Question about Pure Digital Flip Video Ultra Camcorder
My flip video camera froze.it wont turn on....
After recording something we pressed stop recording but the red light did not go away we freaked out and tried to turn it off but it wouldn't go we just let it sit there in the morning it was off. i tried to turn on but it didn;t turn on so i plugged it in to my computer and it didn't regester it and nothing happened it wont turn on!!!! help!!!
  • 7 more comments
  • Anonymous Jan 22, 2009
    I have the same problem. I'm waiting on response from Flip website
  • nutmeg408 Jan 23, 2009
    i have a solution
    let it die until the screen goes black now all the battery is out you need to charge it for about 4 hours and its all better and no videos are deleted its all good.....
  • Anonymous Jan 24, 2009
    HELP HELP HELP:
    Myself and Kelly (my firend) were making a video for school and my black flip camera .. WONT SHUT OFF.. The little red light is still on. and our faces are foozen on the camera screen... WIll this fix its self or do i need to return it and get a new one.. if one of ya'll could get back to us that would be WONDERFUl
  • Anonymous Jan 28, 2009
    Have you tried resetting the camera? Hold down the power button and the red button simultaneously until the camera shuts off (takes about 10 seconds). Then, just press the power button again and the camera should turn back on. I had the same problem; when I pressed the red button to stop recording, the camera froze, and the red light remained on. I tried resetting it like this, and it seemed to work.
  • Anonymous Feb 14, 2009
    I cant turn my video camera on
    I can't turn on my flip ultra series camcorder. i was filming some videos out side and i went to turn it on but it wouldn't turn on. i changed the batteries about 5 times, pluggedit in to my computer and still nothing. What do I do.
  • sk8darkstar1 Feb 17, 2009
    my ultar flip will not turn on even when i have brand new batteries how do i fix it
  • kadyliz4 Mar 11, 2009
    my flip ultra died, so i put in brand new batteries and it still wont turn on. what do i do?
  • anothrealtor Apr 14, 2009
    Video recorder turns on will not function, and can not turn off.
Posted on Jan 28, 2009
  • 1 more comment
  • m_armand11 Nov 14, 2010
    had the same problem and this one was the ONLY solution taht worked and fixed our porblem. THANK YOU!
  • w2lucky May 15, 2011
    You are da man! After frustrating days trying everything, this worked. The key is the ten second hold on both buttons. Thanks amigo!
  • kris zielinski Jul 19, 2012
    thank god for google and this answer... i tried holding the power button for 30 econds, the record button for 30 seconds and i did try both togethe but not for the full 10+ seconds. i think it was a bit over 10 seconds but it may have just seemed that way because the camera was so hot from being on an hour (not at home when this happened) that i was totally freaked out.
  • 3 Answers
I had the same problem with my flip mino hd. Here are the steps I took to fix it.
1. Adjust the power options on your laptop to ensure it does not sleep/hiberate ever.
2. Reset the camcorder by inserting a paperclip into the hole in the tripod mount. Hold the paperclip in there for about seven seconds.
3. Then immediately plug the flip into the cpu.
4. You may not see anything besides the little blinking white light on the USB arm for a while (about 30 minutes maybe) but leave it in.
5. Eventually it should spring to life and show the recharging battery on the little screen (the Flip Share program may start too.)
6. Leave it charging until the little white light stops flashing - full charge about 3 hours.
7. You can then remove the flip and change the power settings back to normal.
Posted on Apr 17, 2009
  • dogarey Jan 11, 2011
    I rested it, and I plugged it to the computer for more than three hours. nothing happen but the light still blinking.
I had the same problem. Try popping the battery cover off, removing the battery, then replacing it. This worked for me.
Posted on Dec 07, 2009
You have to **** it and then it will turn on
Posted on Sep 21, 2009
I pressed the red bottom and the power bottom simultaneously and it did work. Thank you so much luminescence whoever you are.
Posted on Feb 06, 2009
HI....thanks for that suggestion Lumi....it worked!
Posted on Mar 23, 2009
Guest! I love you to death!!!!!!!!!!!!!!! It worked!!!!!!!!!!!!
Posted on Feb 13, 2009
While recording with my mino it just turned of i thought it might be dead but when i went the charge it the white little light was blinking but nothing happened to the screen i charged it over night and tried to turn in on today still nothing I've tried everything everyone has said but still nothing
Posted on Oct 28, 2011
Luminescence is a savior, if what he said doesn't help then you might be screwed, but it saved my *** :D
Posted on May 08, 2010
Hi I have a flip video ultra HD and when the battery was low I plugged it into my computer to recharge and it has not worked since. It wont even turn on. I tried the suggestions above and nothing has worked. Help please!!!
