No power coming
No responce . no light blinking
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. Check cmos battery for charge and secure dust free connection some Motherboards cmos batteries are soldered in
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 05, 2013
Panasonic Plasma TV will not power up and blinks once.
It sounds like the low-voltage control relay has gone bad. This is what brings the tv out of standby and into full-on. Does it havr the same responce with button and remote? the other possability is the high voltage plasma exiter circuit is experiencing thermal-overload. If it's the first, an easy fix. If second, then the tv is a gonner. Not worth the money to repair. Plasmas unfortunately by design only lats 6-10yrs.
Oct 31, 2014 | Panasonic TC-P50U1 Plasma TV
Why no screen. can i fix
Take it to a Verizon store for evaluation.
Mark
Motorola support
Apr 30, 2014 | Motorola Cell Phones
SAUNA DOES NOT WORK
Can you provide more detail on the manufacturer and model number?
Nov 26, 2013 | Pool & Spa
Dell x50v won't turn on
while pushing the power button , push reset button for couple of seconds. hope that helps as that is what worked with mine.
Jun 11, 2009 | Dell Axim X50v Pocket PC
Blinking power button, no responce from the laptop
sound like you charger is broken, i think tose use the same charger as the compaq presarios, evo's if you can get a used 65 wat that problem would have been fixed, but those are still pretty new, i think you can get a new charger for free if it's still under warranty
Dec 24, 2008 | HP Compaq nc6320 Notebook
CPU problem
that the problem maybe on your power supply adaptor,
if ur monitor appear blue screen maybe ur power supply component has problem
Apr 10, 2008 | ECS RS400-A (V1.0) Motherboard
Multipal amps
make sure your speakers are connected correctly if subs and are inside the box then check connections also at times the rca at the back of the head unit can disconnect. if power light is on then error is either speakers not connected correctly, rca faulty or not connected or speaker output on amp is blown
Jan 03, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
