Retail Supplies Logo
A
Anonymous Posted on Jan 04, 2013
I need to change the tax rate on my samsung SER-6540 cash register
5 Related Answers
Anonymous
  • 55 Answers
  • Posted on Mar 19, 2009
SOURCE: I need to change the sales tax rate for my cash register.
Please find below the solution:
Non-printing models (also applies to HR-8TE printing calculator):
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Printing models (except HR-8TE):
1. Have calculator in "print" mode
2. Press [CA]
3. Hold [SET/%] key for about 3 seconds
5. Press [TAX+]
6. Press [SET/%]
stratovator
  • Posted on Aug 02, 2009
SOURCE: hi I need to change my registers tax rate
http://www.sharpusa.com/files/cas_man_XEA40S.pdf is the link from the previous answer to this problem. According to the manuals on line for cash (which was pretty reasonable at around 5-6$ the 40s and 41s use the same manuals.
hope this helps, Dave
Anonymous
  • 12 Answers
  • Posted on Aug 03, 2009
SOURCE: need to change tax rate in old model crs100 cash register?
Hello I cannot find your model but here is the complete list of how to program the tax rate from Casio business support.
http://www.casio4business.com/sa/support/taxtable_programming.html
Let me know if this helps.
Anonymous
  • 36 Answers
  • Posted on Aug 28, 2009
SOURCE: programming all department keys for tax
Page 34 item 2 "Tax Programming for Automatic Tax Calculation Function" in the manual. You can download the PDF version of the manual by clicking the link below:
SHARP ELECTRONIC CASH REGISTER MANUAL XE-A404
There you go... :) Please rate me for this answer.
Anonymous
  • 16 Answers
  • Posted on Apr 13, 2010
SOURCE: logo massage in SER 6540 Cash
Goto settins & coutmize the logo
How to remove cashier error on ser 6540 cash register please need your help
Check the manuals for information:
pg 136 has error msg definitions
the CLEAR key is used to clear error tones as well as clear text
https://www.manualslib.com/download/807139/Samsung-Ser-6500.html
How to change tax rate for Casio pcr 360
http://support.casio.com/en/manual/manualfile.php?cid=014003008
program mode, press number 3 key then press subtotal , press numbers 0125 press subtotal, press 3.00 press cash tender key, 5002 cash subtotal
example 3.%
1helpful
I have a Samsung SER-6540 II register. An error occurred that locked it up. I am not sure what the clerk did. I unplugged and turned the key to "P" and held down "Cash" key to clear. Now the register reads...
Ok. that's good. You have performed an initial reset that does not lose any data. You must log back on after an initial reset. <div>Find the button marked clerk, clk#, cashier, cash# or similar. This is your log on button. Now type a clerk code (default is 1) then press the cashier button.</div> <div><br /></div> <div>-------------------------------------------------------------------------</div> <div><br /></div> <div>If anyone needs a Samsung SER-6500II or SER-6540II manual, c-tech has them here:</div> <div><br /></div> <div><a href="http://the-checkout-tech.com/manuals/cashregisters/Samsung2.php">http://the-checkout-tech.com/manuals/cashregisters/Samsung2.php</a></div>
2answers
Im using samsung SER-6540 II, problem is register
I need more information. Does it open when you complete a sale and press the cash button? ---------------------------------------------------------------------------------------------------
If anyone needs a Samsung / Sam4s SER-6540II manual, go here: http://the-checkout-tech.com/manuals/cashregisters/samsung1.php
1helpful
11helpful
4answers
Samsung Register SER-6500/6540
Hi.
I don't have this error code in my notes at all. Is there a description of it in your manual? You may have a different software version in your machine.
Mark
10helpful
Need to change tax rate on a Casio tk-6000/6500 register
turn key to PGM
1 CLK# 3 SUBTOTAL 0125 SUBTOTAL 8.75 CASH 0 CASH 5002 CASH SUBTOTAL
turn key to REG1
8.75 is my tax enter your tax instead. make sure to put the decimal point.
Top Retail Supplies Experts
ADMIN Andrew
ADMIN Andrew
Ngoro
Are you a Retail Supply Expert? Answer questions, earn points and help others