Posted on Feb 03, 2010
Have a new Ultra HD Flip Video. How do I know when it is fully charged? Does the red light go off or what?
Hello there,
The Flip Ultra should have a rechargeable AA battery pack.
To verify it is charging, the battery icon will be flashing lightning bolt. The red light goes from red to green the moment it is fully charged. It takes six hours before it gets a full charge via the USB.
Please let me know if this gave you enough information. Thank you for using FixYa.
Oct 08, 2010 | Pure Digital Flip Video Ultra Camcorder
Hi I have a Flip Ultra Video. When it says I still have 1 hour 23 mins of recording time the camera shuts down. Battery?? I plug it in to charge and after that it says I have over an hour left of...
1) Put your Flip Ultra back into the pakaging box
2) Keep it safely inside your fridge (make sure the fridge isnt on or the best is an old fridge model)
3) Scratch your head and scratch your nuts in the same time for thirty second
4) Turn on your Flip camera, press the red button for setting, and change it to indonesian language. If no indonesian language in the setting, shake it 3 times. It surely has.
5) Jumping around on your parent bed.
6) Sing Britney Spears song and film it yourself.
7) Press stop button
8) Post it on youtube.
I hope this will fix ya problem. Have a nice day :)
Sep 16, 2010 | Pure Digital Flip Video Ultra Camcorder
I cleared all the files on my Flip camera and all the files are deleted but the amount of memory is not going back to 60 minutes it is now at 35 minutes
ok, this totally helped w/ mine, I have a 120 ultra and it made my remaining recording time to back to the original time, thanks a bunch YD CORP !!
Apr 08, 2010 | Pure Digital Flip Video Ultra Camcorder
Flip Ultra HD red light won't turn off after charging. Camera won't do anything at all. What do I do?
UNIT: ultraHD
PROBLEM:
I just had this problem: I turned it on, started to record a video, but it hung up on frame #1, with the record red light stuck on. And I couldn't do any of the following: restart the recording, play already recorded videos, turn it off, connect to PC.
SOLUTION:
I removed the battery for about 30 seconds, then replaced it. my UltraHD flip works great now.
Jan 26, 2010 | Pure Digital Flip Video Ultra Camcorder
My flip video won't turn off or record, won't be acknowledged by PC via USB port - seems to have frozen - screen is black but light behind it showing power is on but can't do anything with it.
To fix, I held the on/off button down for an extended time (around 10 secs approx) until it finally turned off. Left it alone for a few minutes and then turned back on. Worked okay. Also got a response from flipshare support who said there is a reset button inside the tripod space, use a pin to press that and then fully recharge camera via USB slot on PC.
Jan 12, 2010 | Pure Digital Flip Video Ultra Camcorder
Flip HD camera frozen "on"
Just take out the batteries and put them back in. That should fix your problem. =)
Dec 06, 2009 | Pure Digital Flip Video Ultra Camcorder
My flip mino wont turn off
Easy Fix bro,same thing happened to my mino when I let my friends fool around with it.
Soulution:See the tripod mount,theirs a little hole in it,and thats what your gonna use to fix it.Just get something small I recomend a paperclip,and bend it into an S shape.Put the point of it in that little hole,it triggers a restart for the camera,and boom!Its fixed.Worked for me.Proved by the Flip Company.
Hope this helps
Jan 14, 2009 | Pure Digital Flip Video Ultra Camcorder
Recording video and processing came up
The processing bar came up automatically for one of two reasons: You ran out of space for the video to save on your memory, or the SD card you are using writes too slow to record video after a certain length.
About it not turning on: The blinking light means the camera is processing (saving your video) and you will have to wait until it stop processing (the blinking light will turn off) in order to turn the camera back on.
Sep 21, 2008 | HP Photosmart R927 Digital Camera
Flip video problem
I have had this exact problem. The Flip Camera read "empty" however if I tried to record something by pressing the red button, the camera read "full." I started having this problem and kept on seeing fewer and fewer minutes available to record. Today, I was trying to shoot and then uploaded three videos. I could use the camera no more. So, I did as you suggested...plug the camera in to my Mac and then emptied the trashcan. It WORKED!! I got all sixt minutes back.
Jun 02, 2008 | Pure Digital Flip Video Camcorder
Pure Digital Flip Video Ultra Camcorder Logo
22,453 people viewed this question
Top Pure Digital Video Cameras Experts
Rommel Balcita
sharky633
sharky633
tomikles
Level 1 Expert
Are you a Pure Digital Video Camera Expert? Answer questions, earn points and help others
