Question about Whirlpool LEN2000PW Dryer
Dryer not heating
Dryer spins but does not heat. After I replaced the heating element it worked again. But then I replaced the cutoff and hi-limit thermostats as well and it no longer works. With multimeter checked for short circuits and continuity across the thermostats, heating element, and thermal fuse and detected no problem. At the thermal block, got 120 at each of the two leads, but instead of 240 got voltage off the meter combined. What should I do now? Thanks.
  • 26 Answers
Its a good possibility that you have lost the nuteral connection at the power block or the receptical .
Posted on Jun 22, 2014
ronpar
  • 27 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Posted on Jun 29, 2008
aasc
  • 1606 Answers
SOURCE: Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
Posted on Aug 01, 2009
hiltonjug
  • 612 Answers
SOURCE: can't control heat setting
Either your dryer vent is clogged, the blower wheel is striped out and not turning or the internal bias thermostat you bought is bad. These are the only things that can make the dryer over heat.
Please rate solution.
Posted on Sep 05, 2009
  • 44 Answers
SOURCE: Have replaced heat element, thermostat, thermal
I'd like you to try something easy. Set the dryer to Air Fluff and see if the dryer still puts
out Heat let it run for about 2 full minutes If you dryer is still putting out Heat get back to me
Posted on Nov 20, 2010
  • 3074 Answers
SOURCE: dryer won't heat. I have
timer motor, here is a website that should help, Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Posted on Jan 15, 2011
Electric dryer getting way too hot
3-5 ACCESS TO THE BLOWER WHEEL OR THERMOSTATS
To get to the blower wheel, remove the back of the dryer.
The blower wheel is under the bottom of the lint screen duct to your left, as you look at the back of the dryer.
The operating thermostats are at the blower wheel outlet.
In electric models, the hi-temperature cutout thermostat is mounted to the heat riser.
3-6 TEMPERATURE CONTROLS AND HI-TEMP SAFETIES
These clothes dryer machines use operating thermostats to control the temperature inside the drum, and hi-limit thermostats to prevent overheating of the dryer drum.. Many machines also have extra temperature controls, such as bias thermostats and heaters, hi-temperature cutoffs, and thermal fuses.
Bias thermostats are just like regular operating thermostats, except that they are mounted inside a bias heater. When the bias heater is energized, it generates a small amount of heat, which causes the operating thermostat to open sooner, keeping the dryer drum cooler inside. Thus a bias heater allows a single operating thermostat to act like both a hi-temp and a lo-temp operating thermostat.
A thermal fuse is found on the blower outlet, right next to the operating thermostat(s.) This fuse will blow when too high a temperature is sensed at the outlet; usually when one of the operating thermostats has failed. If it blows, the motor may not start, or you may get no heat (no voltage to the burner.)
A thermal cut-off is mounted on the clothes dryer heater box. It is a back-up for the hi-limit thermostat. Whenever you replace it, you should replace the hi-limit thermostat, too. A high-temperature condition causes it to open, an overheated grounded heat element may also cause it to open.
Dec 01, 2013 | Kenmore Elite HE4 Electric Dryer
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
Kenmore elite model 11062952100 My dryer will not heat I replaced The thermal cutoff and high limit thermostat the dryer produce heat briefly but is not producing heat again.
There is a high limit switch (looks like a button with two wires hooked to it) on the bottom of the vent frame. When the vent fills up with lent at the bottom it gets hot. For safety, this limit switch will turn heat off. Remove the vent frame and clean it out and check the continuity of the switch. Also, make sure both heater elements are working properly.
Jun 19, 2011 | Kenmore 63942 Dryer
Should you have continuity on the cut off switch?
4239059.jpgcheck this out: If either one of these limits mounted aside the heat chamber check open the dryer will not heat but it will run. These come in a kit with both limits and both limits need replacement.
Apr 11, 2010 | Dryers
Dryer has no heat anymore.
No, but there is a thermal cutoff located on the element. Which blows at 350 degrees and needs to be replaced for the dryer to work again. Since it blew, you will also need to replace the hi-limit thermostat, which cuts the element off at 250 degrees. They are both right next to each other, and you will need to remove the drum to get to them.
Dec 05, 2009 | Dryers
Where is the heat element on this dryer? Dryer is not drying clothes. Dryer do spin but no heat. Changed fuses. Fan belt still intact.
Either on the back of the machine or on the floor under the drum.  If the lint trap is on the top it will be in the back of the unit, if the lint trap is in front, it will be under the drum.  Before you replace the element check the thermal cutoff which is on element.  If it is blown you will also need to replace the Hi limit thermostat also on the element.
Nov 07, 2009 | Roper REX4634KQ Electric Dryer
NO HEAT
Check for 220 volts incoming at the terminal block where your cord connects.
Make certain the dryer wiring is good there also.
Check the heating element to a ground on the dryer.
Check the continuity tthrough the start switch on the motor.
for the heater wire connection.
Mar 09, 2009 | Whirlpool LER4634J Electric Dryer
Clothes dryer not heating
I eventually changed the thermal cutoff switch and the high limit thermostat as suggested in one of your replies to another consumer and now the dryer is working fine. Thanks.
Nov 13, 2008 | Zanussi TC7114W Electric Dryer
Whirlpool Dryer Thermal Cutoff Wiring
the thermal cut off wires do not matter how you put them on.. The high limit is wired in series with the heating element.one red thick wire to element the wh/red top side of the high limit stat out of the high limit sat(other side) then goes to the other side of the heating element
Feb 20, 2008 | Dryers
Whirlpool LEN2000PW Dryer Logo
55 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
