Question about Canon PIXMA mini220 InkJet Photo Printer
Error 5c00 mini 220 - Canon PIXMA mini220 InkJet Photo Printer
CANON MG8100 series error 5C00
Per http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#5c00
5C00 - Orange and green blinking 4 times Description:
A service error has occurred.
Resolution:
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
May 27, 2014 | Canon PIXMA iP3500 Printer
Canon printer ip90V is showing Error 5C00
A 5c00 error relates to the sensor in the purge unit, which is where the carriage stops on the right hand side of the printer. You may find that the ink has built up in the purge unit and it will need to be washed out in warm water. The sensor in the purge unit will need to be removed before washing the unit. Problem is getting the purge unit out is quite tricky.
Rating the solution is highly appreciated.
May 25, 2010 | Canon PIXMA iP90v Printer
Service error 5c00 canon ix4000
Purge cam sensor error [5C00], PG position error [5C10]
Mar 23, 2010 | Canon PIXMA iX4000 InkJet Photo Printer
Canon ix4000 error 5c00
error [5C00] & Light Blinking 4 times = PURGE CAM SENSOR ERROR
you may need to replace :
- PURGE UNIT
- LOGIC BOARD ASSY
Oct 14, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Error Code 5c00 for Canon ix4000
5C00 is a purge assembly error, it happens when paper is caught stopping the cleaning blades from working properly, or when the purge unit is just worn out.
Aug 20, 2009 | Office Equipment & Supplies
Canon iP90 error 5C00
5C00 is a purge unit error, thats the cleaning unit on the right where the printhead parks. Look inside with a flashlight, if nothing is blocking it's operation, you willl need a new print engine, qm2-2020-000 around $150.00
Jul 21, 2009 | Canon PIXMA iP90 InkJet Printer
Error code 5C00
Error code 5C00 refers to a purge unit error. This is a service call error and requires that the printer be taken into a canon authorized service facility for diagnostic and proper repair.
May 15, 2009 | Canon I900D InkJet Photo Printer
Canon printer ix4000 service error 5C00
bagai mana caranya menanggulangi eror 5c00 Printer ix4000, mohon petunjuknya
Apr 01, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Canon ip3000 shows service error 5c00
5C00 is Purge unit error.Check for object around the purge unit.
Feb 23, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Service error 5C00 or 5100
5100 Make sure nothing is blocking the cartridge movement, if not requires service.
Mar 27, 2008 | Canon BubbleJet i560 InkJet Printer
Canon PIXMA mini220 InkJet Photo Printer Logo
64 people viewed this question
old marine
old marine
