Question about Kitchen Ranges
Cooker hood Lamona HJA2420 is not working no lights and no fan
Hood is not working - no fan - no lights working
  • darcie_newto
    darcie_newto Jan 21, 2013
    We're and how to change the cooker hood fuse
  • Stuart Yates
    Stuart Yates Dec 08, 2013
    Thanks Peterfitz, simple solution, changed fuse after one of the lights blowing had blown the fuse. Fuse and isolator behind the chimney casing could be better situated (like the hob under the work top) and my installer had got the flexible duct tight to the fuse position which made it difficult to get out. Anyway, cheap resolution to the problem.
SOURCE: a bulb blew in my tecnik cooker hood and neither
In case you are still looking for an answer. The same happened to me.
I found a 3-amp fuse which I changed, and now it's ok.
I removed the chimney casing and located the electrical connection into the wall. You'll find a fuse unit within the switch which swings out.
Hope this helps.
Posted on Dec 20, 2010
SOURCE: cooker hood not working
Check power from the wall.
Check power in the wiring coming into the hood.
Check to see wiring is not broken.
Posted on Feb 18, 2008
  • 1314 Answers
SOURCE: F60 SS Cooker hood
short in light switch
Posted on Dec 30, 2007
  • 171 Answers
SOURCE: internal cooker hood
Hi judav,
I'm Harvey the Master Plumber.
Your problem is: You live in a flat with no chimney and you would like to install a cooker hood. how do you do this please?
Is there living space above? If so you can't go straight up. If your range is on an outside wall, it can be piped out the back. If only attic or roof above, no problem. Just pipe it straight up useing B-vent pipe or equivlent. If you can't do any of this just get a hood that vents filtered air back into the room.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 14, 2008
manhandy
  • 146 Answers
SOURCE: Bulb blew on Whirlpool cooker hood and new ones fail.
well is there a switch you might want to check that out.
Posted on Jul 05, 2009
Hi! I've got lamona HJA2450 cooker hood which stopped working. I thought it might be fuse but light is still on. Do you think is motor?
Possibly - before going any further - you need to get to where you can access the motor and check to see if there is a (usually red) RESET switch (or button) on the motor. When it gets too hot, etc. it'll trip and the motor can reset. Pushing that button may fix your problem - all the best, Justin M. 17 South Industries
Apr 16, 2016 | Kitchen Ranges
Connection of mains flex into hood joint box
Hello Dave,
in the hood there are normally 3 wires in the connection box.
When it is in Europe, they are green/yellow for earth, blue for N and brown or black for L
N is the zero line, L is the power line.
Kind regards, Dik
Jan 23, 2018 | Kitchen Ranges
Can I wash the cooker hood carbon filter
No! The material is impregnated with minute carbon granules which will have absorbed all the grease and moisture coming from the cooker, like little pieces of coke (smokeless fuel!!). If the filter is a cartridge type, a search on Google for the model may help. Search under "cooker extractor spares". If it's a cloth type, there are numerous cheap shop choices for universal filter material that you just trim to fit.
Aug 22, 2014 | Kitchen Ranges
Fan on cooker hood does not work but light works
It it new? Maybe the fan connection in the connection panel come loose or was not done properly from factory. Turn off the breaker to the hood and inspect the wires and connections, if all is good, then maybe the switch needs replacing. Good Luck!
Jun 25, 2012 | Kuppersbusch Designer Island Canopy Cooker...
The lights have blown on my Lamona cooker hood, is there a fuse and how do I access it?
So has mine. At a loss as to what to do as fan not working either. Any joy yet???
Feb 22, 2011 | Microwave Ovens
The lights and the fan in our Tecnik electric range cooker hood have stopped working. I am not certain of the product number. It was bought 5 years ago and is stainless steeI. I suspect a blown fuse but...
Hello Jack728,
I never have found a fuse IN a cooker hood as long as I repair them.
My first impression would be a faulty connection to the grid, as both functions of the hood do not work.
I hope this helps, Kind regards, Dik
Feb 08, 2018 | Tecnik TKC1426 Electric Kitchen Range
Cooker hood
Look around on the hood and cooker for a small fuse. If you find one, replace it with one of the same type and rating.
Apr 16, 2009 | General Electric Stove/Oven/Range Chrome...
Elica oven hood fan not working
fan & light on elica extractor fan not working over cooker
Feb 25, 2009 | Kitchen Ranges
Cooker hood not working
Feb 18, 2008 | Kitchen Ranges
Kitchen Ranges Logo
3,069 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
