Have part #vsz12782205 0600000676 unable to get old part out. bulbs out ,door locks off, cannot get pannel down or open.how do i do that
SOURCE: Sears Kenmore Elite Refrigerator model
need model number even though it says kenmore we need to know the model will tell us the maufacturer but start by checking voltage at the outlet to see if you have proper ground
SOURCE: Kenmore Trio lights staying on melting the bulb housing
Thanks, FixYa, for posting this problem. My husband and I were about to buy one of these and were able to save ourselves a headache. We found out some updated information obtained from Sam, a lead tech at the national Kenmore service center, 888-536-6673:
There are 4 potential manufacturers of this fridge type, only 1 of which made the faulty part, which was apparently finally recalled last month. You cannot tell the manufacturer by the brand name, only by the first 3 digits of your trio fridge's MODEL number (usually listed somewhere on the fridge as well as on the printed manual you received at the time of purchase):
795 -- LG Korea -- some fridges affected, determined by SERIAL number
596 -- Amana/Whirlpool -- not affected
464 -- Maytag -- not affected
106 -- Whirlpool -- not affected
If you have a model number beginning with 795, call Sam or his colleagues, reference the service flash sf46-515, and have them look up your fridge by serial number to determine whether your fridge contains the recalled part. Good luck to all of you, and thanks again!
SOURCE: Temperature and adjust refrigerator panel does not work.
problems exist in its electronic control panel that is damaged, this problem should be solved by replacing one block electronic circuit in the control panel. damage is usually caused by a memory of the troubled program. actually if you know you can fix the electronic control panel of the electronic circuit itself, simply replace the IC EEPROM or memory alone. follows with Cristal oscilator usually must be replaced too
SOURCE: Help....kenmore trio refrigerator, error message "er co"
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
I have the same problem with this refrigerator. It looks like Sears Parts Direct sells all the parts for this unit except for the printed circuit board and temperature control switches. I called my local repairman and set up an appointment. He called back to cancel his appointment because he was also unable to get the electronics. Were you able to fix your unit? What did you replace?
