Question about IBM Lenovo ThinkPad W510 43194MU Notebook PC Core i7 i7720QM 16GHz 156
Lenovo laptop how enable wireless - IBM Lenovo ThinkPad W510 43194MU Notebook PC Core i7 i7720QM 16GHz 156
Lenovo Z70-80 problem with wifi (don't show). Please do you know why? Thanks for any answer
see p18 of the user guide, downloadable from Lenovo website for how do this in win 8.1 (selt other o/s presumably)
it says
Connecting to wireless LAN - - -- - - - -- - - -- - - - -- - - -- - - - -- - - - -- - - -- - - - -- - - - -- - - -- -
Enabling wireless connection
To enable wireless functions, do one of the following:
• Press F7 ( ) to disable the Airplane mode if the mode is enabled.
• Open the charms, and select Settings ? to open the Network
configuration page. Toggle the Airplane mode switch to Off.
Connecting to a wireless LAN
After wireless has been enabled, the computer will automatically scan for
available wireless networks and display them in the wireless LAN network
list. To connect to a wireless network, click the network name in the list, and
then click Connect.
Note: Some networks require a network security key or passphrase for connection. To
connect to one of those networks, ask the network administrator or the Internet
Service Provider (ISP) for the security key or passphrase.
Jan 15, 2016 | Lenovo Computers & Internet
How to connect wifi in lenovo g575
In order to connect to a wireless network and the Internet on an IBM Lenovo machine, you must first enable wireless networking via your computer's operating system. Allow about five minutes to enable your IBM Lenovo computer's wireless capabilities.
Click the Windows logo in the bottom left of your screen. Select "Control Panel" from the menu. Click the "Network and Internet" icon in the Control Panel. Click "Network and Sharing Center." Right click "Wireless Network Connection" icon. Select "Enable." Enable Wireless via Switch Check your IBM Lenovo laptop for a wireless networking switch. It is usually on the front of the computer above the keyboard. Slide the wireless switch to the "On" position. Look for a wireless light on the front of the laptop. In some cases a light will come on to indicate that wireless networking is active. Other switches, when active, reveal a green strip of plastic.
Troubleshoot network connection problems http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-network-connection-problems Lenovo support http://www-307.ibm.com/pc/support/site.wss/migr-50402.html
Apr 02, 2013 | Lenovo G575-438343u Amd E-350 1.60ghz...
How do i turn the wifi on on my lenovo ideacentre b3?
Step 1:
Feb 24, 2013 | Computers & Internet
WIRELESS NOT WORKING
Welcome to Fixya
Lenovo laptop usually have wireless switch located either at the front of the laptop or at the side. All you need to do is to slide the switch to turn off/on the wireless adapter. You may also use function key to enable/disable the wireless adapter. Press Fn + Esc key to enable and disable wireless capability.
Thank you for using Fixya!
Sep 04, 2011 | Lenovo 3000 C200 Notebook
How do you enable wireless on a lenovo G550?
Welcome to fixya
You can enable the wireless adapter of your notebook by pressing FN+F5 simultaneously. You also need to verify that the hardware switch on the right side of the laptop is toggled on
Hope this helps
Aug 06, 2011 | Lenovo G550 PC Notebook
My laptop is lenovo b460. I have the wireless switch on and it is showing that wireless connections are available. But it does not show the available networks. Please suggest some solution.
There are two ways to view available wireless connections.
1. Thru windows: press Start>Connect to>enter.
2. Lenovo has proprietary software installed called access connections. If this is enabled it should be accessible thru: Start>All Programs>Access Connections. If not enabled it also should be available thru the Control Panel.
Jun 08, 2011 | Computers & Internet
How to enable wireless of lenovo thinkpad R400
hi mmi300, try to press Fn + F5 and check if it works. Pls determine if there is a toggle switch (if it is a laptop) somewhere. Disregard that step if it is a desktop...
Hope this help...
May 09, 2010 | Lenovo ThinkPad R400 Notebook
How to turn on wireless on Lenovo T61 laptop?
I checked the manufacturer's web-site:
http://www-307.ibm.com/pc/support/site.wss/product.do?brandind=10&familyind=374625&machineind=0&operatingsystemind=49979&template=%2Fproductselection%2Flandingpages%2FdownloadsDriversLandingPage.vm&validate=true
but did not find any device-driver for the wireless-adapter for your Operating System.
This might imply that the wireless-adapter is fully supported by the Operating System, i.e., no additional device-driver is needed.
Open the "Network Connections" window, and display all the currently-defined network-adapters -- the wireless adapter should be present. Select it, and right-mouse click on its icon, and choose "enable".
Apr 29, 2010 | Lenovo (40Y7026) Wireless Adapter
Bluetooth problem in lenovo 3000 G430 laptop
i am using lenovo 3000 g430, and i am fall in problem about bluetooth,
i am already install xp and vista, but when i install the bluetooth driver
one warning message show me "bluetooth device not detected"
my bluetooth device switch is on but indicator led light still off,
please help me , how can i use bluetooth in this laptop.
Dec 13, 2009 | Lenovo 3000 Y410 Notebook
IBM Lenovo ThinkPad W510 43194MU Notebook PC Core i7 i7720QM 16GHz 156 Logo
18 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
