Question about Eclipse SIR-ECL1 SIRIUS Radio Receiver
Sirius/xm activation I just traded trucks (06 Dodge Ram for 07). The 06 had a Sirius radio, the 07 an XM. I've tried to activate the XM thru my existing account, but the tuner does not work in the Sat. mode. Everything works fine in AM/FM mode. I was told during the activation process to tune to channel 0 to find a code number, but the tuner will only display 184. Is this a radio problem or satellite reception?
Typical, they wont recognize sirius and xm on the same account. tyou need to close the old account and open a new account on the new brand head and start from square one. Also - they wont give multi head discounts if you have a mix of siruis branded heads and xm branded heads - each brand needs its own account and own e-mail address. They **** in this regard. Good luck, ive decided between this backwards book keeping and aneed to keep resetting my Sirius head periodicaly that neither is worth the aggrivation so I cancelled all of them.
Posted on Nov 09, 2011
    Problem Solver:
  • 18 Answers
Satellite reception problem
Posted on Sep 11, 2009
I have a 2014 dodge ram pickup with xm version of sirius xm. In northern canada xm signal is horrible bit sirius works flawlessly. Is there a upgrade to switch to sirius signal without adding a stand alone...
The 2012 Dodge Caliber had a Sirius radio instead of XM - BUT - you will have to check if it has a "FAST" or a "SLOW" "BUSS SPEED" - that is very important that the radio you replace it with has the correct buss speed. Sirius will only work a little while longer as they are eventually going to phase out their overhead satellites for a geostationary satellite like XM. XM has the better sound than Sirius - if you can receive them. If you can't find a factory replacement from 2012, then BestBuy still sells a Stratus Sirius radio - and you can probably even fish-out the antenna wire that you already have for use with the plug and play add-on Status. Good luck - let me know if you have more questions.
Jul 17, 2014 | Audio Players & Recorders
Sirius radio problems
I would do the following, hoping one of them works.
1) DISCONNECT the power to the radio and SiriusXM unit to "clear" it. Then reconnect and ask Sirius to resend signat.
2) Ask Sirius to UNSUBCRIBE that radio so it is deactivated. Then, have them reactivate and resend programing signal.
3) Be sure your car is outside under clear sky when Sirius sends the program signal.
4) It is possible the antenna cable to your unit is loose at the connections and/or damaged. A weaker signal may get your stations, but may prevent the additional Navigational signals. Have the antenna checked thoroughly and tested. If car is still under warranty, this should be a covered diagnostic/repair.
5) Finally, be sure the correct Radio Serial Number is being activated. If your radio works, that is one service. But maybe they are putting a wrong number by some chance into the system to fix this one? For example, you have TWO radios in TWO cars. Are they sending the turn on signal to the WRONG radio? Not as farfetched as you might think.
Jun 19, 2014 | Delphi Roady XT XM Radio Receiver
I purchased a 2008 g35 infiniti & would like to know how to activate or operate the xm radio. thx
Turn the radio on an locate the Radio ID
For XM Radios
Your Radio ID can be displayed by tuning your radio to channel 0. (That's one channel down from the XM Preview.) Make sure to check your ID code carefully. Please note that the following letters are not used: I,O, S, and F.
Call the activation hotline to activate your service
1-866-635-8634
Sep 20, 2011 | Sirius Sportster 5 Satellite Radio...
Why can't i get oprah on my sirius radio natalieromyn@shaw.ca
On Sirius radios, some programs require a subscription to the "Best of XM" and on some XM radios, you need a subscription to the "Best of Sirius" to get their programs. Call XM/Sirius and ask them, but I think that you have to pay extra for the "B.O.XM".
Jan 18, 2011 | Sirius Sportster 5 Satellite Radio...
Antenna interface - Sirius to XM, Dodge
connector should fit - provided that there is ONLY one connector for the SatRad and not two.
You might have to trim off some yellow, or pink or green plastic, but the metal connector should fit.
Jan 24, 2010 | Terk XM Commander Satellite Radio Receiver
Replace satellite system in 2007 saturn aura xr
If you are looking to convert your radio from XM to Sirius, there are a number of kits available by typing 'convert radio from XM to Sirius' into your favorite search engine. But why bother? XM and Sirius have merged and you can now get Sirius programming on the XM band.
Mar 01, 2009 | 2007 Saturn Aura XR Sedan
XM Radio online use problem
Yeah use sirius radio service. Prolly a reason that it isn't running it anymore because Xm and Sirius merged company's. So Sirius is the same as Xm now.
Jan 09, 2009 | Audio Players & Recorders
Bluetooth XM not meshing
does xm adapter have a pass thru port on it as in mine is sirius and i have radio changer output pluged up to the sirius unit then from sir changer output i have the bt100 plugged up and mine works great
Jan 06, 2009 | Kenwood KCA-BT100 Wireless Headset
Acura TL XM conversion to Sirius
You can get a Windshield Mounting kit and Sirius Unit and use the FM Frequency Modualator that is Built in and just not use the XM.
Nov 25, 2008 | Sirius Satellite Radio Receiver
Sirius Radio Invalid Channel message
1) Do you have a Sirius account?
2) Have you called Sirius and given the serial number of that receiver?
Those are the first two things you have to do to get a Sirius receiver working. (The original owner could have changed his account to use his new receiver, if he has one.) Go to http://www.sirius.com/install - the "activate" part - for details.
Aug 20, 2008 | Clarion (NAVSIR) SIRIUS Radio Receiver
Eclipse SIR-ECL1 SIRIUS Radio Receiver Logo
634 people viewed this question
Top Eclipse Audio Players & Recorders Experts
Oloyede Monsuru
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
