Question about Microsoft Xbox 360 Console
Will not play 360 discs on my xbox360
Error reads: to play this disc put it in an xbox 360 console
  • 3 more comments
  • kcaj200 Jan 20, 2009
    Yeah i get this all the time, I turn it on and off like 50 times then it finally works
  • thesmyefamil Jan 20, 2009
    my xbox will not read the discs
  • walker992 Jan 20, 2009
    yes my old xbox did this and marked the discs. send back to ms
  • Anonymous Jan 21, 2009
    When i enter a disc , the games doesn't plays instead comes a message to play this disc put it in an Xbox 360 console in multiple languages!
  • james morgan
    james morgan May 11, 2010
    Sometimes this can happen if the laser is dead or if someone has tried to flash it and they have done it wrong. if no one has touched your dvd drive then it is more than likely a laser fault and this can easily be repaired by replacement parts from ebay etc.
    You could also try adjusting the laser pots ive uploaded a short guide to help you along your way:
    www.fixmyconsole.co.uk/freeguides/XBOX_360_POT_CALIBRATION_V1.0_by_Moda.pdf
    Problem Solver:
  • 71 Answers
Same thing happened to me. the disk is basically garbage. there must be a scratch or chip on the cd thats y it wont play.
Posted on Jan 29, 2009
Tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
on May 14, 2011 | Microsoft Xbox 360 Console
In my PES 11 on my xbox 360 , it doesnt start .... when i put in the disc it says region error . SO how do i fix it?????
For the xbox360, the region code on the disc must match the region code in the registry of the dvd-rom drive. The only way around this is to modify your xbox360 so that it plays different regions. This is highly illegal, voids all your warranties and is not at all recommended.
I own a US console (NTSC) and it will only play discs that match with the NTSC code. I can not play a Japanese game (NTSC-J) since NTSC-J is different from NTSC.
Use the following link to figure out which region disc and which region xbox360 you have:
http://support.microsoft.com/kb/906934
Mar 28, 2011 | Konami Pro Evolution Soccer 2011 for Xbox...
Xbox 360 Console: I've had problem with my Xbox 360 reading my discs...
Disc drive is out, needs replaced, but inorder to replace it you must keep the original drive. You can either order one online and follow these instructions to do it ureself (recommended) or email xbox360repair@palegathon.com for a pricing for repair.
http://www.llamma.com/xbox360/repair/xbox-360-repair.htm
May 18, 2010 | Microsoft Xbox 360 Console
My xbox360 wont play some xbox360 games it says put in 360 console well it is a 360 console. What so i do?
you do it is very simple , you can manually fix your problem with the use of repair guide,, it is a complete version to fix your problems caused by xbox.
if you want to download click here.
May 14, 2010 | Microsoft Xbox 360 Console
Swapped Hitachi boards now have "Put disc into xbox 360 console"
Have you put the sata cable from your drive to your motherboard in upside down? if your not sure turn it around and see if it works.
Remember thumbs up if this works.
Feb 03, 2010 | Microsoft Xbox 360 Console
XBOX360 WONT READ DISC
Though i fixed the Disc Read Error myself within anhour but please test the below method at your OWN Risk. Please alsonote that microsoft is no longer providing Extended warranty for E74Error.
Check out this DIY Video Guide,that explains step by step instructions to fix Disc Read Error yourselfwithin an hour. It also provides the money back guarantee in case youare not satisfied. As i fixed my Xbox myself so i thought to share itwith you guys....
Apr 06, 2009 | Microsoft Xbox 360 Console
XBox360 won't play games
Well I just recently purchased an XBOX 360 about a month ago form gamestation(used). It was giving me disc read errors every time iplayed it, but i opened it up and cleaned my TOSHIBA drive and wiped everything down with a cotton bud, and then lubed up all of the parts which needed to be.
and that fixed my problem
please rate
Dec 17, 2008 | Microsoft Xbox 360 Console
Xbox360 disc reading error
u should find out if its chiped or not chiped 360s dont play live cds unless they r burned
Nov 06, 2008 | Microsoft Xbox 360 Console
Xbox360 game will not read
If your xbox is modded try a different brand of disc.
Obviously try and clean the disc itself.
Else your dvd drive is faulty and needs to be replaced
Mar 17, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
