Question about HP DeskJet 1280 InkJet Printer
No power to my hp deskjet 1280. Tested power to the pc board - 220v present, after transformer 6v but the printer is still not turning on.
Cannot examine the pc board in front of printer - the ink carriage is blocking access because it is locked in position. Please advise if ink carriage can be manually moved?
SOURCE: printer deskjet 3650
saks
Posted on Jul 10, 2008
SOURCE: Cannot print A3 on HP 1280
go to custom then set your paper size 297x420mm
Posted on Aug 14, 2008
rakeshpramod
  • 234 Answers
SOURCE: HP C4180 Carriage Jam
Try the steps mentioned in the link Bellow:
Also make sure you should Unplug the power cord when there is
still power in the unit, take out both the ink cartridges and apply little more pressure and move the carriage too and fro untill you feel it is moving freely (Dont worry it wil not break)
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00806599&dlc=en&product=1141647
Good Luck
Posted on Sep 01, 2008
SOURCE: can i download the installer of HP Deskjet 1280
you can go to the hp.com website and download the drivers from there
Posted on Oct 27, 2008
  • 61 Answers
SOURCE: HP deskjet 1280 paper jam
Yes you can manually remove the paper. It can be pulled out from the feed area (pulled out backwards).
To clear the jam status....
Take the back cover off, there is a reset switch in the top left hand lock hole. Push a pen (or similar) into this hole, the switch will give slightly and be the same depth as the others.
put the cover back on, all should be well
Posted on Sep 11, 2009
Testimonial: "Thanks so much for your help - problem solved."
Our printer states printer jam but after examining it numerous times it does not have any paper stuck inside. What could be the problem?
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Dec 16, 2010 | Brother MFC 240C All-In-One InkJet Printer
Put new ink in printer. got the message "carriage jam" checked ink to see if correctly installed...it was. tried to use it again and same message appeared. Did as was instructed on Kodak...
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Dec 15, 2010 | Office Equipment & Supplies
Paper jam
Check the following steps for fixing Hp Carriage Jam Error :
Dec 07, 2010 | Office Equipment & Supplies
Printer carriage jam and then locks
Dec 07, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Errror e flashing. i cant see any paper jam or small object that affect the sensor.please help me
Nov 25, 2010 | Office Equipment & Supplies
I have paper jammed in my HP DESKJET PRINTER D2260. Tried to pull it out but paper ripped off and can still see other end still in there. Been advised to open back door and clear it but cant see how back...
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 18, 2010 | Office Equipment & Supplies
Paper Jam {Printer does not detect paper
One page paper jam on model 5650
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Nov 12, 2010 | Office Equipment & Supplies
Piece of paper stuck inside my HP printer
Oct 21, 2010 | Office Equipment & Supplies
False paper jam message
Check the following Steps to Fix Hp printer carriage jam :
  • Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
  • Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
  • Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
  • Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Sep 29, 2010 | Office Equipment & Supplies
HP DeskJet 1280 InkJet Printer Logo
130 people viewed this question
Seeker5211
Seeker5211
