Question about Polaroid FLM-2632 Television
Polaroid TLA-01511c Backlights go out
Hi everyone... I've been told that the inverter on this TV is on the PSU board and to replace the capacitors. Can anyone tell me which caps to replace? Board position number or what to look for. I don't see any "puffy" capacitors or any sign of a bad one.
  • Berryn Jan 20, 2009
    I went over both boards with a jeweler's loop. Couldn't see anything abnormal. I don't have any way of checking the capacitors while they're on the board. Still puzzled.
    Replaced all capacitors on the power board (PSU). I read a post saying that this model combined the inverter board and the PSU. None tested defective and TV does exactly what it did before. Comes on for a few seconds then the backlights go out. Sound is still there and when shining a flashlight into the dark screen I can make out the images. The only other board I can find is the main board where all the hook-ups are and the thin flat board on the screen, no inverter board... or is there a separate inverter board for this model?
  • 362 Answers
Hi Berryn,
Your Inverter is in fact built into the power supply, there is a small transformer near where the backlight plugs into the power supply that needs to be checked, if you find no disfigured caps on the board you may want to replace the power supply.
The part number is  200-001-XXXXTLTX-AH
I was unable to find the supply from my vendors but there are a couple on Ebay, this one is gauranteed for 30 days, http://cgi.ebay.com/POLAROID-200-001-XXXXTLTX-AH-TLA-01511C-TV-POWER-SUPPLY_W0QQitemZ170295627068QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item170295627068&_trksid=p3286.c0.m14&_trkparms=72:1205|66:2|65:12|39:1|240:1318|301:1|293:1|294:50
Let me know how it goes. Lone99star
Posted on Jan 19, 2009
    President:
  • 2,110 Answers
I fixed my dead FLM-2632 by replacing the large black 150uf 450 volt power supply capacitor. I used a $4.09 Digi-key PN P14080-ND 420 volt 150UF Cap since I only power the TV on 110 vac. ( http://digikey.com. )The Rubycon 450 volt 150 uf Cap is no longer manufactured because it has poor life in a high ripple current switching power suppy application like used in many TVs. If you are not experienced in soldering, don't attrmpt this repair on your own. You have to cut the leads on the old Cap before you can carefully pry the old cap loose from the RTV. Use solder wick to clean the terminals before installing the new Cap.
  • Polaroid Master
  • 19,396 Answers
If the TV "Comes on for a few seconds then the backlights go out." , and you keep having picture and sound with not backlight, then it is likely the inverter.
If TV comes on, then goes off after seconds, test minor boards, and replace the main unit, on this TV it is all built on digital board.
Inverters that are built in the PSU board are not common, and are considered not serviceable. That means that fyou should replace the whole board.
To test the inverter, you need to test the oscillators on inverter board , read voltages, and test the frequency.
A full test on a malfunctioning inverter may be difficult, we usually replace the inverter.
Here is the part : 200-000-XXXXTLTX-AH
The left half of the picture is PSU, with PSU caps under the metal plate. Left side is inverter, converting back DC to high voltage AC.
part number is : 200-000-XXXXTLTX-AH
Posted on Jan 20, 2009
    Brigadier General:
  • 5,158 Answers
When you are checking the capactors ... you actually need to put your finger on the top of each one (with the power off of course) to check them.... any that feel swelled at the top are bad and need to be replaced.
Robert
  • 53 Answers
I would replace the power supply. It doesnt look like you are gonna get one for less than 80
Part # 200-001-XXXXTLTX-AH
http://www.shopjimmy.com/showparts.cfm?item=603201&ps=6032&pn=1
    President:
  • 2,559 Answers
Check these.
This is the invertor board
  • 4,806 Answers
Hi there
There could be a number of things to do here.
The best thing to do is phone them on 1-866-289-5168 or email them
http://mycusthelp.com/POLAROID/_cs/QuestionAskCI.aspx?
Good luck
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
While the capacitor as chapli has posted would be one possibility, there are other components on this board that may be responsible for inverter failure. It could very well be that the output of the PSU besides it is not reaching the inverter section hence no inverter out.
