Question about Kenmore Dryers
Kenmore Dryer only lights gas sporaticly
Appliance: Kenmore (Sears) Dryer
Model: 110.70602991
Note: Thank you in advance for any help with this issue.
Problem: In Permanent Press Cycle - Igniter Element will not glow and natural gas will not light at all, in Normal Cycle Igniter Element will glow then 3 loud clicks will be heard (sometimes) and natural gas supply will light for about 15-20 seconds but typically Igniter Element will glow NO loud clicks will be heard and natural gas supply will NOT light.
The only thing I don't know how to check is the very expensive Dryer Timer.
Item's I did clean and check:
- Cleaned Thermal Cut-off & Continuity (w/Ohm Meter) Good
- Cleaned Thermal Fuse & Continuity (w/Ohm Meter) Good
- Cleaned Holding/Boosting Gas Coil & Continuity (w/Ohm Meter) Good
- Cleaned Secondary Gas Coil & Continuity (w/Ohm Meter) Good
- Cleaned Igniter Element & Continuity (w/Ohm Meter) Good and functioning well
- Cleaned Radiant Sensor & Continuity (w/Ohm Meter) Good
- Cleaned Vents and Lint Trap
Note:
- No High Limit Thermostat Sensor on this model
  • 61 Answers
Replace the igniter. The ignitor is the most comon problem with gas appliances checking continuity does not tell you if it is bad or not it has to draw a certain amount of amps to open the gas safty valve and the is no safe way to check this on most gas dryers
Posted on Jan 19, 2009
Why won't it start?
Free Kenmore Clothes Dryer User Manuals ' ManualsOnline ...
laundry.manualsonline.com > ... > Laundry Appliance Kenmore
Products 1 - 50 of 65 - Kenmore ELITE HE3 Gas Dryer User's Guide 110.9787 9789. Pages: 0 ... Kenmore 27-Inch Wide Electric Dryer Owners Manual. Pages: 0 ...
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...? 7:29https://www.youtube.com/watch?v=SPRqKVE8JfYOct 21, 2011 - Uploaded by canyonman1963... and repair a Whirlpool or Kenmore electric dryer that will not start or run. ..... I have a Kenmore Elite Oasis ST Dryer, model number 110.78082701. During ... Dryer Troubleshooting - NotDrying or Taking a Long Time to Dry ...How to take apart Kenmore Elite Dryer - YouTube? 6:28https://www.youtube.com/watch?v=QNa6zfzrm5kOct 16, 2012 - Uploaded by RenewApplianceI have a kenmore elite 79661423410 electric dryer stoppedworking manual says has no thermal fuse and I can't take it apart help thank you.
Dec 12, 2015 | Kenmore HE5 Electric Dryer
I have a sears Kenmore 500 series gas dryer and I can't put a full load of laundry in or the drum won't turn
Either the belt, belt tensioner or the motor is defective. What is the model number? APPLIANCE 911
Nov 28, 2015 | Kenmore Dryers
Lights flashing E2F2 on kemore dishwasher
Appliances branded with the Kenmore logo and sold through Sears are produced by other major manufacturers.
So First: Using the Sears Model Prefix Chart, find out which manufacturer produced your appliance to find the right repair information. Locate the model number on your appliance and match up the first three digits before the decimal point of the model number to find the manufacturer.
Then search the appropriate manufacturer Fault codes to diagnose (and hopefully fix) the problem
.http://www.partselect.com/JustForFun/Fault-Codes.aspxwww.partselect.com/JustForFun/Sears-And-Kenmore-Appliance-Fault-Codes.aspx
Sears and Kenmore Appliance Fault Codes
Jan 29, 2015 | Kenmore 24 in. 17482 / 17484 / 17489...
Dryer will not start
might need a control broad if you know how to check it out ,if u still got the mannual that came with the dry it will have a troubleshooting page you can read it will help you out are calll a appliance repair man ok
Jun 10, 2017 | Kenmore Dryers
Gas dryer. won't heat. replaced ignitor sensor. still won't heat. seems that a valve is stuck closed (auto-valve), which is it? hold or ass't ?
The glow igniter should light up and after a delay the sensor will click and turn on the gas valve. If the gas doesn't flow and light the cycle will repeat.
Most likely you need a gas valve coil kit. The coils get weak and wont open the gas valve.
Nov 04, 2013 | Kenmore Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
My gas dryer stopped heating it is a Kenmore 70 series. I am getting good gas flow but dryer will not heat.
Try this link I hope it helps, I know it helped me a ton!! ps don't forget to rank my help. Thank you and have a nice day!
http://fixitnow.com/wp/2004/11/13/mailbag-how-to-troubleshoot-a-gas-dryer-with-no-heat/
May 07, 2009 | Whirlpool LGR3624JQ Gas Dryer
No heat
Sears Kenmore electric dryer model #110.96320100 will not get hot.
Nov 12, 2008 | Kenmore 63942 Dryer
Dryers Logo
166 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
