Question about Magic Chef Freezer. 8.8 cu. ft. Upright Freezer in White MCUF88W
I have a Magic Chef upright freezer. The compressor comes on and makes a gurgling sound on the inside. I heard this means that it has freon, but it still won't get cold. Is there anything I can do
There is a plastic box that is attached to a metal bracket that attaches to the compressor tank. when I checked it , it wasn't secure to the metal bracket and the contents are exposed. I don't know if there is supposed to be a cover or not, but there is a round plastic thing with a chrome looking ring around it. The round black thing looks like a small horn and has a black and purple wire attached to it. It also has a prong on it that is not attached to anything.
3 Suggested Answers
  • 2468 Answers
SOURCE: magic chef portable freezer not cooling.
first of all are you sure its running correctly,if its overly hot to the touch is may sound like its running which it may be,but only on the start/run windings and if left this way it will burn out soon,it needs start/run windings to oppose the pressures inside the compressor to get it up to correct operating speeds,then the start winding cuts out of the circuit,this is where the ptc overload comes into play,as it does this sequence switching to make it operate correctly,just unplug it from the compressor and plug in a new one,also you may think you hear the compressor running,but its only the fans in the unit running,a compressor will run warm but shouldn't be overly hot to the touch,then if this isn't your problem,it could be an evaporator core blocked by ice and you cant get cold thru a solid block of ice so iuf its a self defrost model the defrost thermostat or defrost heater might be inopertive too
Posted on Dec 26, 2010
  • 7 Answers
SOURCE: MAGIC CHEF FREEZER THE DOOR IS NOT OPENING FOR 8.8
If You run Your finger in between the rubber seal that is resting on the freezer and the frame of the door , the rubber seal will break lose. When you open the door the seal is attache to the door.
Just had the same problem after unboxing.
Simple, just be sure to do the entire door.
Posted on Jan 29, 2011
Should green "compressor on" light always be on?
read the user manual
the light may only come on when the compressor is working
talk with a service agent for the unit and ask them
Dec 29, 2016 | Magic Chef Freezers
Chest freezer not working. Light inside chest freezer comes on but green power light doesn't turn on and freezer makes no sound. What could be the problem.
Could be your thermostat is bad and not calling for the compressor to come on. If you are able see if there is power getting to the compressor. If not then back track to where you are loosing power (thermostat) etc.
Nov 04, 2014 | Magic Chef Chest Freezer MCCF5WBX
Magic chef freezer model mcuf88w won't freeze
When you thawed it, did you remove ice from it using a metal object. That may have damaged the coils when would allow freon to leak out. This is too coincidental to be a problem itself with the compressor. The t'stat might be the problem. Try turning it off at the t'stat for a few minutes, then turn back on to the normal setting. Keep door closed for 30 minutes and check the inside and see if the walls are freezing. If not, you may have a compressor problem, or t'stat, or relay switch problem.
Feb 04, 2013 | Magic Chef Freezer. 8.8 cu. ft. Upright...
I have a Magic chef upright freezer i can hear the compresser running but it will not freeze meat
Has this happened suddenly? Look at the shelves to see if there is a frost line. If the shelves that also carry the Freon appear to have a frost line your freezer may have a Freon leak. If there is a Freon leak it will be better to begin looking for a replacement freezer. Let me know what you see, Thanks Sea Breeze
Nov 29, 2012 | Magic Chef 11.8 cu. ft. / 334 liter...
Magic chef portable freezer not cooling. compressor running
Dec 26, 2010 | Magic Chef Chest Freezer MCCF5WBX
"High wind" sound following defrost.
Freon running through the feon lines can make some odd noises, usually a gurgling or higher pitched noise. If your freezer works fine with no more strange noises, then don't worry about it. If you have temperature problems or continue to have abnormal noises, then see if your freezer has the 5 year sealed system warrantee that most freezers have. If it does, and it is under 5 years, then call Frigidaire to come out to check it out for free. If it is out of warrantee you will need to live with it or replace the freezer, since a freon sealed system repair is very high. Good Luck, Appliance Specialists
Feb 04, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Powers on, but doesn not freeze. There is no noise coming from the freezer.
Try this, unplug the unit for about 5 minutes. This will give the compressor time to cool. Plug it back in and listen to the compressor. See how long it takes for it kick on. When it does is there a click sound, shudder, or is it quiet. Touch the compressor, is it hot. Be careful when you do this as it might be very hot. There could be a chance that the freon has leaked out. Check to make sure there is no dust, lint, debris blocking the filter / vents. Vacuum as needed, it has to breathe. When the compressor kicks on and if it gets hot there is a chance it is bad. The repair for this is expensive and another solution might be to check out craigslist as you can find some great deals. Hope this helps.
JimmyC
Sep 27, 2009 | Magic Chef Chest Freezer MCCF5WBX
Chest freezer repair
I had the same problem with an upright and so I bought a piercing valve and charged the compressor with 134R and has been working great since.
Jul 05, 2009 | Freezers
Upright freezer stopped working
That clicking sound is your compressor tightening up(clixon switching on and off.). Pull the freezer out and feel the compressor. If very hot and not running, there is your problem.
Jan 29, 2009 | Freezers
Magic Chef Freezer. 8.8 cu. ft. Upright Freezer in White MCUF88W Logo
66 people viewed this question
Top Magic Chef Freezers Experts
Dan Webster
Dan Webster
AJMAL KHAN
Tom Chichester
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
