Question about Dell Inspiron 1501 Notebook
Often when i turn on dell inspiron the screen stays black
I hear the start up tune and things seem to be working but the screen shows absolutely nothing. If i turn off at the mains it will often work again (about 50% of the time) Is the hard drive broken? The lap top is 10 months old and works well otherwise.
    Genius:
  • Dell Master
  • 1,102 Answers
When the screen is black does it all shutdown
Posted on Jan 19, 2009
  • 32 Answers
When problems such as this occur it is important to backup all your critical data to a network, online service, external drive or USB drive.
From the limited information provided your problem could be a hardware or software cause.
If you have not as yet called the Dell Support line, do so now. After they take you through a lengthy list of their problem-solution process they may provide you with an RMA which will let you return the unit to them to repair or replace your unit. Consider yourself lucky that the problem occurred while still under warranty.
My dell inspiron 2400 won`t come on .it does not show anything on screen.
You first need to check the screen is working, disconnect the VGA/DVI cable from the monitor, then turn it on do you get anything on screen at all?
If that works reconnect the cable and turn it on, now boot the PC, do you see anything at all on the monitor?
No then check the cable/swop with new one or check the graphics card.
Yes but goes off after a few seconds, reboot and press the F8 key as soon as you hear the first beep, this should bring up a start menu, try safe mode, if that works load and windows it might be the graphics driver (has this been updated?) if yes try roll back to previous driver or you could even try system restore back to a date you know it all worked.
May 19, 2014 | Dell Inspiron 530s Desktop Computer
Are soyo monitors compatable with dell computers?
try running it in safe mode tap f5 when you see the dell screen. if it boots to safe mode remove the driver for the display adapter in device manager. the dell computer doesn't know what kind of monitor it's plug into. install the soyo monitor driver
Jun 13, 2017 | Computers & Internet
When I turn on my dell inspiron 1526 the screen stays black, you can hear the fan start, but it does not boot up
Try plugging a monitor into the VGA port on the back. If that works, then it's your LCD screen. If it doesn't then it's most likely your video card or your motherboard.
Aug 19, 2010 | Dell Inspiron 6000 Notebook
Dell inspiron 2650 frozen on blue welcome page
try this...
turn on the laptop,,,
keep pressing F8
a menu screen will appear,, select SAFE MODE using the cursor keys and hit enter,,
once it boots in safe mode click no to use system restore..
follow the onscreen instructions to send it back to a date when it did work,,
it will shut it self down and restart in a propper manner..
if that fails,,
when u turn on the laptop it displays a menu,, it shows to press a certin key to enter system recovery,, press that key,,
follow the onscreen instructions to restor the laptop to factory condition..
Jun 03, 2010 | Dell Inspiron 2650 Notebook
Possible water or hard drive damage to Dell Inspiron 1000 Laptop
its fryed the GPU, sorry it won't work anymore, unless a miracle happens. If it was off and you left it off until it completely dried out (6-7 days) it would of still worked.
Sep 27, 2009 | Dell Inspiron 1000 Notebook
Dell 1525 laptop keeps freezing
i am suspesioning on Rams. maybe overheating also does that.
May 30, 2009 | Dell Inspiron 1525 Laptop Jet Black
Inspiron e 1505 does not turn' on
It could be a couple of things, but it seems most likely that it is the RAM Memory that is causing this.  You might need to add more.  I have seen this before with one of my customers, we upgraded his ram from 1.5 to 2 gbs, and his games/windows no longer crashed
May 08, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron 6400 PC Notebook shows black screen after startup
I have a Inspiron 530 when I turn on it you can see that everything start ok but before I type my password everyting turn black an the only you can see is the litlle white arrow of the computer mouse
Jan 01, 2009 | Dell Inspiron 6400 Notebook
Screen will not stay on
The first thing to check is the LCD or Screen inverter. It is a small board that at the bottom of screen. You have to open up the plastic part of the screen or LCD. Usually this part goes bad.
I am sending you a link of a sample from ebay,
http://cgi.ebay.com/NEW-DELL-Inspiron-1300-B120-B130-LCD-INVERTER-CARD_W0QQitemZ170147223708QQcmdZViewItem
I hope that can help you.
Feb 28, 2008 | Dell Inspiron B130 Notebook
Dell inspiron 1150 laptop black screen
Can you hear the Windows startup noises but can't hear it?
Does it work plugged into an external monitor? (Any good CRT or flat screen should work.
Be sure to plug in the screen before you turn it on.
If it doesnt output to the LCD automatically you may have to hit FN-F8 to switch to external.
If it works on external monitor you are just dealing with a screen problem of some sort - either a bad inverter or backlight in the LCD most commonly...
Let us know.
Dec 17, 2007 | Dell INSPIRON 6000 CENTRINO...
Dell Inspiron 1501 Notebook Logo
54 people viewed this question
Alun Cox
