Question about Plantronics M50 Bluetooth Headset
Bluetooth on phone not detecting - Plantronics M50 Bluetooth Headset
How can I configure wlan and Bluetooth on Blu life play X cell phone?
Do you have a wireless (WiFi) home network ? Do you have any other Bluetooth-enabled devices that are turned on that your phone can detect ? You also need to tap on Scan for Bluetooth on your phone for it to start looking for available Bluetooth devices; maybe you need to do the same for WLAN.
Dec 31, 2014 | Blu Life Play L100a - Pink
Iphone won't detect bluetooth
It's probably not the speaker, your phone is not recognizing the device. This is the link How to troubleshoot Bluetooth Connections from Apple:
http://support.apple.com/kb/TS4562
Dec 25, 2013 | Brookstone Big Blue Live Wireless...
My phone bluetooth is not deteced by any other devirce
Your phone visibility right now must be on.Try going to your bluetooth settings and check your "phone's visibility"--when its "on", that means other bluetooth enabled devices can detect your phone and if its "Off" no device will be able to detect it.
Aug 24, 2011 | HTC Touch Diamond Smartphone
Toshiba laptop with IOgear bluetooth adapter installed will recognize phone but won't detect plantronics explorer headpiece. I would like to use it to chat on skype
If the Bluetooth adapter can detect the phone but not the Plantronics headpiece, then there's no problem with your computer or your Bluetooth adapter. The problem has something to do with the Plantronics.
Try to turn the headpiece off, then turn it back on. Set it to discovery mode, then try to detect it using your computer. If that did not help.
Try to detect the Plantronics, using your phone. That will help you in isolating the problem.
Aside from that, make sure that no possible wireless interference while you're searching for the headpiece. Cell phone, base of the cordless phone should be away from the computer while you're searching for the headpiece. Because Bluetooth and cellphones/cordless phones are running on the same 2.4GHz frequency RF signal. They might interfere with each other.
Apr 14, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth connection
Ensure that your phone is switched
on and the headset is switched off.
2. Press and hold the power key until
the green indicator light starts to
flash quickly.
3. Activate the Bluetooth feature on
the phone, and set the phone to
search for Bluetooth devices.
4. Select the headset from the list
Feb 09, 2010 | Nokia BH-208 Wireless Headset
IPhone bluetooth disease!!!
Bluetooth on the iphone only recognises other iphones or bluetooth devices such as the handsfree in your car. It will not find other mobile phones with bluetooth. Another scam for apple to get everyone to buy their fones I assume.
Aug 05, 2009 | Apple iPhone Smartphone
Pairing Problem - BluetoohJabra VBT2050 & LG Shine CU720
I have a Jabra VBT 2050 bluetooth headset. As per the product user manual(page 8) this device is compatible with any bluetooth mobile phones with bluetooth version 1.1 or higher.
My LG Shine CU720 mobile phone is not able to detect the VBT 2050 device. I checked the specification of mobile phone & its bluetooth 1.2. I am able to pair the VBT 2050 with other bluetooth mobile devices.
Could you help me resolve my problem. Appreciate quick help
Apr 01, 2009 | LG Shine 720 Cellular Phone
Bluetooth on but not detected or detects other devices
What u need to do is not just turn on the blue tooth on your phone but set it to 'find me', so that other bluetooth devices would be able to locate the device. the 'find me' option is also under the blue tooth menu.
please rate me. thank you.
Dec 03, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Motorzr v8 Bluetooth problem
The Bluetooth Transmitter/Reciever in the phone is probably defective. You can verify this by testing it with another Bluetooth device. If it fails with another device, then you know for sure that the phone has a fault.
The fix is to change the circuit board that has the Bluetooth processing. This fix will be expensive in relation to changing the phone if the phone is out of warranty.
Jerry G.
Jun 15, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Plantronics M50 Bluetooth Headset Logo
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
