Question about Yamaha RX-V595 Receiver
Smart TV but reveiver does not have HD plug ins
My Samsung Smart TV receives input directly from cable to TV. What are my options to make sure any TV audio is in surround sound? The RX-V595 5.1 does not have the HDML connections. Do I simply output from TV L/R's audio and my HD is not an issue regarding SSound?
  • brooks_chris Jan 04, 2013
    I should have worded it differently. If not using the new HD connection cables, am I losing quality sound from my HD channels by using the regular L/R input cables for audio? In addition should I input my DVD directly to the TV because it does have the HDMI output port?
    Genius:
  • Yamaha Master
  • 1,054 Answers
I would input everything directly to the tv via hdmi, then take the optical audio output from the tv back to the receiver.
Posted on Jan 04, 2013
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
  • 4 Answers
SOURCE: tv speaker noise from yamaha rx-v663 hdmi connection
try running your A/C from TV to your reciver swichd outlet sound like it could be a grounding problem.This will put all ac from same outlet to the same componets.And will elimanate any difference in potencial
Posted on Feb 23, 2009
SOURCE: No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
Posted on Apr 14, 2009
smarthome2
  • 1114 Answers
SOURCE: Yamaha RX V 657 - No Sound Output, and No input detection
Bad DSP chip. The only other possibility is if you have the "Direct" on. On the front of the receiver it's a small button. Also make sure your "Speaker Select" A/B is "on" You will see it on the display, it's also a small button on the front of the receiver. If all this is correct and you still have no audio, it's a bad DSP chip. Not worth repair, it's 400-500 repair. Not very common in a Yamaha RX-V series, but I have seen it. I'm a Yamaha Dealer. If you need further help, post a comment and I will be glad to help you further.
Posted on Aug 23, 2009
  • 127 Answers
SOURCE: Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
Posted on Mar 02, 2010
Trying to connect my marinate nr 1603 to new samsung smart tv and keeps telling me "no signal"? Help
check the device input option. for example. HDMI 1, HDMI 2, HDMI3, typically you should see the port number marked by where you plug the cable in.
Jan 06, 2015 | Marantz Audio Players & Recorders
Trying to connect samsung smart tv to harmon kardon avr 330 with toslink cable, but i'm not gettting any sound through the receiver to speakers
The inputs may be assignable on the Harman Kardon. Make sure you have selected the proper analog or digital input type for the cable you are using. For more information, or should you have further questions, please visit my website at audioserviceclinic.com. You may contact me directly through the website. Thank you.
Dec 14, 2013 | Harmon Kardon Harman Kardon Avr 330 5.1...
Upgraded older HD TV to a Sharp 70" smart TV & Home Theater Receiver (Yamaha RX-V575. Have AT&T U-verse HD Cable box. What is the connection sequence using HDMI cables. Searched Yamaha and AT&T sites and...
I dont know about your particular hd hookup , but I take the hdmi cable out of my dish reciever/dvr [digital video recorder] and run it straight to the hdmi input #2 in the back of my apex 40 in lcd-hd-tv
I think take the hdmi output from the at&t u-verse cable box and plug it into the hdmi input of your 70 in sharp smart tv
that will get the input signal from your cable box ,both video & audio, into your tv set.
on the back of your tv set
there should be audio outputs for home theater audio systems that would plug into the audio inputs of the home theater system.
prehaps i am wrong because you say that your yamaha is a home theater* reciever.* is the yahama more than a home theater audio system? What does it recieve?
Idea-- the salesman that you bought it from should be willing to help tell you how to hook it up.
also consider that there are many different ways to hook up vcr's and then dv recorders and dvd recorders and external 2 tera bite hard drives into my tv & dvr . I got that all hooked in & a rats nest of wires. so i can record in hd or sd,on vhs or dvd or dvr
point is that you cant hurt anything by plugging the wrong plug into the wrong jack, as long as the same type of plug goes into the same type of jack.
