Question about Whirlpool Dehumidifiers
Whirlpool AD50GUSX 50-pint Dehumidifier
Owner's manual
  • 121 Answers
SOURCE: DeLonghi 50 Pint dehumidifier DE 500P won't turn back on
If it is not responding when you try to activate the shutoff button and are still not recieving an acknowledgement that the bucket is full you may hav a defective shutoff button. Try contacting the Manufacturer and see if you can purchase just the button. This i a common part and the price is usually reasonable. If you feel very technical inclined you can remove the button and touch the 2 wires together simulating a closed contact. The dehumidifier should now acknowledge the bucket is full. If you recieve the notification then the button is bad. If you found this solution helpful please rate it.
Thanks - Tech101
Posted on Jun 24, 2008
22yooper
  • 828 Answers
SOURCE: 2008 Frigidaire 50 pint Dehumidifier from Lowes
You can test it out by disconnecting the power cord, wait five minutes and plug it back in. If it retains the original settings you are good to go. If you are wondering before purchasing a new unit ask before you buy.
Posted on Jun 29, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: What is the proper humidity control % setting?
It is recommended that your settings stay at 35%. The ideal level of humidity in your house is anywhere between 30% to 60% depending on the weather outside.. I hope that this works for you. Have a good day
Posted on Feb 09, 2009
SOURCE: I need a manual for the Kenmore #54701
Here is a link for the manual. You can download it and save it or print it.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0406271.pdf
Hope this helps, it's from www.managemyhome.com
Maryanne
Posted on Jun 17, 2009
Dittoz
  • 3 Answers
SOURCE: my kenmore 50 pint dehumidifier 54501 runs but it
You need to determine what's "running". Here's why: There are three things that must be working to extract water. The 'coil' (a finned metal part that needs air to flow across its surface) may be filled with dust and obstructions, so no air can move...then no water. There is a blower motor that must move the air. If it is seized up and not blowing air...very little or no water. The compressor creates condensation from air moving across the coil (like the moisture than forms on an ice filled glass on a humid day) to extract the water from the air. If it's not working then no water.
So, if there is air blowing out of the dehumidifier the blower is working. If the air is room temp the compressor is not working. If it's real hot air, and the humidifier keeps cycling on and off quickly, the coil is dirty. Those are the 3 things that need to be working.
Posted on Jul 31, 2009
Winix wdh851 service manual
The owner's manual is here: http://www.sylvane.com/media/documents/products/winix-wdh851-dehumidifier-owners-manual.pdf
but that's probably not what you want. You might try posting your specific issue that you need the service manual for. For instance a fan that won't start is a common problem for dehumidifiers and a cheap fix. If that is your issue read this: http://www.fixya.com/support/t3588983-lg_lhd65ebl_serial_603taac20984
The article is for an LG dehumidifier but the thermistor mentioned is common to most brands.
Jul 13, 2014 | Winix 50 Pint Dehumidifier WDH851
How to set timer on 2014 Kenmore 50 pt Dehumidifier
if you hold mode button down does it not cycle thru timer settings?
May 24, 2014 | Kenmore 30-Pint EnergyStar Dehumidifier
Need owners manual
need owners manual for amana d950ep dehumidifier 50 pint cap with electronic controls with led service cant figure out what the settings should be
Apr 04, 2013 | Amana D950EP Dehumidifier
I have lost my instruction manual and cannot change te temperature and humidity settings. How do you do this?
Here is a link to an Owner's Manual for a Haier 45 pint dehumidifier. Not sure if yours exactly like it or not, as you didn't mention a model number. You can download and print the manual for future reference.
http://www.haieramerica.com/cool-heat-air-quality/dehumidifiers/45-pint-capacity-electronic-control-115-volt-dehumidifier-de45ek-7
Look for the download in the left hand lower left on the page.
Hope this helps and thanks for choosing FixYa.
Sep 11, 2011 | Haier 45-Pint Dehumidifier
Whirlpool DEHUMIDIFIER Model - AD70USS1 does fan NOT does not cycle off anymore in the low settings as it should
According to the Owner's Manual for your model, the fan will run continually, if the unit is set in continuous mode or if the unit is in defrost mode. Once the unit senses a rise in the humidity level, the compressor will start up again. Also, a dirty or clogged air filter will cause the fan to run more that it should.
Hope this helps you troubleshoot and solve the problem.
Jun 02, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
I just purchased a second-hand LG 45 pint dehumidifier. I need an owner's manual, free if possible........ Thanks
Jenifay, take good care of your dehumidifier and do all the routine maintenance that is recommended in the Owners Manual. As this model has been discontinued.
The following link will take you to LG's Knowledge Base. On the right of the page, you will see Dehumidifier Manual English. Click on that, and you can download and print the manual for a 45 pint LHD4SEL Dehumidifier.
Since I was able to get you a free manual, would you be kind enough to rate my response to you?
Thanks.
Apr 27, 2011 | LG Dehumidifiers
The bucket fills with water even though the humidifier is attached to a hose
Most of the units do not require the bucket to be in place, when the hose is attached. However, since you didn't list the Model Number of your unit, I can't be sure that's the case with yours. However, if you click on the following link, and enter the correct model number, you can download and print the Owners Manual for future reference.
http://whirlpool.com/custserv/index.jsp
Hope this helped you to sort it out.
Apr 21, 2011 | Whirlpool 75-Pint Dehumidifier
I need a manual for a 50 pint DeLonghi dehumidifier
delonghiusa.com has a manual for a DE500P this may be close enough to yours
Aug 28, 2009 | DeLonghi DE500 50 pint Dehumidifier...
Dehumidifiers Logo
87 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Mike Squire
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
