Question about Sportcraft Exercise & Fitness
Treadmill Protec Forerunner 3000 E 7 light on (mother control board FH-3545C-E, VER:B2)
    Top Expert:
  • Sportcraft Master
  • 12,223 Answers
Step 1:
you will have two alternatives:
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
see the block diagram+additional diagrams for troubleshooting and fix it.
God bless you
Step 2:
Treadmill Protec Forerunner 3000 E 7 light on (mot - 1_4_2013_6_15_26_pm.jpgelevation motor diagram
Step 3:
treadmill motor control board diagram
1_4_2013Treadmill Protec Forerunner 3000 E 7 light on (mot - 1_4_2013_6_16_30_pm.gif1_4_2013_6_16_30_pm.gif
Posted on Jan 04, 2013
  •  Raymond
    Raymond Jan 05, 2013
    Thank you for posting. My treadmill has different control board (FH.3545C-E), are u sure E 7 means elevation issues? The treadmill is "dead" ant there is no dip switch on the elevation motor. Do you have access to what error codes means for my particular brand/control board. I`ve seen that the codes is not standarized.
VISIO E550i-B2
The main board of the tv is faulty. Can be a hardware fault or software error. You have to replace the mother board or can consult the service center.
of you wish to get some details about television repair then check the following link
http://electro-medical.blogspot.com/
Aug 18, 2016 | Televison & Video
Need to order a control board
I am not sure they carry these boards but most certainly worth a call is Allied Electronics. If they don't have one I know they will steer you the right direction.
May 14, 2014 | Sportcraft Tx350 Treadmill Motor Speed...
Motor Control Board
go to www. fitnessrepairsparts.com and get it.
God bless you
Jun 11, 2013 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
Treadmill speed varies with or w/o load. Belt not loose. Led speed indicator constant.
0ed98914-d0ff-4c07-aa5a-486eca10f03f.gif1) adjust the speed sensor see the diagram, clean the sensor very well, tight the connector very well.
2) LUBE the deck belt with silicone or wax READ your owner manual,
God bless you
Jun 03, 2013 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
Tx 5.o rc sportcraft treadmill varies in speed with or w/o load.
1) adjust the speed sensor, see the diagram attached, test for open or faulty. clean it very well. tight the connector very well
2) LUBE the treadmills very important . do it with silicone or wax. Read your onwer manual for verification.
Treadmill will not start
Step 1:
please see the video and proceed according. God bless you
Step 2:
if the problem persist:
use the table lamp connect in the circuit of the treadmill, if the lamp does not go on, the problem is the outlet wall home. Reset the c. breaker and test again.
Open the outlet and tight the white+black+green wires. REPAIR IF THERE are something faulty. Use the Voltmeter.
TEST AGAIN.
Step 3:
if the problem persist see the block diagram attached.
a) test the main motor see my personal TIPS for motor help.
b) test the main board for faulty.
Jan 04, 2013 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
Fix E3 error message
see your troubleshooting section in your instr. manual and enter the keys for clear the error.
However you must test:
a) test the input voltage motor, if there are the motor need repair.
b) test the output voltage board, for input voltage motor, if there are NOT the board is faulty., see the block diagram+ w.diagram
Nov 26, 2012 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
Sport trac treadmill shuts off after a few seconds
1) LUBE the deck belt, this produce enough friction, by lack of LUBE
2) Lube the roller bearing, very well
3) Test the input voltage motor, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
See the block diagram. God bless you
May 27, 2012 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
Exercise & Fitness Logo
883 people viewed this question
Top Sportcraft Exercise & Fitness Experts
John
Are you a Sportcraft Exercise and Fitnes Expert? Answer questions, earn points and help others
