Question about Magic Chef Refrigerators
My magic chef refrigerator, model MCBR415S motor stopped running
The motor on my Magic Chef mini refrigerator, model #MCBR415S stopped running.
5 Suggested Answers
  • 146 Answers
SOURCE: Magic Chef MCBR415S cabinet get's very HOT!
* Is your compressor motor running all the time ?
* have you checked and cleaned your condenser coils at the back ?
* Is there sufficient airflow around your refrigerator (especially at the back) ?
* Is your refrigerator and freezer cooling properly ?
Sounds like your unit is working overtime - it will usually get hot like that when compressor motor has been running a long time and heat does not dissipate properly at the back - it also gets hot after a defrost cycle - it should NOT be hot at all times. CHeck to make sure your temps are correct to rule out a stuck defrost cycle timer - your refrigerator should not be hotter than 40F and your freezer's temp between 0F-10F, the optimal temp is 0F.
Posted on Aug 18, 2009
SOURCE: i NEED A PICTORAL DIAGRAM
hi
i'm not sure will you find you solution
go to following link i hope you will find your solution
http://derilob.t35.com/index.html
Posted on Nov 02, 2010
heatman101
  • 43501 Answers
SOURCE: I have Magic Chef refrigerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Jul 03, 2011
imufo2
  • 3773 Answers
SOURCE: I have 'Magic Chef' 10.0 cu. ft. Refrigerator.
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Jul 28, 2011
The Magic Chef Refrigerator Electronic Thermostat - SF-WB-4/CM will only cool to 45 degrees, Is it possible to change out the thermostat with another factory unit fom a standard mini frig ?
Putting another thermostat would not help it be cooler it actually stop it from functioning all together if it's not recommended by the manufacturer
May 08, 2014 | Magic Chef Refrigerator Electronic...
4.0 magic chef freezing on the back wall
you have a defrost component not working , timer , thermost , or defrost thermo
Nov 29, 2013 | Magic Chef Refrigerators
I have Magic Chef refrigerator model MCBR415S frezzer is working but the refrigerator only cools to 52 degress what can be the problem
heatman101
Jul 02, 2011 | Magic Chef Refrigerators
I have a Magic Chef Mini Fridge model number MCBR465S that stopped cooling. I can hear it humming but don't know how to diagnose the problem. The seal on the door is a little bent up (not really bad) on...
First fixed the seal make sure that any leaking out. And then go to the next step by checking to see if the compessor motor come on and stay running for af list 10 minute. check the temperature controls make sure they are at the set temperature.
If you go behind the fridg and take the motor temperature see is very hight you must unpluged the fridg you may have a bad motor.
Oct 24, 2010 | Magic Chef MCBR445S1 Stainless Steel...
Magic Chef refigerator/freezer stopped running
if you said stop running id assume that there is no power?? even with good electrical input..
for that instance, better check.charred cables.. if not there maybe a problem with timer itself..
Nov 05, 2009 | Magic Chef CTB1922 Top Freezer...
Aug 17, 2009 | Magic Chef Refrigerators
Magic Chef Mini-Fridge not Working, Model # MCBR360S
Unplug and look for the thermostat control. Try jumping the thermostat wires together. If it runs then replace the thermostat. Also feel the compressor to see if running, they run very silently. Thanks, Sea Breeze
Apr 27, 2009 | Magic Chef MCBR440 Compact Refrigerator
Refrigerators Logo
67 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
