Question about Exercise & Fitness
The treadmill on my Roger Black Gold Treadmill won't move when the power is on. The board lights up and the incline etc works but the treadmill just won't move. Can anyone help me please?
  • Liam wynne Feb 28, 2013
    Do u avea fix as mine does the same? Liam_wynne@hotmail.com
    Top Expert:
  • 12,223 Answers
Please see the video and proceed according, LUBE the rollers bearing very IMPORTANT!
However , if the problem persist your must test a) main motor+belt
b) main control motor board see the block diagram attached.
God bless you
The treadmill on my Roger Black Gold Treadmill won - 1_4_2013_6_23_55_pm.gif
Posted on Jan 04, 2013
bwinton
  • 83 Answers
SOURCE: Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Posted on Apr 29, 2010
SOURCE: roger black gold treadmill
Me neither. I can switch it on but cant get it to do anything :(
Posted on Dec 01, 2009
SOURCE: looking to find a user manual for Roger Black Gold
Hi I just found out where to get the manual ring 0845 6000 464 they should be able to help - ive been trying to get a manual too and had success at last from the Reebok Tech team, they were great and fast too! Gd luck!
Posted on Mar 24, 2010
  • 3 Answers
SOURCE: how to lubricate roger black gold treadmill and with what
http://rogerblackmanuals.co.uk
Posted on Apr 01, 2011
  • 1196 Answers
SOURCE: i have a roger black treadmill the power light is
All powered treadmills have a breaker. The purpose of the breaker is to prevent a power surge that might damage the treadmill motor. Check the circuit breaker on the frame near the power cord. If the reset/off circuit breaker has tripped, wait 5 minutes and then reset the breaker by pressing the switch in. That should fix the problem.
Posted on May 11, 2011
How to fix a treadmill
see the video attached. lube the rollers bearing front +back.
However you must test the terminal motor voltage with multimeter, if there ARE THE MOTOR IS faulty. see my personal TIPS.
2) test the measure output voltage from control board for input voltage terminal motor if there ARE NOT, the board is faulty.
God bless you
Oct 19, 2013 | Exercise & Fitness
My Reebok v6.80 treadmill turns and lights up but won't go.
1) LUBE the deck belt,you have a WORN deck belt, this happen because you didnot lube according with the schedule maintenance
29 LUBE the rollers bearing too
3) Test the drive belt motor, for worn or crack, or adjust if is possible
4) Test the input voltage motor, if there are the motor need repair
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 28, 2012 | New Balance 1400 Treadmill
Problem with my Rogerblack treadmill
i av gold treadmill model ag10302 and need 2 get mains lead
May 17, 2012 | Exercise & Fitness
My treadmill won't start. It sounds like it is inclining when I insert the key but nothing lights and it is not moving.
Dear Sir:
Inside test the fuse and replace use DVOM, or reset the c.breaker
2) Adjust the reed switch see the diagram attached, clean,and tight the connector very well. Tigh the ribbon cable from keypad + connector from display board vs lower board
3) Lube the deck vs deck belt, this produce enough friction.
4) test the input motor voltage,if there are the motor need repair or replace
5) Test the output voltage from the m.motor board for the input motor voltage, if there are NOT the board is faulty.
6) Try after your fix, the software calibration for diagnose, and troubleshooting.
sincerely. God bless you
May 01, 2012 | Proform CrossTrainer Treadmill
Where is the reset button on Roger Black Gold Treadmill
resetting the treadmill especially on most merit treadmill is as easy as pressing and holding the "STOP" button until you hear a beeping sound and the display shows all zeros.
Apr 08, 2011 | Exercise & Fitness
The incline on my proform treadmill is not working and now I can't get the treadmill to start, it just keeps inclining up and down
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad.
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
If the incline motor does not move, we need to figure out if the motor is getting voltage. Use a simple multi-meter and set it to AC volts. When you put it into calibration, it tries to calibrate the directions one at a time. Measure across the white and black wires first, then measure across the white and red wires second. If the motor is getting voltage you will read 120VAC (or
thereabouts) one one of the measurements. If you have voltage but the motor won't move, you need to replace the motor.
4.
If the incline motor does not move and you have done the voltage test and you do not have any voltage present, there is a problem in the electronics board that supplies the power. If the console is powering the drive motor as normal, you can bet it is getting an incline signal and the power board needs to be replaced (some models have an integrated power board/controller) so if there is only a single board the whole board has to be replaced. It is possible the console is not giving the proper signal but we've never seen it happen in thousands of treadmills.
Jul 09, 2010 | Proform 650 Crosstrainer Treadmill
Treadmill stuck on highest incline....and motor running...but seems stuck...won't come down
If the incline is stuck, it could be a problem as simple as the gearbox on the motor being jammed. Unplug the treadmill remove the motor shroud then remove the incline motor from the treadmill, reconnect the wiring, plug in the treadmill and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
If the incline motor does not move, we need to figure out if the motor is getting voltage. Use a simple multi-meter and set it to AC volts. When you put it into calibration, it tries to calibrate the directions one at a time. Measure across the white and black wires first, then measure across the white and red wires second. If the motor is getting voltage you will read 120VAC (or thereabouts) one one of the measurements. If you have voltage but the motor won't move, you need to replace the motor. . If the incline motor does not move and you have done the voltage test and you do not have any voltage present, there is a problem in the electronics board that supplies the power, you need to replace the board.
May 17, 2010 | Proform 650 Crosstrainer Treadmill
The treadmill will not incline
Try calibrating the unit first, if this does not work than check below:
1. If the incline moves but you will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad and needs to be replaced.
2. If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. Remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
3. If the incline motor does not move, we need to figure out if the motor is getting voltage. Use a simple multi-meter and set it to AC volts. When you put it into calibration, it tries to calibrate the directions one at a time. Measure across the white and black wires first, then measure across the white and red wires second. If the motor is getting voltage you will read 120VAC (or thereabouts) one of the measurements. If you have voltage but the motor won't move, you need to replace the motor.
4. If the incline motor does not move and you have done the voltage test and you do not have any voltage present, there is a problem in the electronics board that supplies the power. If the console is powering the drive motor as normal, you can bet it is getting an incline signal and the power board needs to be replaced (some models have an integrated power board/controller) so if there is only a single board the whole board has to be replaced.
Feb 20, 2010 | Exercise & Fitness
Roger black gold treadmill
Apr 30, 2009 | Exercise & Fitness
Roger black treadmill.
i can repair or supply any roger black parts that you would need. contact me on 01706 371711
Jan 27, 2008 | Baby Gear
Exercise & Fitness Logo
1,902 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
