Question about Alesis Io2 Express 24-bit USB Recording Interface
Connectin alesis io2 to laptop
I connected the alesis io2 And downloaded the cubase cd. I installed the software and when I tried to to open it, it came up with a not authorised... And closed down the cubase. The cd came with the product. There seems to be a problem with elicence etc. I took it back to the shop where I obtained the product from- fairdeal music birmingham uk. I was told to go online. Please help me connect my io2 as I am eager to record songs. Thanks. My email is vinodrai71@hotmail.com and my laptop runs windows vista.
4 Suggested Answers
SOURCE: Newbie Questions -- please help!
After I'm satisfied with a track, I save it as an MP-3 file. This can be saved into your regualr Dell files in a folder. Once there, you can use Microsoft media player and drag them into a 'burn' column in the order your want them. Use a good quality 'record to' CD when you burn your work. Caution, once you burn a piece on to the CD you can't usually add or change anything. Once you are satisfied with the disk, use media player or SONIC to burn multiple copies. This is pretty basic and I am definetely an amature but recently recorded a 17 track compilation of old Hawaiin music played by a wonderful talented lady for her family. I even managed to layer ocean sounds and other cools stuff. It turned out great!
Posted on Oct 29, 2008
  • 86 Answers
SOURCE: How do i get Cubase Le 4 to recognize and record my Alesis Io2
You may have a conflict with the onboard sound. If that is not turned off your card will not function.
Posted on Jan 08, 2009
bob_computer
  • 3153 Answers
SOURCE: no playback sound on cubebase le4/alesis io2
I am not 100 % with cubase but I am pretty sure it defaults to playing via midi and that you HAVE to set up the sound devices from the options first.
Hope it is of some use
Posted on Aug 22, 2009
Alesis io2 guitar inpu and mute playback for backing track in audacity
Audacity is a copyrighted audio source and does not permit you to record tracks or playback of any kind. you will need to D/L the audio file you are trying to record in tangent and then play them together through an audio remixing app, like Ableton live or FL Studio
Jan 28, 2014 | Alesis iO 26 Sound Card
Turn off dell 1545 microphone
Have you gone into the Audio Sound properties and taken the check mark off the microphone as a Recording device? Also mute the mic.
Apr 14, 2012 | Dell Inspiron 15 1545 Notebook
When i import an instrumental into cubase it will playback but will be very distorted, if i change the device settings in cubase and dont use the io2 it will playback fine so im assuming its something to...
In order for an imported file to sound correctly in Cubase, the bit rate and KHz must be the same or you will create garbage when going through your interface. For instance if you have ripped something from a CD it will be in 16 bit 44.1 KHz format. If you were to pull this into Cubase at 24 bit with 48 KHz selected as your projects rate you would encounter this problem. (I'm guessing this is what is causing your problem.)
Please open up cubase and click import, a window should pop up asking if you want to convert formats, please select the check boxes for conversion for the bit rate and KHz (depending on what version of Cubase it will be something similar to this.) An alternate solution is to go to the project preferences and select the rates that match the imported material before importing and no conversion will be necessary. (Although, I recommend always working in 24 bit and 48 KHz if you're machine can handle it.) A final possibility is that you have the latency set really low and the converters can't handle the speed at which the information is being processed. If the above should for some reason not work, check in your preferences box in Cubase if possible or through software that came with your interface and increase the latency. This can cause an audible delay between the time you hit a note and hear it back so make sure to decrease it before recording and increase it while mixing since you won't being recording new material and can use that processing power that would have gone to making sure you hear your live audio quickly can be steered to use plug-ins and get crackling free playback. Remember, with latency, even if get crackling from a low latency you will not hear that crackling upon mixdown! However, I'm quite sure your problem is with conversion rates, but if never hurts to know or get a reminder on things like latency. Cubase is a high quality product and I hope you enjoy using it. Thank you and I hope this helps.
Feb 25, 2011 | Alesis iO | 2 Sound Card
My alesis io2 express isnt working, doesnt work with my mac, not on garage band or cubase, is it compatable? what should i do?
When using with PC you have to go into soundcard settings and disable the internal sound card and select io2 or asio drivers.
I'm thinking it's the same on a mac
David
Oct 03, 2010 | Alesis io 2 Portable 2-Channel 24-bit...
I need some guidence to use my alesis io2
Anything spcific or you can download reference material from here,
http://www.alesis.com/io2
Mar 19, 2010 | Computers & Internet
No playback sound on cubebase le4/alesis io2
Aug 22, 2009 | Alesis IO 2 Sound Card
Jan 07, 2009 | Alesis IO/2 Portable 2-Channel/ 24-bit/96k...
Vista Home Premium fails to work correctly with 3rd party audio-ware, even though ALL audio product Vista drivers updated, and Vista OS software updated. Apparently the Vista audio problem is a common...
you will have a very hard time finding drivers for xp. dell will not support and dell does not have drivers for xp for your system. try vista sp1. i have no problems with my 1530
Aug 11, 2008 | Alesis Multimix 8 USB 8-Channel Mixer...
Alesis Io2 Express 24-bit USB Recording Interface Logo
99 people viewed this question
Top Alesis Computers & Internet Experts
John Bolton
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Alesis Computer and Internet Expert? Answer questions, earn points and help others
