Question about Xerox Office Equipment & Supplies
My Xerox Dc 252 has the error code 012-322
Whenever i send something to print it says Fault or error has occured switch off your machine. error code 012-332. Help ZM
2 Suggested Answers
  • 155 Answers
SOURCE: xerox DC 3535 error 116-332
Simultaneously press and hold the 1,the Stop
and the Power Save buttons on the Control
Panel,if problem continues repeat the same
with
6,the Stop and the Power Save buttons
4,the Stop and the Power Save buttons
3,the Stop and the Power Save buttons
Posted on Aug 28, 2009
Xerox Printer not starting, A fault has occurred. Fault Error 116-201
The problem description is: Fault Code 116-201: HDD Was Not Booted Due to an HDD Error Detected on Booting. Try this link first: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=387,E=0000000005750000208,K=9799,Sxi=3,Solution=obj(542)
If this does not work. Unplug the machine from the wall while still on
do not power down first. treat it like the power just went off in your building. While the machine is still off not plugged to the wall. Press the power button several times. This will erase any saved info on memory.
Plug machine back on an try again. If it does it again you will need to replace your hard drive and that will take a service call.
Dec 10, 2015 | Xerox DocuColor 3535 Copier
I have xerox dc 250 machine, it shows fault code 077-909, paper jam at tranfer module but i checked there is no paper in it??
Hello friend, you are not alone !!!!
From http://www.copytechnet.com/forums/xerox/28764-dc-250-fuser-problem-077-909-a.html
At the bottom of the page it says.......
'what sometimes happens is that the sensor flag/arm call it what you will, twists out of its holder and jams, hence the machine thinks that there is still paper. the flag/arm should pivot freely'
Sep 03, 2014 | upbright AC / DC Adapter For XEROX...
Fault code 127-337
Xerox dc240 error code 127-337 problem solustion
Aug 06, 2012 | Xerox DocuColor 240 242 250 252 260 Black...
Xerox docucolor 12 system fault 15-362
Fault Code 15-362 - CAUTION: The Fuser Roll remains in a cammed-up position if power to the copier is interrupted while the copier is in use. The Fuser Roll will not be released from its position until the power is restored, the Power Switch is in the On position, and the Start button is pressed again. If the Fuser Roll remains in the cammed-up position for a prolonged period of time, copy quality defects will occur. To prevent damage to the Fuser Roll, switch the Power On as soon as possible after the power is restored, and make a copy of a document. If the machine is a DC 12LP send a print job from a workstation to prevent damage to the Fuser Roll.
Apr 15, 2009 | Xerox DocuColor 12 Printer
Xerox Workcentre 24. 20 months old. The sreen simply says: Fault/Error, then below: A fault has occured. Switch the machine Off and then On. If the problem persists, call for service. In the bottom left...
That is a software processing error.
Do you have it set up as a printer? If so, try removing the print cable and power it on that way.
If that doesn't work, you need to have the firmware reloaded. That can only be done from a laptop with Xerox software on it.
Oct 02, 2008 | Xerox Office Equipment & Supplies
Xerox dc 12 copier system faulit 9-354
Hi ,
Sir I am have dc12 mech
its giving error code 9-354.
send me the solution as soon as posible.
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
764 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
