Question about Empire DV-35 Heater
Have an Empire DV-35-2SG, and when it first comes on it sounds like someone is in the combustion chamber banging it with a hammer, usually 2 minutes. Also, does it right after it shuts down...Loud enough to keep/wake you up!!
3 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: Empire DV-35 low heat low flame
Check your gas pressure, You could have a gas valve problem or you could have a restriction in the air intake.
Posted on Sep 09, 2009
  • 4736 Answers
SOURCE: Empire model dv 40e 3 The
It very well may be that circuit control board has malfunctioned. In which case you should receive a series of blinks from a red blinking light. The number of blinks, determines what the problem is.
These, generally are very dependable high efficient wall heaters.
In case you have misplaced your Owners Manual, I have provided a link to it. You can download and print for future reference if you like.
http://www.empirecomfort.com/EMPIRECOMFORT/pdf2010/manuals/19562-4-0610-DV-20E-5-DV-40E-5.pdf
If all else fails, call Empire Comfort Systems Tech Service at 800-851-3153
Posted on Feb 24, 2011
Blowing smoke
White smoke usually is coolant burning. Is engine loosing coolant? Small pop could have been head cracking, or possibly head gasket failing. If you are loosing coolant, time to remove the head to see what failed.
Apr 07, 2015 | Cars & Trucks
What type of hammer arrestor do I buy to fix banging pipes after installing a new Moen posi-temp cartridge?
Banging pipes are a result of improper piping support. If the piping is secured, the banging will stop. If your only option is to install chambers for water hammer, any will do. Their only purpose is to hold air.
Apr 21, 2014 | Home
Noisy water pipes when neighbours use water
Install air chamber to cushion sudden-stop of flowing water.
Water flow coming to sudden stop is called water hammer, and will bang pipes, but also loosen plumbing joints, causing leaks.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#bang
http://waterheatertimer.org/images/Flow-rates-water-hammer-600.jpg
Air chamber has to be vertical, and about 18" long, with cap on top.
By code each Hot and Cold line at each tap will have air chamber located behind the wall. So there are two air chambers at each tap.
In your case, you can probably add air chamber to your Hot and Cold lines and solve problem for both dwellings.
Water hammer is caused because water does not compress like air.
So when long column of water suddenly stops... the whole pipe-full of water comes to sudden halt... and that water could weigh 1-1/2 pounds ... and just like a hammer head moving, the weight of water bangs the pipes to dissipate energy, causing noise.
Apr 21, 2013 | Water Heaters
09 yamaha r6-Steam or white smoke on start up lasts for about 3-5 minutes
Hi, 123gevans your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. COLORLESS OR SLIGHTLY BLUE SMOKE on start-up means your air/fuel mixture is at the right composition and everything is well burnt in your combustion chamber.
2. BLUE SMOKE on start-up is usually caused by failed valve seals dripping oil into the combustion chamber when the engine is not running.
3. YELLOW OR BROWNISH SMOKE at start-up means your air/fuel mixture is too lean. Too lean means that there is low fuel but high air mixture in your combustion chamber.
4. WHITE SMOKE on start-up may be caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers. Smoke while riding is usually caused by worn out or damaged valves, seals, guides, pistons, rings, or cylinder walls.
5. BLACK SMOKE on start-up is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke/enrichner or not in the off position, air filter dirty and clogged, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large or a damaged carburetor.
It should be noted that aggressive or abnormal throttle operation will cause these conditions to manifest themselves exponentially.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
07 08 white smoke in the exhaust
smoke from exhaust after oil change
Yamaha YZF R6 Service Manual
OEM parts for Yamaha
Yamaha YZF R6 Owner Manual
May 25, 2017 | 2009 Yamaha yZFR6
White smoke come out in my bike in yamaha fzs
Hi, Anonymous your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
White Smoke coming out of the exhaust
White smoke from one of the exhausts when bike has been shut off
Yamaha FZS FZ16 Service Manual pdf
Yamaha FZ16 User Manual pdf
Oct 09, 2012 | 2009 Yamaha FZS
There is black "dust"all over
the dv 215 uses no room air for the combustion. it is called a sealed combustion unit all combustion air and vent gases are outside of the building. look at the vent cap outside. is it black? if not unit is most likely working ok. if it is black you need to have it checked. so unless the unit has been damaged you should be getting no air from the combustion into your room.
Feb 08, 2011 | Empire DV-215 Direct Vent Natural Gas...
Martin lp gas heater has recently begun to make loud metallic bangs during use. This heater is approximately 15 years old. Can these metal banging noises be a sign of something potentially dangerous? ...
If you can inspect the combustion chamber for cracks it may be a good idea. To get rid of the banging, put a dent in the metal combustion chamber.
Jan 18, 2011 | Heating & Cooling
MY WILLIAMS WALL GAS HEATER MAKES A LOUD BANG AFTER A FEW MINUTES ON
Question, is this bang a metal sound or like a small poof of a gas burner? If it is a metal "bong", it is the heat exchanger expanding. You could hit the combustion chamber with a hammer causing a dent (really) and it may take the noise away. If it is a "poof", it should be looked at by a technician.
Jan 04, 2010 | Williams 2509612 Ceramic Mid-Size Heater
B vent configuration of direct vent propane heaters
Yes, the design of the combustion chamber is limited at how much fresh air and combustion air can enter it. If you lengthen the venting, you will be causing more restriction and there will not be enough natural air movement to make it work. It will start, run for a minute or two and poof out. Not to mention you will be circumventing it's UL rating and if you sell your home with it installed, you are liable for any fatality or damage. Do you want to risk that? Don't even think of doing it! There are "Box" heaters out there sized from about 5,000 Btu's on up to 100,000 Btu's. Check the web.
Sep 17, 2008 | Empire DV-215 Direct Vent Natural Gas...
Empire DV-35 Heater Logo
76 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
rudyjoe
Level 1 Expert
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
