Question about GE Microwave Ovens
Need to find replacement microwave for GE JE1540GW002. What microwaves are comparable?
SOURCE: GE MICROWAVE FUSE REPLACEMENT
i have a galanz microwave i need to replace the fuse and i dont know wht to buy
Posted on Feb 08, 2008
MATRIX_MMX
  • 209 Answers
Dear Carluc
Right for this one, it is essential that you unplug the oven from the mains and leave it to dissipate any electrical current certainly for 6 hours. Once you have done this, you wil to get yourself a phillips head 6mm screwdiver and unfasten the screws on the back that hold the casing cover to the chassis. This will expose the enternal components, then all you simply need to do, is find the lightbulb, unclip this from the holder and then replace it with one of the same make and model. Fitting and re-assembly is as straightforward as it is taking the unit to bits.
go to http://www.google.com and type in GE Microwave lightbulb........this will get you the details about the bulb, and use the same google search to get your service sheet/ disassembly guide. Easy as 1,2,3.
Hope this works for you and please contact me here if you need further assistance in this or any other matter that is of a technical nature.
Yours sincerely
Oz
Posted on Apr 11, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
SOURCE: Need replacement microwave to fit existing trim kit
Finally built up the courage to call GE Appliance number and weave my way through the phone menu system. Pressed the right menu option (sales) to speak to someone about trim kits. Found out that the trim kit model number is JX1527MWW. Then called back to select a different menu option (other) and learned from someone else that since the trim kit model is more than 1-2 years old, there's a slim-to-none chance any new microwave models will work with it, and even if there was they couldn't easily cross-reference against a model that old to tell me which one (or something to that effect). So I hit a dead end. Only option for me at this point is to buy a new microwave with new trim kit.
(Personal note: I think the trim kit business is a racket, in bed with the microwave manufacturers. Why else would there be no standard dimensions for microwaves by now--like refrigerators have--and why is it a few pieces of sheet metal cost over $150? Pretty convenient that every microwave model needs its own trim kit model!)
Posted on Nov 22, 2008
SOURCE: Microwave interior light
Very easy to replace...at least on my JVM1790. Remove the top vent....the long plastic thing that runs along the top of the MW. Two screws on top of the micro. Behind the charcola filter (if you installed one) is an access area to the bulb. remove one screw and the entire assy comes out. Simply R & R the bulb.
Posted on Apr 02, 2009
I need to replace my ge microwave zmc1095. what is a comparable microwave?
You can call GE customer service to see if they have "drop-in" replacement.
Otherwise, you can refer to your owner's manual for the specifications to compare to new ones.
Jan 15, 2013 | GE JVM1790SK Convection/Microwave Oven
GE countertop microwave shows "F3" on display, won't work
F3 on a GE means you have a shorted membrane keypad.
There are two ways to fix this model, either replace the membrane keypad which is a lot of work (handy guide with pictures) or to replace the complete controller.
It's probably not going to be economical even to repair it yourself if you or a friend want to. It depends on the model:
JES1334WD001
JES1334WD01
JES1334WD02
JES1334WD03
JES1334WD04
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
I looked up parts prices for the -02 verison.
ref # 38 part number WB27X10554 membrane keypad $69.71 here (compared to $112.50 direct from GE!)
ref # 42 part number WB07X11076 complete controller assembly $131.01 here (compared to $196.25 direct from GE!)
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jun 02, 2010 | GE Microwave Ovens
I have a GE Profile Spacemaker Microwave Touch Pad does not work
Sadly, GE does not make individual parts available for these controllers, so they cannot be repaired.
You have to replace the control panel sub-assembly (part number WB07X10733 in your case) and the best price I've found on that is $370.32 here (compared to $483.25 direct from GE).
In my opinion, this does not do much to inspire brand loyalty...
Or you may be able to find a whole oven on eBay for about that or less.
Sorry to bear bad news. Good luck.
May 27, 2010 | GE Profile Spacemaker Over-the-Range...
Need a replacement glass plate for GE JVM1640CJ01
The part number for a replacement glass tray for your microwave oven is WB49X10114.
You can purchase a replacement at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you with locating and properly identifying the parts you need.
If you have any questions, please post back and let me know. I hope this helps you.
May 17, 2010 | GE JVM1640 Microwave Oven
We have a GE microwave model # JE 18600 SB 001 installed with a trim kit that stopped working. Can it be replaced with GE model # JEB 1860 SMSS?
You can download GE owner's manuals and installation instructions here. You can download for both models and compare the two.
Or you can ask GE Customer Support. Contact info is here.
But your oven may be pretty simple to fix yourself or with help from a friend.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit and symptoms) for free DIY help and information.
prototech@usa.net
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave shut off
try to checked the fuse if its blown.and replace a new one,check also the power cord.
Jul 05, 2009 | General Electric Microwave Oven
Compatible replacement
GE Customer Service is here. They can tell you if they have a comparable "drop-in" replacement.
You can usually find helpful exploded view diagrams and order parts & accessories by entering your full model number here.
Nov 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
The top vent broke
I called GE and got a new model since the JVM 1860 is discontinued.
Sep 13, 2008 | GE JVM1860 Microwave Oven
Ge spacemaker JVM140H001
Are you sure yours might be economical to repair? What's wrong with it?
Please write back with more details if you need further help.
GE Customer Service should be able to take your current model and recommend comparable replacements. Contact them here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
New Microwave
Well one would presume you could simply measure the bracket and the microwave, and ask a retailer for the dimensions of units with similar dimensions.
They may also have this bracket and be able to compare the sizes before purchasing your new one.
Not knowing the dimensions of either the bracket itself or the microwave, this would be the only solution i can think of.
Jan 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
198 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