Still, if you suspect the capacitor then there would only be 2 capacitor on the inverter section on the right side of the board. Blue & black.Polaroid TLA-01511c Backlights go out - 081a775.jpg
Yet you may want to consider board replacement rather than component level repair.
Pls post back result(s). Good luck and Thank you for using FixYa.
    Sergeant:
  • 378 Answers
The capacitors on the meter has to be checked with a device called mulimeter as if you r not been able to find the puffy capacitors on the board.as sometimes its also due to loose soldering joints of thev capacitor and dry soldering whole board solves the problem.get the board checked with a multimeter if dry soldering does not helps.you can get the required capacitors at radioshack websites.
    Genius:
  • 2,920 Answers
It would be simpler and cheaper to replace the board than trying to chase down diodes and bad capasiters,,,they are not very expensive
    Scholar:
  • 160 Answers
Also see for any bulged capacitors or leaky capasitors or which 1 has got burned slightly.also checking with a meter will help to get the faulty on the board.
Polaroid Tla-01511B LCD TV goes blank after power up. Power led stays on. I replaced all 1000uf and 470uf 105 degree caps, no luck. What else should I replace?
have you been tried to dis able the supply going to the inverter board for the back light which may have bad parts causing the supply to drop. by the way is there any blinking lights after it turns off? it will tell you the error either in the power supply, inverter board or at the main board.
Nov 02, 2013 | Polaroid TLA-01511C 15 in. LCD Television
Screen is white when you turn it on but you can hear the audio. after a while it comes on
On older tube televisions this was referred to as the "warm in period". You don't get that on newer LCD as there is no tube to warm. SO, what you've got here is a growing problem with your LCD inverter board or your backlights. Both can be repaired rather easily (and cheaply) at most television repair shops. I've seen a lot of this on polaroid sets, and it almost always gets much worse very quickly. Eventually the TV will refuse to turn on. My recommendation is to get to the repair shop right away!
May 03, 2011 | Polaroid TLA-01511C 15 in. LCD Television
When I turn my Polaroid tv on I get the dish signal and see a picture a few seconds, then goes off. I still have sound.
This problems is the long LCD inverter board is dead.This long LCD inverter board help the LCD screen panel to have a backlight to prduced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a long LCD inverter board for the replacement.
Feb 02, 2011 | Polaroid TLA-01511C 15 in. LCD Television
The picture keeps going on but i cant still hear.
Tv turn on now,u have a picture only flashes few sec and than dies and have sound left only?Yes,ur tv have a dead board,that call the LCD inverter board,this board is a long board.This long LCD inverter help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Dec 15, 2010 | Polaroid TLA-01511C 15 in. LCD Television
Monitor goes black after a few seconds
Tv turn on now,picture flashes only few sec. just dies and have sound left only?Yes,than a long board call the LCD inverter board is dead.This LCD inverter board help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish a long LCD inverter board for the replacement.
Aug 04, 2010 | Polaroid TLA-01511C 15 in. LCD Television
No picture on tV
Yes,Ur LCD inverter board is dead.Replaced this board will get ur picture back.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Apr 25, 2010 | Polaroid TLA-01511C 15 in. LCD Television
My Polaroid TLA-01511C has sound but no picture...what do I do
Replaced the LCD inverter backlight board is dead.After U replaced this LCD inverter board.U will get ur picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board.It a long board shape.
Feb 21, 2010 | Polaroid TLA-01511C 15 in. LCD Television
I have 3 Polaroid TLA-01511C 15 in. LCD Televisions that have no picture but does have sound. Is this a common problem with this model?
I replaced three capacitors on my power supply board and the unit started working again, There was two 680uf 10v caps and one 1500uf 10v cap bad.
Nov 20, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Screen goes dark after few minutes
check your LCD inverter maybe there is loss connection or some parts damage from inverter.
May 05, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Polaroid TLA-04011C
Check the powersupply/inverter board for bad capacitors. Also check the CCFL bulbs in the top and bottom for poor solder connection - replace if necessary.
Nov 08, 2008 | Polaroid TLA-01911C TV
Polaroid FLM-2632 Television Logo
1,136 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
