I have a Canon iP5200R printer which connects fine to my Toshiba laptop using USB but bizarrely fails to connect using either wired ethernet or wireless. It connects fine using all three interfaces to other computers I've tried. The install procedure runs fine although it does require a reboot due to an outdated file (this doesn't happen on other machines), and the Canon IJ network tool reports it as being present and connected. But the printers folder in windows XP Pro shows it as being offline so I can't print! I have tried reinstalling multiple times, purging the files each time but have had no success.
Hi My printer is not taking paper and it seems the roller that feeds is not working. the light...
(More)
Hi My printer is not taking paper and it seems the roller that feeds is not working. the light flashes 11x which I saw means 'ap position error' does anyone know if this can be repaired? Or how? Many thanks,
Pixma ip5200 has mail lable wrapped around roller and is printing white streaks on printouts. How to...
(More)
Pixma ip5200 has mail lable wrapped around roller and is printing white streaks on printouts. How to remove and clean or replace roller?
I have just changed the ink cartridges but the printer is not used for quite some time. After it is...
(More)
I have just changed the ink cartridges but the printer is not used for quite some time. After it is switched on, all seems normal except that the printer can't form feed the paper to print. The papers are placed properly and print job is in order, but even I have reset the printer a few times, it still does not print. Please advise the solution. Thanks.
Whe I try to open the CD Lable print program this message appears in a box on the screen I used it...
(More)
Whe I try to open the CD Lable print program this message appears in a box on the screen I used it Yesterday morning without any trouble suddenly it hangs up after I used Task Manger to quit the program I restart my computer re-install the printer drivers etc but is still appears when I'm trying t locate the program to print on the CD's please I'm stying in Sout Africa. nicolene.heydenrych@gmail.com
I have a Canon Pixma iP5200R which has been going great up and until now! Now the print outs are...
(More)
I have a Canon Pixma iP5200R which has been going great up and until now! Now the print outs are coming out in colour but with purple tinge. Checked all cartridges - switched off computer and printer and restarted. This solved it for about 5 print outs, now it is back. Why?
