Question about Kenmore Dryers
Kenmore Gas Dryer will not start
Kenmore Series 80 Gas Dryer will not turn on. Light inside dryer is on, so there is power to machine. Drum turns freely. How do I get the dryer open and what should be checked?
  • 61 Answers
I would check the thermal fuse on the back of the dryer where the vent come out remove the back panell it is a small white with2 blue wirs most of the time and one screw holding it in un less you dryer does not have a removeable back then there is a removable front cover acrose the bottom remove it and the fuse is on the blwer housing the in the front should look the same and described above.
Posted on Jan 19, 2009
I have a kenmore 80 series. dryer will heat on all cycles. drum will not turn. gas dryer was in about 9" of water.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 07, 2011 | Kenmore Dryers
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
Kenmore 80 Series Gas Dryer wont turn back on after blowing fuse
Good day,
First, reverse the washer and dryer plugs in the outlet.
If that works, then the outlet needs changed.
If not,
The light switch is hot wired to the light circuit. Which means, if the machine is plugged in, the light will work.
Two possibilities.
1.The cord is bad, and needs replaced.
2. The light switch, which also runs the circuit to the motor is bad.
To access the switch, remove the lint filter, remove the 2 screws under it, then with a screw driver, pry up the top lid, one side at a time.
Lift the lid, but do not go above vertical. You will see the switch, and how to remove it.
You will need a VOM meter to test these items.
As well, make sure the machine is unplugged.
The following clip, at the beginning will get you started if you have to access the switch.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 19, 2009 | Kenmore Dryers
Kenmore 80 series gas dryer has not heat
most of these dryers have a little plastic plug on the front, left side. pop that plug out and look inside after turning it on. you should see a red glow. if not, then your ignitor has broken. if you see a glow, then the problem is probably one of the two little coils on the gas valve. these coils will sense if there is something to light the gas [the red glow] and open the valve - if the coils are bad, they won't open the valve
Aug 17, 2009 | Kenmore Dryers
Kenmore 80 series dryer drum won't turn
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
Feb 20, 2009 | Kenmore 73952 Gas Dryer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
check to make sure you have 220 volts to dryer. if so check element for continuity make sure power is off
Dec 08, 2007 | Kenmore 63942 Dryer
Dryers Logo
85 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