If its right,it works, if its wrong, it wont work until you plug it into the proper jack.
im sorry ,im 65 am not into knowing all the latest and greatest cutting edge tech ,but i am begining to catch up on my hobby, movie recording tech.
Oct 08, 2013 | AT&T UVerse
Hi how do I get surround sound coming from my tv
A Samsung home theatre system can make watching movies at home like going to the theater. Proper setup is essential to get the full benefit of the Samsung system, which is available in 5.1 and 7.1 channel surround sound configurations.
Typically the final step in setting up any home theater is connecting your TV to your system.
Like most home theatre systems, your Samsung home theater receiver will allow you to plug all of your components into it, meaning you only have to run a few cables to connect your television to your system.
Make sure your playback devices are properly connected to your receiver.
Whatever playback devices you use, make sure they are plugged into the appropriate inputs on your receiver.
DVD and Blu-ray players, satellite boxes and cable boxes should all be plugged into video inputs, and CD players should be plugged into audio inputs.
Your receiver will have labels on the back panel indicating into which input you should plug your devices.
Connect the video out to your TV's video input. Make sure you use the correct cable to make the connection. For newer receivers, the connection will likely be either HDMI or component.
If your receiver has an HDMI output, use an HDMI cable to connect the receiver to the HDMI input on your TV.
If your receiver uses a component output, use a component cable to connect your receiver to the component input on your TV.
Connect the audio output of your TV to one of the audio inputs on your Samsung receiver if you want to output your television's audio through your home theatre system.
Most recent TVs will either use an optical cable or a digital coaxial cable to connect to the receiver, allowing you 5.1 channel surround from your television.
If you have an older set, you will likely have to use standard RCA cables.
Turn on your receiver and press the "Setup/Menu" button on your receiver's remote.
When "Input" appears on the display, press the right arrow key on your remote to select TV from the list.
After selecting TV, press the up or down arrow keys on your remote to select the audio input jack into which you have plugged your TV's audio cable.
Press the "Exit" button on your remote to exit the setup menu and lock in the settings.
Samsung home theatre system owners guide download
http://downloadcenter.samsung.com/content/UM/200903/20090327091825515/HT-AS730S-XAA.pdfalso
If you're not an electronics junkie, hooking up your surround sound can seem daunting.
There are so many wires and settings that it's understandable why some people might rather pay someone else to do it for them.
But you can do it yourself as long as you make sure the speakers are positioned correctly; the wires are not only plugged in all the way, but plugged into the right places; and the settings on your television and amplifier are set up correctly.
Check to make sure your surround-sound speakers are correctly installed.
Locate the test function on your surround-sound remote control or amplifier panel to do this.
You will know your speakers are hooked up if sound comes out of each speaker during the test.
Make sure your audio cables are hooked up properly.
Make sure the audio cables running from your television to your amplifier are plugged in correctly. The red and white wires should be plugged into the "Audio Out" spot on the back of your television.
Those same red and white audio wires should be plugged into one of the "Audio Input" spaces on the back of your amplifier.
Turn on your television.
Locate the "Menu" button on either your television remote or your television set.
Scroll through your options until you find "Audio Mode" or a similar naming convention.
Select it.
Scroll through your options until you find "Digital Audio Out," or a similar naming convention. Choose it.
Scroll through your options until you find "Dolby Digital Out." Select that option.
Power your surround-sound system on.
Make sure you have the correct audio input selected.
After the correct audio input is selected, make sure you actually have the Dolby Digital aspect of your surround sound system turned on.
The default for most surround-sound systems is the standard two-channel, stereo output.
Set up a home theater
http://www.cnet.com/1991-7386_1-6214422-7.html
Aug 07, 2013 | Samsung Ht-E355 330W 5.1 Channel Home...
I have a Denon AVR-3803 receiver and I have a DirecTV HD DVR HR 20-700. We believed someone hit a button on the receiver to cause the screen to go black. What buttons should we be pressing to try and...
