Question about Mitsubishi Vehicle Parts & Accessories
Wishbone mounts are knocking on 1997 1.6 carisma
Anti roll bar knocking
  • Mitsubishi Master
  • 694 Answers
Needs new rubber bushings installed to correct the issue
Posted on Mar 02, 2014
Have 2002 Camry and have thumping noise in the front passenger side. Have put on another owners' camry wheels and still have the same issue. So have eliminated that it is my wheels because it still...
is it more of a whomp whomp whomp noise that varies frequency depending on speed ?
Could be a worn wheel bearing
They are a sealed unit if it is a wheel bearing .
Mar 04, 2018 | 2002 Toyota Camry
What does a sway bar look like
sway bar?? could it look like an extension to a british officers swagger stick i wonder,or do you mean the anti roll bar which will connect the lower wishbone on either side of the vehicle
Nov 12, 2012 | Cars & Trucks
I have a banging under my ford windstar paid 2000 for van have put 10000 into it have always have fords love them but this problem mechanics cant figure it out......driving me crazy
It could be any one of a number of things:-
Exhaust system
Anti roll bar on front suspension
Stabilising arms
gear linkages
Wishbone joints
ball joints
rear suspension linkages
shock absorbers
engine or gearbox mounts.
flat spots on wheels
Try figure out if the noise only happens under certain circumstances like road surfaces or wheel speeds or engine speeds, and try narrow down the source.
Apr 01, 2011 | 1995 Ford Windstar
Changing Spark plugs for friend and she said you can't get to the ones at the fire wall what to do?
you can pull the wishbone mounts on the front of the engine and with a pry bar roll the engine forward and put the bolt from the engine side of the wishbone mount in the original hole in the engine side of the mount. this will allow enough room to get to the rear plugs.
Dec 02, 2010 | 1991 Oldsmobile Cutlass Supreme
Hi I own a peugeot 206 gti 180. It has recently
Check the drop link and sway bar (anti roll bar) bushes also the knock could be in the strut top or the strut itself, maybe disconnect the drop link to the sway bar and drive over a pothole and see if the knock is still there.
Jun 05, 2010 | 2005 Peugeot 405
My v 4motion creaks whenever it go over anything.
Definitely get the anti roll bar bushes seen to, its such a front heavy car. The sleeves are plastic and crack away, leaving metal on metal. Also the wishbone bushes dry out and will need replacing(most likely source of the creaking). Probably a 2-3 hour job for a decent mechanic, plus parts, you would have to get a price as it is so variable, but I remember buying anti roll bar bushes and drop links from a dealer for less than £50 all in.
May 11, 2010 | 2002 Volkswagen Golf
Hi, I have a knocking sound coming from the front of my 1997 A6 any time I gone over small or large bumps or holes in the road. It has been suggested my anti-roll bar bushes are to blame. I believe this is...
anti roll bushes are lockated with the arms, that hold your wheels together, if you are not sure get someone to point it out to you, unless you have did them before you may run into a hrd time with it
Jun 10, 2009 | 1997 Audi A6
Suspension knock on small bumps
Could be anti roll bar isolator bushes starting to wear or link rods,
Mar 22, 2009 | 2003 Jaguar X-Type
Knocking from front right wheel
LOWER WISHBONE OR TIE ROD GO FOR THEM FRIST,THEN BUSHES (ANTI-ROLL)
Jun 06, 2008 | 2003 Audi A4 Cabriolet
Vehicle Parts & Accessories Logo
21 people viewed this question
Top Mitsubishi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Navin Sharma
Navin Sharma
Are you a Mitsubishi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
