Question about JVC AV-27530 27" TV
JVC TV Blue screen No remote
I was given a nice JVC TV (tube) with no remote. It does not receive a signal from the cable. The cable and DVR have been proved working. I get only a blue screen. Paging through the menu has given me no answers.
    Top Expert:
  • JVC Master
  • 74,136 Answers
To select the source you must have its remote control. There is no TV/AV source select button at the front panel of this TV.
Posted on Jan 05, 2013
3 Suggested Answers
gopakumarg43
  • 74136 Answers
SOURCE: i have a 32" tv jvc iart and horizontal white
Hello
You are seeing vertical retrace lines. This faut is due to the vertical output section inside your TV. To rectify this fault, you must open your Tv. Just open it after unpluging it from the wall power socket. Locate the vertical output section on the printed circuit board.
It is easy to locate. You can see four wires goes from the deflection yoke; the coil fitted around the neck of the picture tube. Out of which two of them will be thick, usually red and blue coloured, and the other two will be thin. These two thin wires are for vertcal scanning. Just follow these two thin wires, and you will reach a point where these four wires are pluged onto the main circuit board, very near to the LOT. Upside down the printed circuit board, and follow the print of that two thin wires, and you will reach to the vertical output section of your Tv.
Before doing anything, just look for any loose soldering or bad solderings there. It is very difficult to find out loose solderings, as thay will be microscopic, I advice you to resolder most of the soldering points there by applying a little more solder; without making any solder short. Resolder all the pins of the vertical output IC, and see the effect.
If this does not help, replace the two or three electrolytic capacitors, at about 1000MF to 2200MFD there, with same capacity and voltage ratings. Make sure about their polarity, as electrolytic capacitors have both positive and negative terminals like torch cells. Note the polarity when resoldering them out of the board. This must solve ypur problem.
If you need anymore asistance, feel free to contact me through Fixya. OK
Wish you sucess.
Posted on Dec 11, 2010
  • 1751 Answers
SOURCE: I have an old JVC Master Command II TV. We tried
hi
you need to get the original remote
only with that you can do it at this model
Posted on Jan 13, 2011
My tv jvc av 27530 has ablue screen and un able to operate by remote or manually so could you help me please?
many of the late model tvs with a crt (picture tube) would go to a blue screen when there is not signal from the cable or antenna so you don't get the irritating white noise and black and white dots running all over the screen, (called the raster), so probably you aren't getting a signal to the tuner. check your connection from the cable/antenna.
Sep 25, 2014 | JVC AV-27530 27" TV
I have a JVC tv with a Comcast DVR. Remote provided will not work on DVR.
did you take a look at the manual you should have recvd for your comcast remote control, You need to program your DVR, look in the manual for the 4 digit code and follow the instructions- usually- hold the dvr button on the remote down until it stops blinking- enter the code- (depending on who the manufact is) wait for the button to start then stop blinking, see if that helps
Feb 07, 2012 | JVC Televison & Video
How to get sound to tv from JVC TH-M606 without sub woofer.Also trying to put in progressive mode without remote
  • If I understand your question correctly you want to listen your TV on your Stereo system thru your receiver,JVC TH-M606 ** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
JVC TH-M606 RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the
JVC TH-M606 Receiver..By this means whatever you watch on the TV (tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
  • If you want to listen your receiver thru your TV, sorry but it is not a preferable attempt since TV sound system is not a HI-FI quality compare to your nice Receiver..if you really want to do it,try to do the connections given above in reverse..
  • And,best of my knowledge I am afraid you can not put in progressive mode without remote
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Jun 24, 2011 | JVC TH-M606 System
Unhooked all lines in back of tv cant remember to rehook up have2
granmabj,
There are common connections to each receiver but there are unique connections also depending on the receiver. Solo receivers have a coax cable coming from the Dish outside connected to Satellite In. Duo receivers and DVR HD receivers have the coax cable that comes from the dish outside that connects to Satellite 1 and Satellite 2 using a splitter. There is also a cable (coax, RCA (yellow, white, red) or component (green, blue, red - video, white, red - audio) or an HDMI if HD) connected from the receiver to the TV 1. For a duo receiver TV 2 may be backfed on the cable coming from the dish outside using diplexers. This may sound confusing but you can call 1-800-333-3474 for assistance.
Ray Calo
DISH Network
Jul 23, 2010 | DISH Network DVR-625 DTV Receiver /...
Hi Have Vizio Flat Screen and a Denon 3803 receiver. The Tv a Vizio 65 Inch flat screen was here. Out of the wall is a power cord and red,blue,green monster cable. Red and Blue is audio and green video I...
Red, Green and Blue cables together typically denotes a component video signal - an Analog, High Definition transportation for video. This cable does not carry audio, you need another cable to hook up audio between the DVR and receiver. You can use either an RCA stereo cable (red and white), optical-audio, HDMI, or a whole plethora of other audio cables. I would recommend optical or HDMI to get the most out of your system.
Jul 16, 2010 | Denon AVR-3803 Receiver
Dvr stuck on ''receiving satellite info'' when reset.
When it's rebooting, on the first blue screen press 02468 on the remote. This will force a software update. If you have trouble getting it enter at the right time or you just want to make sure, just keep pressing 02468 until it goes to the update. It won't hurt any thing. Hope this helps.
Mar 18, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
The screen shows ''Weak Signal'' and no picture, even though audio is coming through from both the Cable DVR box and Blue-Ray player. The cable box connects to the TV with an HMI cable - all five TV inputs...
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
Dec 29, 2008 | JVC LT42P789 42 in. LCD TV
No signal on TV2 with dishvip622.
If the blue light on the receiver is on then your tv is most likely on the wrong channel after checking cabeling i would do a reset on receiver first wait for it to come back on, then run a channel scan on your tv2 you can do this with orignal tv remote under the menu options. its also refered to as a auto search or auto program.
Nov 30, 2008 | DISH Network ViP622 DVR DTV Receiver /...
Getting no audio to game systems, pc connect won't connect
I also had the same problem when using my optical output for DBS and DIGITAL DVR/DVD.. you need to change the setting for this by on the remote changing to either analouge..rca sound input or Digital...for Optical input. The same problem cuaght me oput for a long time as well. The button is when you slide down the remote cover and the button is called analoug /digital
Dec 30, 2007 | JVC RX-D301S Receiver
JVC AV-27530 27" TV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