First thing would be to check all the input settings on the TV and Receiver. Without knowing how it's connected, follow the cables from the Direct TV receiver to the AV receiver then to the TV and note the location. (input name) on the electronics back panel. Then make sure the TV is on that input, (Video1, Video 2, etc) Same on the AV Receiver, make sure the name on the back of the unit where the video cable is plugged into is displayed on the front of the Receivers display (CBL/SAT, HDTV, etc.) Lastly, make sure all the products are "on" especially the Direct TV receiver. It happens! Hope this helps. If you still have an issue, post a comment/reply and I can help you further diagnose the problem.
Jun 01, 2011 | Denon AVR-3803 Receiver
I have an LG all in one home theatre system, LCD TV and Direct TV satellite box. It is all hooked up and working fine except I only hear the sound through the speakers when playing a dvd or radio. The...
OK. For all you regular Joe's like me here's the fix--plain and simple! I have Dish Networks HD receiver, an LG Home Theater System (LHB953) and an LG HD Television - although I suspect this applies for most LG TV-to-LG Audio Systems used in combination with a HD TV). My problem lied within the LG to LG setting known as SIMPLINK which tries to "auto-configure" everything between LG to LG devices.
Do this to make your HD TV (using Dish/DirecTV) play it's HD video display from the satellite provider but play the audio over the LG surround sound speakers:
1. Plug a HDMI cable from your satelite receiver's set-top-box to your HD TV. This will carry your HD "video" ONLY. Click "Input" on the TV remote until the HD video signal shows your desired TV channel from your satellite provider.
2. Plug an HD Optical cable (the one with the red laser) from your LG HTS (Home Theater System) to your satellite box. This will carry your HD "audio" ONLY.
3. This is the magic everyone seems to be overlooking. On the LG TV remote, go into the menu options and disable SIMPLINK by setting SIMPLINK=OFF. This feature allows the video and audio signals to be split over 2 different ports: HD video goes over the HDMI cable and the audio to go over the HD Optical cable.
Hope this helps!
Scott C.
Feb 01, 2010 | LG LHB953 Theater System
I am having a problem with my remote I can turn my tv on and I can't work my sound.
I know this sounds obvious, but first make sure all of the input/output jacks are plugged in tightly.
Next, check the inputs that each component is plugged into and make sure the surround sound receiver is set to the proper device.
Without seeing the problem it is hard to explain.
There are two main ways that you could be set up.
1. You have all the cables running into the tv with an audio cable running out of your tv.
2. All the audio cables are running directly into the receiver and only the video cables are running into the tv.
To fix the problems it may be as simple as changing the receiver from one input to the next. It sounds like you are using option 1. Meaning you may have a bad audio out cable. If your SS is set up with option 1, check the cables running out of the tv to the receiver and make sure they are secure.
If push comes to shove, try to unplug everything and re-wire it.
Sep 23, 2009 | Televison & Video
I have a HDMI cable hooked between my Direct tv DVR receiver and my Samsung flat screen HD plasma tv. When I turn to Direct tv channels 100 or 200 the screen begins to flicker. My tv is 1080i. This is what...
If the TV just Flickers for a few Seconds then the Picture is Good and Stable, That is just the HDMI re-syncing often due to different signals from 480i to 1080i being broadcasted. If it continues to Flicker then check the options for Video set-up in your DTV menu. Make sure all available resolutions are checked to display or select AUTO if possible. TIP: NEVER Unplug or Plug in HDMI cables with the Power ON. This can Short out the HDMI Input leading to a Repair. Turn off All Units then plug in your cables, When ALL are in then hit the Powers.
Apr 28, 2009 | Denon AVR588 Receiver
Direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 20, 2008 | RCA RTD155 System
Cant get sound from speakers
That is because you didn't have the audio input connection right.
1. HDMI cable going from the Samsung tx72 output to Your Samsung TV HDMI input 2.
2. Non HD directv box Left and right audio output should be connected directly to the Samsung DVD receiver under Satellite input.Select"Satellite"for the sound from your Samsung tx72.You are good to go!
Joe
Feb 03, 2008 | Audio Players & Recorders
Yamaha RX-V595 Receiver Logo
230 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
