Question about Pioneer PDP-4350HD 43 in. Plasma Television
Can i use a Pioneer Plasma Model PDP-4300 without a remote?
The TV was giving to us and they can find the remote.
Can i use the TV without one until i order one from Pioneer?
5 Suggested Answers
HDTV GURU
  • 261 Answers
SOURCE: pioneer pdp-4300
It sounds like to me that either a capacitor blew up or the powersupply failed. Let me know the serial # and the other model # located on the back and i can assist you more. Possibly a driver IC on the ribbon cable going to the panel might have popped, which is about the size of a postage stamp and can be repaired fortunately, but it isn't cheap. If you do it wrong, the panel is ruined for good. If you do it correctly your set is fixed. Fortunately for you i know the boys over in O.T.S in Chicago which can assist me in helping you. Let me know if i can be of anymore help for you. I am located in Louisville, Ky. Thank you Jay
Posted on Jan 31, 2008
localwonder
  • 6784 Answers
SOURCE: where can I sell a pioneer pdp 5070pu plasma tv for parts?
HI, the best way to do this is to disassemble the set and post all the individual internal parts like the power board and main PCB logic and v boards, on line on a e-bay type of sale forum. this way, you can make more money. if you post the entire plasma screen with the crack as is, you will not get many hits. is will be assumed that it is damage goods.
Breaking this set down and, posting the internal circuitry piece by piece will make you more money in this case. The power supply board will sale for at least 289.00. and the main logic(PCB) will sale for 300 to 350. i would go this route to maximizes your gain.
Posted on May 20, 2009
SOURCE: I have a Pioneer pdp-433 plasma with a media
Alas, the powerblock has gone.
Common problem on this model.
Only solution is replacement powerblock.
Pioneer used to repair this for nothing even out of warranty (they did for me), but they may not be so willing now, as your tele must be at least 6 years old. Unfortunately, it will be cheaper to buy a new TV than to pay for a contractor to fix it.
Brian
Posted on Jul 27, 2009
tvservice306
  • 458 Answers
SOURCE: Pioneer PDP-RX06XE has no picture
check PDP 436XPE UNIT may be Y board short...or need factory restore to the original state....
Posted on Nov 18, 2009
  • 4 Answers
SOURCE: Will the Pioneer PDP-R03E Plasma TV Media box work
Yes it will
Posted on Jan 14, 2010
Pioneer PDP-4300 43" Plasma TV, 1/8 of screen has vertical stripes no picture
Look to see PIP or picture in picture is not engaged as it may be doing this.
Dec 10, 2012 | Pioneer PureVision PDP-4300 43 in. Plasma...
Tv won't come on...light in corner just blinks red
OK Its your power supply and it can be fixd for free due to a recall.
PLEASE READ BELOW what I found out.
Here's the whole notice:
Important: Free Power Supply Replacement for Certain Pioneer Plasmas
Pioneer is continuing to offer a free, in-home power supply replacement for certain of its second and third generation plasma models listed below for consumers who experience a problem with the original power supply. If a consumer model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded in your home at no charge.
Consumer Plasma Models (12 listed):
PDP-505HD
PDP-503PU
PDP-5030HD
PDP-5031HD
PDP-433PU
PDP-4300
PDP-4310
PDP-4330HD
PRO-800HD
PRO-800HDI
PRO-1000HD
PRO-1000HDI
The issue with the power supply in the plasmas listed above does not pose any health or safety risk. Pioneer has received reports that the power supply in the affected models may fail. In some cases, a loud popping sound can be heard when a power supply fails. After the power supply fails, the plasma is no longer operable.
We apologize for any inconvenience, and we thank you for your cooperation.
Apr 02, 2010 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Cannot program sky remote to operate volume control on pioneer pdp-4270xd pioneer plasma 42". have tried using code 0707 as this is the nearest I can find.
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0166
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Nov 28, 2008 | Pioneer PDP-4270XD 42 in. HD-Ready Plasma...
Can't turn on from Stanby mode
I would assume the power board has a problem. A tech could possibly repair it without replacing the whole board.
Nov 13, 2008 | Pioneer PDP-5070HD 50 in. Plasma...
Loud pop and tv went off...
Here is a solution from the Pioneer web site:
http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Updated+Information+Regarding+Free+Power+Supply+Replacement+for+Certain+Pioneer+Plasmas
Important: Updated Information Regarding Free Power Supply Replacement for Certain Pioneer Plasmas Pioneer is continuing to offer a free, in-home/office power supply replacement for certain of its second and third generation plasma models listed below for customers who experience a problem with the original power supply. If a model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded at your residence or office at no charge.
Plasma Models (15 listed):
  • PDP-505HD
  • PDP-503PU
  • PDP-5030HD
  • PDP-5031HD
  • PDP-433PU
  • PDP-4300
  • PDP-4310
  • PDP-4330HD
  • PRO-800HD
  • PRO-800HDI
  • PRO-1000HD
  • PRO-1000HDI
  • PDP-433CMX
  • PDP-502MX
  • PDP-503CMX
Anyone with questions can call Pioneer's toll free hotline at 800-421-1404.
We apologize for any inconvenience.
Aug 09, 2008 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Pioneer pro800hd plasma just made a loud pop and then went to black the power button(red led) is flashing. power supply??, flyback xformer??? any ideas. worth fixing??
The affected models of consumer plasmas are listed below. Anyone who owns or uses one of these models may contact Pioneer through its toll free hotline at 800-421-1404 to arrange for the free, in-home upgrade. If a consumer model is not listed below, no power supply replacement is needed and no further action needs to be taken. If consumers are not sure if their plasma is affected, they should call the toll free hotline for confirmation.
Consumer Plasma Models (13 listed): PDP-505HD PDP-4330HD PDP-503PU PDP-4300 PDP-5030HD PDP-4304 PDP-5031HD PDP-4310 PRO-1000HD PRO-800HD PRO-1000HDI PRO-800HDI PDP-433PU
Dec 30, 2007 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Pdp-4300
Try turning the power switch to off and unplugging the television, then plug it in and turn it back on. I have had this same problem and this seemed to work for me.
Sep 25, 2007 | Pioneer PureVision PDP-4300 43 in. Plasma...
43" plasma (Pioneer)
Plasma tv's are known for having overheating problems. Most of these problems occur in the main power supply. Most technicians only replace these boards due to manufacturers policy. If you are lucky, you may find a local technician that can troubleshoot to the component level. This will save you an huge amount of money.The board could cost as much as $800 dollars. Scrivitron
Jul 09, 2007 | Pioneer PDP-4350HD 43 in. Plasma...
Channel problem
what is the model of your TV exactly?
Jun 06, 2007 | Pioneer PureVision PDP-434CMX 43 in....
Pioneer PDP-4350HD 43 in. Plasma Television Logo
Top Pioneer Televison & Video Experts
Electro Med Services...
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
