Question about Dishwashers
My dishwasher won't turn on. It has done this once before. The tech came and fixed it. There is no connection. Thanks
  • 21 Answers
On newer homes it is a requirement that a disconnecting means be provided for dishwashers. This disconnecting means is usually a GFCI outlet located under the sink. Look for this outlet, make sure the plug is in all the way, and make sure that the GFCI is not tripped.
Posted on Jan 19, 2009
My Samsung Dishwasher, model DMR78AH5 will not run. The heavy, delicate, quick and smart lights are permanently on. I cut off the breaker for one minute but that did nothing.
How to Fix a Dishwasher That Won't Start ' Dishwasher Repair
www.partselect.com/Repair/Dishwasher/Will-Not-Start/
If your dishwasher won't start the problem could be the door latch or door latch ... On manual timer models the timer is used to supply power to the pump motor, ...Missing: samsung ‎dmr78ah5
Samsung Dishwasher Won't Start - Model DMR57LFS ...
www.repairclinic.com/...Dishwasher/...-/Samsung-Dishwasher-won-t-start...
The door latch ensures that the dishwasher door latches shut. If the door does notlatch properly, the door switch might prevent the dishwasher from running.
What to Do When the Dishwasher Won't Start - YouTube
? 5:43
https://www.youtube.com/watch?v=L-bMqVb9kX0
Aug 15, 2013 - Uploaded by doityourselfstan
The problem could simply be a blown thermal fuse inside the control panel. ... Maytag Dishwasher Repair ...
Dec 16, 2015 | Samsung Dishwashers
My dishwasher has no power so it won't turn on and I need help fixing it to get power back. Anyone know how? PLEASE HELP
First check the power at connection, bottom right, if you have power here, check the fuse
Mar 29, 2013 | Dishwashers
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
Leaking at the bottom of the door and unsure where plastic door seal goes.
This dishwasher will leak if there is to much water in the unit.
I have the same dishwasher with a different problem.
Mine won't circulate the water. I have not use it for a while and some water will back feed from the sink and fill the dishwasher, so if I don't check for that problem once in a while I see it start to leak.
It never has done that when the unit was working....
Aug 28, 2011 | Jenn-Air 24 in. JDB1100AWS Built-in...
Hi we have a Kenmore Dishwasher Model # 13744K and it won't turn on. It has water in the bottom that won't drain. Please advise. Thanks. John Webster.
For a dishwasher that was rated pretty high by Consumer Reports, it does not clean very well. In addition, the plastic control button cracked in less than a year and I must constantly clean around the inside of the door ... and I never received my rebate.
Despite those issues, it has been a workhorse. My wife is a daycare provider and the machine is used twice a day (on average) and still runs well. On a monthly basis, I alternate a pint of lemon juice and a pint of vinegar to keep it clean and once per year I use a granulated dishwasher cleaner.
Aug 14, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
We had a short in the wiring where the dishwasher plugs into the wall. After fixing the wiring, the dishwasher now has a message "OE" when I turn it on.
Hi
Thanks for using FixYa. Error OE in your LG dishwasher is a drain error, which is displayed when the unit won’t drain out in spite of 5 minutes drain operation. To resolve this issue you’ll need to check the drain hose for any blockages, also check the wiring connection to the pump. If still the issue is not resolved then you’ll have to replace the drain pump/motor. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 14, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Trying to have machine do a diagnostic on it's self for help
THE TECH SHEET SHOULD BE ON THE MACHINE.EITHER BEHIND TO TOE PANNEL OR THE DOOR PANEL.MAKE SURE IT GOES BACK THERE WHEN YOUR DONE.!
Jan 16, 2010 | Dishwashers
Dishlex global 300
try holding the start and program buttons simultaneously for a few seconds, it seemed to reset itself for me-i have done this a few times now.
Feb 04, 2008 | Dishwashers
No hot water in dishwasher
there is a heater in the base of the dishwasher . It could be this is faulty as you can still use the machine .
It does'nt matter that you have connected it to the cold water tap the machie should heat up the water it self.this is'nt a job you can do your self so you will have to call out an engineer sorry
Dec 11, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Kenmore mdl 665.16034401 dishwasher
looking at your control panel there should be a option/clear button. push that button then the button to the right of that button back and forth untill all lights light up. that will start a test mode just let the test mode run once its done you should be able to run the dishwasher again
Nov 21, 2007 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
96 people viewed this question
Top Dishwashers Experts
