Question about Riccar Vacuums
Riccar brilliance fan replacement - Riccar Vacuums
  • Riccar Master
  • 1,510 Answers
Take off the bottom plate and the nozzle housing cover. Remove the motor cover to get to the direct air motor. This is not a difficult fix if you take your time to make sure you reassemble it properly
Posted on Mar 08, 2014
2 Suggested Answers
  • 694 Answers
SOURCE: Where is the model number on the Riccar Brilliance
As you're looking at the back of the vacuum, the model number should be located on the tag beside the right wheel. If there is no model number there, then the model is simply the name of the vacuum, in this case Brilliance.
Posted on Jan 09, 2011
The roller brush of my Riccar Brilliance vacuum is suddenly spinning extremely fast; way faster than normal, and is very loud. How do I rectify that?
I will likely save money by having it checked out by your local Riccar service center. A Brilliance can last a long time and work great but like any quality vacuum should be properly serviced every year or two depending on use. A qualified service technician knows what to look for and what your vacuum needs to work properly.
Jan 21, 2018 | Riccar Vacuums
I can't reset my thermal reset button on my Riccar Brilliance
You may have hair and debris in the endcaps or bearings of your brushroll causing a restriction. The belt sensor thinks you have something stuck in the brushroll so it shuts it off. It's a simple fix, if you can't figure out how to do it take it to your Riccar dealer.
Feb 25, 2016 | Riccar Vacuums
How do i replace the fan on a riccar rsl3 vacuum cleaner?
RICCAR SIMPLICITY SUPRALITE RSL MOTOR and FAN
Its looks the same as a Kirby its done with a nut on the axle on the armature of the motor.
Feb 20, 2016 | Riccar Vacuums
How do I change the fan in my riccar vacummn?
It depends on which model you have. Most models have a fan that will never need replaced. Tandem air and Supralight models have a fan that could be damaged on older models but is unlikely on newer models as fan are now made from a flexible material. Remove the motor assembly and disassemble to get to the fan. Remove the nut from. The shaft and remove the fan. Install new fan and put back together in reverse order as it was taken apart.
Feb 28, 2015 | Riccar Vacuums
Why does my riccar supralite vacuum makes a loud rattling noise like the roller is banging around?
You have something wrong with your brush roll or you have damaged the fan. Remove the brush roll and belt and turn the vacuum back on, if the noise is gone it is likely something wrong with your brush roll, if the noise persists you probably have a broken fan. You have to remove the motor and fan housing after removing the top cover, unscrew the bolt holding the fan on and install a new fan (you can get one from any Riccar or Simplicity vacuum dealer)
May 15, 2014 | Riccar Vacuums
Replace belt on Riccar Brilliance
The Brilliance has a lifetime belt but if it gets overheated it can get warped and comes off. Normally you do not need to replace the belt unless there is a problem. You have to remove the cover over the power nozzle assembly by removing the screws on the bottom. Notice how the belt goes around the motor shaft and through the "Hall Assembly" which is the spring loaded lever that detects a jam and shuts the brush roll motor off.
Jan 23, 2014 | Riccar Vacuums
Riccar rsl5 motor fan impeller replacement
From your local Riccar retailer.
Dec 01, 2013 | Riccar Vacuums
Where is the model number on the Riccar Brilliance upright?
Jan 09, 2011 | Riccar 8955 Upright Vacuum
Where can I get replacement wheels?
Greetings from GoVacuum.com,
I just wanted to let you know that we are an authorized Riccar dealer, and we can certainly get the replacement wheels for your Riccar 4812 upright vacuum cleaner.
We stock some parts, and what we don't stock we'll order for you. We don't currently have the wheels on our site, but if you still need the wheels, you may email me at chris.jones@govacuum.com.
We do stock a lot of parts for your 4812 Riccar, including the following;
Riccar 4000 Series Bags That Fit the 4812. Paper Bags 12pk.
http://www.govacuum.com/ricc103.html
Riccar 4000 Series Exhaust Filters for the 4812 Part RF4-2;
http://www.govacuum.com/ricc117.html
Riccar 4000 / 8000 Series Drive Belts Part # A20-R2P
http://www.govacuum.com/ricc112.html
Foam Filter Underneath of Bag Riccar 4812 Part B622-0500
http://www.govacuum.com/ricc133.html
I look forward to helping you if you still need to get the wheels for your vacuum.
Thank you,
Chris J.
GoVacuum.com
Jan 11, 2010 | Riccar 4812 Vacuum
Vacuums Logo
204 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
Jim Parker
Jim Parker
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
