Question about Bowflex TreadClimber TC5000
I have a TC 5000, the whole front end is off center. The right tread rubs against the stablizer bar when going up and down. How do I center the front end?
Do I adjust the 9/16th hex bolts in the back or the front stabilizer bars somehow?
    Top Expert:
  • Bowflex Master
  • 12,223 Answers
Please see the video and proceed according.God bless you
I have a TC 5000, the whole front end is off cente - mkwrinri3haaaaaelftksuqmcch8oly96lhb9tqaaaabjru5erkjggg==
Posted on Jan 04, 2013
Treadles on tc5000 wobble and rub
You have to realign treadles ,take the back cover out and at the base of your unit you'll see two slides , couple of screws and yellow bushings if bushings are still in a good shape you can align treadles , if they're broken or worn out you have to replace them , I think there are 8 of them total ,they're called IGUS bushing
Good luck
Jan 05, 2014 | Bowflex Tc5000 Climber Treadclimber...
I have a viberating noise coming from the front can feel it in the stearing not ball joints or drive shaft does anyone no that ill call it a stablizer bar that goes from left tire to right tire have a
If you have a vibration and you have eliminated the suspension and steering take a close look at the tyres. Look for bulges on the side walls , raised section of treads. Have the tyres rebalanced. Tyres are prone to belt seperation which causes vibrations
Jan 27, 2013 | 2000 Chrysler Town & Country
How to replace outer tie rod
There is a cotter pin that you remove first. Unbolt the tie rod end to where it attaches to the vehicle. You will the need to use a tie rod end separtor to separate it from the knuckle. It is a U kind of tool that you hammer in and it will separate it for you. You will understand what I mean when you see the tool. Next you take two wrenches, one that fits on the flat part of the tie rod end itself ( close to the nut you will see one the treaded bar it is attached to. Take the other wrench and turn the nut on the treaded part of the bar that the tir rod end is attached to. Loosen the bolt, it just needs to be loose so you can turn the tie rod end around. Now that it is loose "unscrew the tie rod end from the treaded bar. Remember to count how many times you turn the tie rod end so you turn it the same amount of turns when you put the new one on. Reassemble in the oposite order remebering to turn that tie rod end the same amount of turns. Make sure that the bolt attached to the treaded bar that the tie rod end screws on is good and tight against the tie rod end so it stays put. I would still think about getting an alighnment and would replace both right and left tie rod ends. I hope this helped and good luck
Feb 15, 2011 | 1999 Lincoln Town Car
I went and got new tires they told me I needed a link pin replaced on the front passenger wheel. It is now grinding when I make a hard right turn. I do not see a part named that do you know what that would...
Did they replace the "link" pin? In the front...the only thing that is a "link" are the swaybar end links, would not be in the way of the tires though. But these need to be replaced as a whole, cannot replace just the pins. Are the tires rubbing or is it a metal to metal sound? If the tires are oversized, could be rubbing against the upper ball joint. If it's metal to metal, it could be many things. If they replaced the end link, make sure they put the correct one on, the right is for the right, the left is for the left, if switched, it will bend and rub agains the gusset right there.....been there, made that mistake.
Jan 22, 2011 | 2002 GMC Envoy
Tread is sliding and rubbing agianst right side of track.
Make sure treadmill is running when you adjust belt. The treadmill belt tracks as the belt goes around. I usually put machine on 2-2.5 if belt is not rubbing instantly. If belt is already against plastic, turn adj. counterclockwise on the opposite side about one full turn. You can usually move belt with your foot to see if it aligns any with turning on the treadmill. Once belt is not rubbing, turn treadmill on and continue alighing the belt.
Jul 20, 2009 | Nordic Track NordicTrack Treadmill, A2550
Proform treadmill belt won't stay centered. travels to left and rubs against side
Adjust the tension on the right side rear using an allen wrench. Try 1/4 turn clockwise( should tighten). then run tread mill for 30 sec. to see if it centers itself. repeat again if not. if its to tight then turn the left side in a 1/4 turn
Apr 28, 2009 | Proform Exercise & Fitness
Bowflex Treadclimber rubs against housing.
Adjustment is needed. Remove rear covers and using a 9/16 wrench lossen the four bolts that secure treadle assembly to base. Place a 3/4 inch piece of plywood or a 3/8 inch socket extension in between the treadles in the front area. with that in place center them about an 1/8 in closer to the right upright as when you tighten the four bolt up the drive belt will place additional pressure and they should center perfect. tighten bolts...tight. remove wedge from between treadles and recalibrate unit. replace covers and enjoy. Use turtle wax on area rubbed to prevent rust.
Mar 05, 2009 | Bowflex Treadclimber TC5300
Bowflex TreadClimber TC5000 Logo
119 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
