Question about Maytag Refrigerators
Water and ice smell and taste like plastic
MSD2273 purchased 11-11. Have changed out switch and water supply hose, was ok now bad again, 1 month later
  • 54 Answers
SOURCE: ice maker problem
let it run its caused by stagment water in the system it will clear over time.
Posted on Feb 12, 2008
  • 399 Answers
SOURCE: Bad water & ice cube taste
the feed line of the water source is bad replace it you will also need to clean the ice makers insides to remove the rest of the contamination
and 2 more suggestions:1) change the filter - older refers have the filter in the water line serving the ice maker - newer refers have the water filter in the refer (it looks much like an auto oil filter); 2) do not store ice for extended periods when ice use is not high e.g. during cooler months. Unless you use a full basket of ice over say a few weeks you should dump all and start over periodically.
thanks.
Posted on Sep 16, 2008
Our refridgerator has terrible tasting ice and water and we have tried everything to fix it. Is there a sure fire way to fix the problem. I would love to use the ice maker and water.
miracow
Posted on Dec 08, 2008
  • 4 Answers
SOURCE: Ice tastes funny and a strange metallic or plastic type smell
Sometimes the smell comes from something in the freezer or even the refrigeratior and makes the ice taste funny. My suggestion is to clean out the freezer compartment of anything frozen that has been there a while and may have freezer burn. That may be the funny smell you are experiencing.
Hope this will help you.
Posted on Jan 15, 2009
  • 9 Answers
SOURCE: Smell & bad taste of water from refrigerator dispenser
depending on the brand and the style, locate the filter and change it out. Please note that you must empty out the remaining water from the refrigerator cause if you don't, when you change out the filter you might get the same taste for a while until all the remaining water is replaced by freash water.
Posted on Jun 23, 2009
How do I clean my ice maker?
Curious, does your refrigerator have a water dispenser? How does water taste from it? Your ref. has one water supply for both ice and water. Changing filter was a good start but if it's been over a month, there's something else going on. I would look and see behind your ref. and look at the water line. I've run across a bad plastic tube that causes a bad taste. If you have a plastic one, change it out with a new one. Also, ice absorbs food odors from both the freezer section and refrigerator sections, so check your fridge for bad food. Bell green peppers are the worst, they'll leave a metallic taste. Good luck!
Sep 18, 2015 | Refrigerators
Why does the ice in my freezer taste and smell bad even though I changed the filter?
OLD PIPES NEED REPLACING,OR DID HOUSE WATER LINES SET A WHILE ,HOW LONG DID ICE MAKER NOT BE USED .CAN YOU REMOVE ICE MAKER AND CLEAN?. MOLD MAY OF ESTABLISHED OR RUST.TAKE WATER LINE OFF BACK THIS IS EASIEST. AND RUN 5 GALLONS OF WATER IN A BUCKET.TEST WITH A CLEAR GLASS WITH SOME FROM THE FLUSHING OUT WATER.IF IT DOES NOT CLEAR UP,HAS THE WATER COMPANY RAN TEST ON THEIR PRODUCT.THEIR MIXTURE OF FLUORIDE AND SUCH MAYBE FUNKY.DOES WATER LOOK CLEAN.GET CLEAR GLASS,FILL WITH ICE AFTER IT MELTS SEE IF THINGS AT ALL ARE FLOATING.DO SAME TEST AFTER YOU RUN 5 GALLONS OF WATER OUT OF THE LINE.ICE,MELT LOOK.HOW DOES WATER TASTE OUT OF DOOR IF THAT TYPE.IT CONFIRMS WATER LINE OR OUT OF FLUSHING WATER.IF IT TASTE OK FROM FLUSHING WATER THE SOURCE IS AS DESCRIBED IN THE FIX...
Jul 25, 2014 | Whirlpool Refrigerators
Ice smells like mildew! We purchased the refrigerator/freezer new 6 months ago. It does not seem to be a problem caused by other foods in the freezer. Model number: FFTR2126LW
Mildew smell in your ice is caused by one of three things. 1. Old, dirty, clogged water filter 2. Bad water quality from your house water supply 3. Ice that has not been used and sits in the bucket for time can become stale tasting.
Sep 01, 2011 | Frigidaire FFTR2126LW Top Freezer...
Ice maker is makeing bad tasting ice water supply is good no bad taste in water , can it be cleaned
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Oct 09, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
There is a bad order coming from ice and water dispenser. I changed the filter but it didn't help. Smells like ''dirt''. Thanks, Linda
Replace water supply line with the plastic tubing ice maker line. It fixed mine that had a metal braided line on it that made the water taste kie rubber and dirt,, after that I tried a vinyl braided line.and it made the water taste like garden hose water.. The plastic tubing was the cure. Reply and tell me what you have.
Mar 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
FRIDGE FREEZER SIDE STINKS
That is your problem.
The plastic supply lines over time deteriorate and wind up causing the water to smell.
Replace the plastic line with a stainless steel ice maker water supply line available at any home improvement center. They are 1/4 inch inside diameter lines and fittings.
They come in 5/10 and 20 foot lenghts.
After you do this run about 2 gallons of water through the water in the door dispenser. Discard the first 3 drops of ice from the ice maker.
Your ice quality will improve.
Mar 25, 2009 | GE Profile PFS22 33" Artica French Door...
My new Whirlpool Refrigerator the water and ice still stink
Dec 19, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
thanks.
Sep 16, 2008 | Refrigerators
Very bad tasting/smelling water and ice cubes - Superba KSRS27QAAL05
Since I found that the water itself being fed to the trays and being dispensed was bad. I replace the nylon, reinforced plastice icemaker hose with 1/4" copper supply line. That, along with purging the hopper (getting rid of) any old ice as well as washing the hopper out real good and giving the freezer a general cleaning - seemed to do the trick. No repugnant odor or taste. (I didn't even replace the filter- the cycle is every 6 mos.)
Hope this helps others who may be experiencing this same prob with this type of side by side appliance.
Lou
Jul 30, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
13 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
