Question about Hunter 52" Ceiling Fan With Light And Remote Control
Hunter ceiling fan 22450 no reverse switch manual says there is.
Vaulted ceiling and has light kit with variable speed an on off for light. No reverse switch on fan as in manual.
    Top Expert:
  • Hunter Master
  • 41,955 Answers
The reverse switch usually is in the lamp housing directly under the motor. With a vaulted ceiling installation, you would need to use a ladder to get access to the switch
Posted on Jan 04, 2013
    New Friend:
Model 22450 does not have a reverse motor. The blades are spring loaded. You change the blade pitch by pushing in and twisting. This will change the air flow direction.
Posted on Mar 18, 2014
landsend
  • 1066 Answers
SOURCE: My Hunter fan will only switch from high to low speed and won't
if the three speed switch is functioning the middle speed winding is bad.  Either replace the fan or hook up a wall speed control and keep the fan on high.
Posted on Mar 26, 2009
SOURCE: have a hunter ceiling fan with light kit and
This is likely caused by stray frequencies in the neighborhood. Change the frequency on your system and see if the lights go off less frequently.
See the manual for the remote system. You'll need to go into the top of the fan and change some little switches (dip switches) and set the same frequency on the transmitter (what most call "the remote").
Charlie
Posted on Aug 21, 2009
Testimonial: "Thanks!"
  • 1114 Answers
SOURCE: Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Posted on Jul 21, 2009
  • 34 Answers
SOURCE: HUNTER ceiling fan remote works with fan but not light
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot2.gif. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
Posted on Sep 10, 2009
  • 6 Answers
SOURCE: Similar problem: Does Hampton Bay Vaulted Ceiling Mount exist?
Ok so here is the deal. No there does not seem to be a Hampton Bay specific mount. The mount that comes standard in most of the Hampton Bay fans can handle the angle of most standard (read: small) angles. I do not know if it will be the case with all Hunter products, but the adapter for the Hunter fan that I replaced, worked with my new Hampton Bay. So now, I have from the downrod up is from the original Hunter fan. Hope this helps.
Posted on Mar 26, 2010
I have 2 Hunter ceiling fans and the wall switch has 2 knobs which you push to click on or off.......after you click on...you can turn the knob and increase or decrease the fan speed. You can click on both...
Hello .. you should be able to find a replacement for your fan control at any building supply store, a home depot type store. Look or ask for a variable speed fan control. This is slightly different from a normal liight dimmer . You might also look for a replacement knob before replacing the whole switch, or matbe getting a replacement just to replace the knob ..
Jun 18, 2010 | Hunter Ceiling Fan Control Switch
Reinstall of a hunter model 22450
Can you put a 2X4 between the joists and bolt the fox to that?
Jun 09, 2010 | Hunter Fan Company 5/1/1 Programmable...
Hampton bay vaulted ceiling mount adapter? Do they exist?
If you have a Menards Home Hardware store in your area they will stock this item. Home Depot, Lowes, & Sears Home Centers may have them too
Apr 15, 2010 | Hunter Vaulted Ceiling Mount - Bright...
Receiver 85112-04 need a replacement for hunter fan remote receiver which is housed in the based of the fan in ceiling.
I realize that this is an old post. However, the best solution is to replace the receiver with 3 or 4 speed wire harness, which includes the capacitor, fan speed switch, forward/reverse switch and female plug for $15 as of today's writing. While you may be able to find a 85112-04 replacement receiver, I found them to be an expensive solution at $80. In addition, there is no telling how long the replacement receiver would last. To purchase a 4 speed wire harness for this Hunter fan, they can be ordered from
Casablanca. Casablanca you say? Yes! Casablanca is a subsidiary of Hunter Fans. This 4 speed wire harness, part number K016501H01, is standard in many Hunter and Casablanca fans. Hopefully this will help someone looking for a low-cost solution to replacing the fan. Link below:
http://www.casablancafanco.com/Parts-Manuals/Part-Manual-Detail?ModelNumber=54019
Apr 11, 2010 | Hunter Ceiling Fan Remote Receiver...
Sep 16, 2009 | Hunter Vaulted Ceiling Mount - Bright...
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
Mar 26, 2009 | Hunter 23852 Classic Original Ceiling Fan
Hampton Bay ceiling fan - will not reverse
It sounds like the direction switch has a broken connection on the "reverse" side.  Should be an easy fix (but you might need a soldering iron).
Dec 07, 2008 | Kitchen Appliances - Others
Ceiling fan and light wiring, 2 switches, 1 romexHunt
If you have only one black and one white in the ceiling to connect the fan / light to , then you have only one switch for this ceiling box. The fan / light will connect the white wires together and then the two colored wires on the fan to the black ceiling wire. In order to use separate switches for the fan and the lighht a 4 wire cable must go from the switches to the light so you have a red and black wire to switch the two separately .
Oct 30, 2008 | Hunter Vaulted Ceiling Mount - Antique...
Two fans, remotes work with one, not the other
YOU MUST TRY CHANGEING THE CHANNEL ON THE REMOT AND TRY IT THEN IF IT DOES NOT WORK YOU MUST TAKE DOWN THE FAN AND CHECK WHAT CHANNEL THE RECIEVER HAS AND MATCH IT TO THE REMOTE.
Nov 04, 2007 | Hunter Vaulted Ceiling Mount - Antique...
Dryers Logo
807 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
