Short Circuit on motherboard Acer 5738ZG
Hi, I have issue with repair 5738. Perhaps this Notebook was damaged with wrong polarity on power supply input. I think some electrical element on motherboard was destroyed. Bud I dont known how transistors switching or which element can be damaged. I remove element for DC 24V 1,1A and measure + oposit - still has 0 OHM. So I dont known where is short circuit. If you have some good idea or scheme power part on motherboard please inform me. Thanks.
How to reset acer aspire 5538 hard drive password
Hello Peggy
Bad news, if you forgot your hard disk password there is no way to help, just buy a new one, and recover all your operating system again.
sorry, but at least its my opinion
Feb 02, 2016 | Acer Genuine OEM Aspire 5536, 5536G, 5538,...
Hi I have an htc one mini m8 it suffered some water ingress everything still works fine accept the back light so found that the charging port flex is damaged does this have anything to do with the...
Any short circuit on the PCB due to water intrusion causes short circuit in the supply voltage to the back light.
Try to clean the PCB under a microscope.or replace the damaged parts.
Mar 09, 2015 | HTC Cell Phones
My Acer Aspire 4750G-2312G50nbb does not turn on, Whenever I insert the charger adaptor to the power jack, the charger adaptor led light turns off.
One of two issues will cause that.1/ The socket is damaged and presenting a short circuit to the charger or 2/ The protection diode has blocked an incorrect voltage/polarity and provided protection by going short circuit.
Jan 11, 2014 | Acer Aspire Computers & Internet
Can my daozd1mb6go motherboard work with out the capacitor pc 90?
No! you will cause more damage in the long run even if you successfully restart it, replace the part before you attempt it.
May 06, 2012 | Acer Aspire 5920-6423 Notebook
Hi,i have notebook acer aspire 5738zg. i have problem to opein cd drive when ever i try to open its taking tomuch time and after that i cant open it what i have to do
Hi our cd drive is probably stuck try tipping the laptop differnet ways to get it unstuck if that doesnt work take the back off the laptop remove the cd drive this is quite hard on laptops and you should search google for a guide for your model. unscrew the cd drive and push the drive open and closed this should get it moving put it all back together and open ta da it works lol hope it helps
May 07, 2011 | Lifetime Acer Aspire 5738ZG Replacement...
Have reversed polarity and is no longer open and no longer charge the battery. You can help?
Applying a power supply with reverse polarity to your Acer will have damaged the motherboard and possibly other components. This notebook is beyond repair.
Sep 20, 2010 | Acer Aspire 1300XC Notebook
Hi - For some reason, the printer will not turn on. I have checked all connections.
Also, are you sure that the replacement power supply was compatible with the old one
was working on the problem. There was nothing wrong with power supply or motherboard. I disconnected everything and left only power supply connected to motherboard. When I turned on the power switch located on power supply nothing happened. Then I short the power sw pins located on the motherboard with the help of a screwdriver. The motherboard came to life. The I connected all connections again. I don't know whether it was a static charge developed on the board or reverse polarity ... May be you can explain it better as I am a newbie in hardware world. In nutshell problem is resolved.
Dec 03, 2009 | HP Photosmart 2610 All-In-One InkJet...
Acer Aspire 5738 fingerprint reader not working in vista
zer0ne:i too have this problem . what can i do........
Oct 05, 2009 | Computers & Internet
Power supply issue
sound like they have damaged the "new motherboard" when have installed it at the shop. Or they installed a cheap brand and it's not correctly sitting in the base. should ask them to show you the old motherboard they removed to make sure they haven't just fudged-up the old one.
Jan 13, 2008 | Acer Aspire 5004WLMi Notebook
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
