It works.
I tried it on Philips Blue-Ray BDP 5200.
It works
Which solution(s) work(s) ? In which BDP 5200 version ? Does it unlock DVD region ? Blu-ray region ? both ?
The "138931+0" code works just fine on my BDP5200 to unlock DVD regions, but NOT for blu-ray regions. :-(
SOURCE: Philips DVD player dvp 3580 regional unlocking code
1. Press the Setup button on your remote control
2. Using your remote control, highlight but do not
select the Preferences menu
3. Press the 1 button on your remote control
4. Press the 3 button on your remote control
5. Press the 8 button on your remote control
6. Press the 9 button on your remote control
7. Press the 3 button on your remote control
8. Press the 1 button on your remote control
9. Using the Up and Down buttons on your remote
control select 1 for region 1, 2 for region 2, and so on, or
0 for multi-region playback
10. Press the OK button on your remote control
11. Press the Setup button on your remote control
SOURCE: unlock region code
Keep Tray in eject position
Press Setup from remot
Go to preference page
Press"138931"
Using Navigation Key chane region code to "0"
Press "OK"
OR
open tray
press 98790
SOURCE: philips dvdr 3320 v DVD Player Unlock region codes
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
SOURCE: Unlock region code for Philips DVP 3256
Region code hack for PHILIPS 3256 x/94
1. Go to Setup.
[from remote]
2. Select the Preference Page.
3. Press 1, 3, 8, 9, 3, 1 on the Philips DVD Player remote.
--> It will show current region code [ for example 5 ]
4. Now Press the up/down key to select "0" which makes it region free.
5. Press ok and exit setup.
Probably the same would be applicable for 3258, 3268, 3986.
Good Luck!
SOURCE: Philips DVP3960 uncolck code
region-free hack?
I used the following and it worked fine for me on a recent purchase of a Philips DVP3960
Power Up the unit with NO Disc in the tray.
Open the tray
Press the SETUP Button on the remote control
Navigate to the PREFERENCES page using the Right Arrow Key
Press the DOWN ARROW one time to select
The current Region Code Setting will display
Use the UP/DOWN Arrow Keys to select the region required or '0' for All Regions
Press the PLAY Button on the remote control
Good luck
