Question about Vehicle Parts & Accessories
Hi setting on heater in my car doesnt work - Vehicle Parts & Accessories
  • Vehicle Part... Master
  • 14,337 Answers
Replace blower motor resister,it's located by blower motor,easy to replace,remove electrical connector and remove 2 screws.
Posted on Jan 05, 2013
Heater blew a fuse, replaced it but heater still doesnt work
Hi, Check the fan motor it could be the problem. It maybe why the fuses are blowing. It is lacated under dash right side. Check motor connections, and grounds.
Good luck.
Dec 11, 2011 | 1998 Cadillac DeVille
Hi my heater in my car doesnt seem to work. Is there something i can look at and fix or better off going to a mechanic?
First thing you will want to do is put make model and year of the vehicle your talking about. But an off the wall guess would be heater control switch.
Mar 26, 2011 | Ford F Cars & Trucks
Hi, this 1999 ford escort zx2 has a heating problem, i set the temperature to the red side on supposedly the hottest, and air fan running, and air its still cold, it has coolant/antifreeze mix to proper...
You may have a clogged heater core. Carefully feel both heater hoses and see if they are about the same temperature. If one is colder than the other the flow thru your heater core is restricted and it will have to be changed
Jan 01, 2011 | 1993 Jeep Grand Cherokee
My heater blower in my 95 yukon doesnt work on low , only on the 2 highest settings, and also doesnt blow hot
THE DIOED IN THE FAN SWITCH IS GONE. CHECK VACUUM LINES IN ENGINE BAY FOR LEAKS OR BROKEN CONNECTIONS ON PASSENGER SIDE, THEY FEED ACTUATORS UNDER DASH THAT CONTROL HEATER FUNCTIONS.OR A VACUUM ACTUATOR COULD HAVE FAILED.
Jan 09, 2010 | 1995 GMC Yukon
Ford ka blows hot air even set at cold
sounds like heater control valve situated under scullle panel common fault on ka set heater fan switch half way between hot and cold with heater blowing then touch valve if pulsing or clicking noise it is faulty if doesnt solve problem faulty switch
Jun 07, 2009 | 1999 Ford Taurus
Ac heat dash board problem
U will need to replace the automatic climate control head, this is the module u set your desired AC and heat setting on in the center of the dash.
Dec 03, 2008 | 1994 Lincoln Town Car
Heater wont blow heat but A/C works fine....
Go to engine compartment, locate heater control valve. It will have the heater hoses connected to it that pass into the firewall. Unhook actuation plunger on the control valve. This will allow the coolant to flow though the heater core at all times. Now you have heat. If you get too hot, you can control it by the hot/cold settings to adjust the heater door.
Nov 21, 2008 | 1999 Jeep Grand Cherokee
Heater blower on sprinter van not working ,i need to locate the problem point .has been going off intermitently for some time
email this guy at sales@bargainworlduk.com he sells the carbon brushes new at only 5.99 a pair! Its fantastic and they work a treat. Why pay £300 when it will cost 5.99 to buy a new set of carbon brushes!!
Nov 03, 2008 | Mercedes-Benz E350 Cars & Trucks
Heater/AC fan does not blow on two lowest speeds.
Your fan uses resistors to reduce the speed of the fan. Hi speed doesnt use the resistors and that is why it runs on hi. Standing in front of the car, all of your heater housing is on the left side of the firewall You will see a connection with about 4 wires That look like they go nowhere. Take the couple screws out and pull it out. You will be able to see the burnt one.Jump out the burnt on and that will give you another speed or two.
Oct 25, 2008 | 2003 Buick Century
Heater/air con
The heater resister switch has gone. You need to strip out the box and put a new switch in which costs around £20
Jul 29, 2008 | 2002 Ford SVT Focus
Vehicle Parts & Accessories Logo
22 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
