Question about HTC HD7 Cell Phone
Error code: 805a01f7
Market space is not available
Status code 4174-0000-3080-0504-8007-000D
This is very simple: you seem to not have enough hard drive space for a system update that your console is trying to install.
Error 8007 0070 occurs when you install an update or buy content on...
(I've pasted some bullet points for you)
" Error 8007-0070 occurs when you install an update or buy content on Xbox 360
Problem
You may see the following error code and message when you try to update your Xbox 360 console or purchase content:
xxxx-xxxx-xxxx-xxxx-8007-0070
Note
The "x" characters in the error code vary.
This may mean that there's not enough space on your storage device (mostly likely the Xbox 360 hard disk) to install the update or the content.
Solution
A console update or content download may require significant hard disk space. If you don't have enough free space, you need to move or delete some items."
You can probably get around this by using a 32gb USB thumb drive and moving some of your content that's hogging up your console's space onto that thumb drive temporarily.
Heres the Xbox.com info to get you started about moving and deleting hdd space--which also has info about using a USB thumb drive, too. Copy move or delete Xbox saved games profiles and avatar items
Jul 21, 2014 | Microsoft Xbox 360 Console
Eror code 093-555
Get in touch with the friendly Xerox Engineer, I think I remember this error code being the Cyan print head is not performing as it should. A bad batch of Cyan was allowed onto the market a lot time back and the plumbing and print heads became bunged up, due to crystallisation within the hot wax.
Hope you have a service contract!
Good Luck.
Mar 12, 2014 | Xerox Corporation ColorQube CQ9302 9302/P...
Canon mf3010 scan driver error there is not enough free space to complete the scan freeup available disk space scanner driver will be terminated
This error occurs when there is no enough memory on your C Drive, Did you have a check on the Memory which is left on the Drive?
Feb 20, 2013 | Canon Toner Cart /MF3010
Error code 0x81000019
Does your motherboard support USB 3.0?? I'm using Go-flex too but it is working fine so far on USB. 2.0. or could you give some of computer or laptop 'spec'?
Nov 16, 2011 | Microsoft Windows 7 Ultimate for PC
I have tried to reset the system from scratch with a best buy geek squad recovery disk series and I get error: 403 with no other info when I try to restore the C drive to preinstalled factory settings
For a New Hard Disk Recovery with the Sony Recovery DVD's, do a complete restore, and leave the SKIP button selected on the last screen when asked if you want to recover the C: Drive.
Sony are a bit wierd the way they work this step.
Try that anyway and failing this try entering the bios at boot up and making sure your time and date are right and try again.
Mar 20, 2011 | Sony VAIO NS Series Notebook
Critical error! Windows can't find hard disk space. Hard drive error -- Damaged hard drive clusters detected. Pruvate data at risk!....What should I do ?
Try deleting all files within the following locations: (In Windows Explorer (not Internet Explorer) click "Tools" and select "Folder Options" then choose "Show hidden files" and take the tick out of "Hide protected system files")
%UserProfile%\Local Settings\Temporary Internet Files\
This is the action of some form of malware, masquerading as Windows Security Center. It roots itself in the current user's temporary data folders and as far as I know, doesn't affect all users.
It is also a hidden process but as far as I know, doesn't execute any particularly malicious code, just a really annoying notification (which you'll notice changes).
Nov 02, 2010 | Microsoft Windows XP Professional with...
Cannot save to computer
That error means the either in reality, or the computer"Thinks" that there is NOT enough HDD space to transfer the 30 min Video, a 30 min Video, will be a large file, toy need to ensure you do actually have enough room to copy to the HDD. if this isn't the case, then your unit may have developed a problem.
May 12, 2010 | Flip Video Camcorder
Can't burn photos onto disc
ok sir your using withch vrsion nero software telme firast ?
any way first uninstall nero software next install your copany nero software. Problam solove if any Problam contact:
uday_uday2004@rediffmail.com
Apr 02, 2008 | Computers & Internet
Out of hard disk space
try to delete all temp file and reinstall your driver software disk may be your software is corrupted bcoz of that you geeting this error. bye
Sep 17, 2006 | Konica Minolta Dimage Scan Dual IV Film...
HTC HD7 Cell Phone Logo
32 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
