MID7010WC supports usb drives(pen drive)? if yes tell me how to connect it. please when im connecting a device it nt showing anythng
  • hariur4it
    hariur4it Jan 04, 2013
    coby kyros mid 7010
  • 27,725 Answers
W 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts if you need more help with this or if i have missed the problem post a reply Hope it helps.
Posted on Jan 05, 2013
  • hariur4it
    hariur4it Jan 08, 2013
    I am asking about tablet bro.. my tablet not showing usb when I connect it via cable.. should I install anythng in tablet to work it properly?? my tablet is coby kyros mid 7010wc
  • Brian Sullivan
    Brian Sullivan Jan 08, 2013
    http://www.bing.com/videos/search?q=how+... youtube videos
5 Suggested Answers
  • 3 Answers
SOURCE: i don't have driver of pen drive in windows 98
Let's check your Windows 98 Version first :)
  • Right click on My Computer and select Properties
  • On the System Properties page that opens up click on the General tab, if it is not already on that page.
  • Under the System heading, look for the version number (see right)
    • Version 4.10.1998 is the original version of Windows 98 (98FE)
    • Version 4.10.2222 is Windows 98 Second Edition (98SE)
  • Click the link below for the download and installation instructions for your version of Windows 98
Fo Windows 98 FE:
  1. Download and install the Windows 98 Service Pack (35.5Mb)
  2. Download to your desktop the driver file from the Download section below
  3. Remove ALL drivers for USB flash drives in Device Manager (Optional)
  4. Remove ALL drivers for any USB 2.0 controllers (many have an uninstall option) (Optional)
  5. Remove ALL unknown devices from Device Manager
  6. Run the exe file you downloaded, and follow the instructions, rebooting after installation
  7. When the computer boots up again, it may detect new USB 2.0 controllers, in which case you may need to reboot again
The drivers can be downloaded from the following link:
Windows 98 FE Generic USB Mass Storage Device Drivers v3.20
For Windows 98SE:
  1. Download the exe file to the desktop
  2. Remove ALL drivers for USB flash drives in Device Manager
  3. Remove ALL drivers for any USB 2.0 controllers (many have an uninstall option)
  4. Remove ALL unknown devices from Device Manager
  5. Run the exe file you downloaded, and follow the instructions, rebooting after installation
  6. When the computer boots up again, it may detect new USB 2.0 controllers, in which case you may need to reboot again
Windows 98 SE Generic USB Mass Storage Device Drivers v3.3
For detail explanation, please visit http://www.technical-assistance.co.uk.
It's help for me :)
Thanks
AkulahPathub
Posted on Mar 13, 2009
ginko
  • 19396 Answers
SOURCE: External USB Drives No Longer Detected
There are two possibilities:
The Mybook USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. WD Mybooks are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be WD .
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
Posted on May 04, 2009
SOURCE: Fantom Drive TFDU16072A Error
2009 06 30 - I just had a similar problem. The Fantom external drive was working fine, but I had to shut down due to a thunderstorm. When I restarted the PC, the drive was not showing up. WHAT I FOUND: First, I didn't find this solution anywhere - everything seemed to point to a new install (or at least how to reformat and start over.) BUT, I right clicked on Computer, Manage, Disk Management - it still didn't show. On the right, under More Actions, I clicked 'rescan disks'. Now it shows up! And all of my data is right there. Whew!
Posted on Jul 01, 2009
  • 25 Answers
SOURCE: This device can perform faster ??
Go to device divers and make sure you have the right driver installed...some other download you may have done might have changed the original driver..try to download new driver from original sight
Posted on Oct 02, 2009
My pc doesn't show sandisk cruzer blade 4 gb pen drive whereas it shows others
Sometimes, windwos OS, give same drive letter to different devices, and when you connect both, one is not showing. So, you need to go in to Disk Manage (right clic on "My PC", clic on Manage") and verify if you can assign a different driver letter to your pen drive.
Oct 01, 2012 | SanDisk SDCZ50-004G-P95 4GB Cruzer Blade...
PEN DRIVE NOT OPEN
what problem you are facing with your pen drive? are any error message you are getting when you try to open your pen drive? please send us your problem in details.
Apr 13, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Sony microvault 2 gb pen drive- can not copy file- I/o device err
My 2gb sony microvault is asking me to format. It is teeling me that it is write protected. How do I format it
Apr 16, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
How to use USB device in USB port of Sony DVD Player
Hi!
When using the pen drive with the dvd player add the images/videos/songs directly into the pen drive without creating any folders in the pen drive and then try to connect.
Thanks
Rylee
Feb 09, 2009 | Sony Audio Players & Recorders
About Pen Drive
1. Connect the USB drive.
2. In XP, select Start>Programs, right-click My Computer, and
select Properties. Click the Hardware tab, then Device Manager. In
Vista, click Start, type device manager, and press <Enter>.
3. Find the drive under ‘Disk drives’.
4. Right-click the drive and select Uninstall.
Confirm by clicking OK.
5. The final step: Unplug the USB drive,
and then plug it in again. The drivers will
reinstall automatically.
Feb 04, 2009 | Transcend (589307) Media
Pendrive i/o device error. it can,t formatte or write send solutions
tell ur pen drive model.
as some pen drives has option to lock it (manually). check it out.
Oct 13, 2008 | Electronics - Others
Pen drive not showing in my explorer.
Its a common problem with the pendrive, in windows. some time it doesnot detect or not showing clearly that device. you have to check your pendrive manufacturer and driver details. and also check it out driver signing.
Do you have mapped network drives on your computer? If you have this may cause your problem. When you insert the PEN Drive into USB and the "safely remove hardware" icon appers try to right-click on it and choose "eject" or "remove" (don't remember :), then pull the PEN DRIVE from the USB and connect it again. Go to Windows Explorer and try to open all your mapped drives, then the content of your PEN DRIVE must be loaded into your Windows Explorer. This is happened sometimes, because PEN DRIVE try to assign the first free drive letter after your phisical drive letters, and if you have a mapped drive letter, the PEN DRIVE assign one of them.
Jul 22, 2008 | Microsoft Windows XP Professional With...
Pen drive does not open
Your pendrive is affected virus and do the format both pen drives and first cheak with your usb port also once and when you are pushing the pen drive in the pc should be smoth dont press just push some times light is appear but data cabe is not connected to pc
Jun 17, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
