Question about Sewing Machines
Error Code - Argos Value Range 75 Stitch Computerised sewing machine
It's giving me error code LO. I have no manual. I would be very grateful if somebody could help please!
  • Mrs R Jan 06, 2013
    When I plug a compatible foot controller in it gives error code Fc instead!
    This is my machine http://www.independent.co.uk/life-style/...
SOURCE: machine beeps and stops sewing, no error message displayed
sounds like not through the tension plate (on top) right... rethread and make sure you hold the thread taunt toward you as you putt through top tension... you should hear a slight click and some resistance...
Posted on Apr 17, 2009
SOURCE: machine will not complete a buttonhole, keeps showing error code 6L. No error code listed in manual. Machine will only do first half of buttonhole and then shows code and stops.
I've been looking too and I found here http://sewing.patternreview.com/cgi-bin/sewingclasses/board.pl?t=18328that you need to put the bar behind the needle threader down. I think they call it a button hole stop? I don't know, but it worked. I didn't even know it existed. But it solved my problem. On my Kenmore it looks like a black lever and you pull it down. It tells the button-holer that you are at the end of the hole and it needs to backup. nifty, kind of.
Posted on May 27, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: MANUAL FOR BROTHER INDUSTRIAL SEWING MACHINE DB2-B755-3
Go to brother.com . From there you will need to enter the model number and serial number to get the file for free good luck
Posted on Jun 01, 2009
SOURCE: error #19 on singer futura ce150
Try re-threading the machine. Also, when you put the thread trough the clear plastic part on the top left at the back, swish it back and forth a couple times before bringing it all the way through. It is a little tip someone told me and seems to work wonders.
Posted on Feb 19, 2010
  • 1116 Answers
SOURCE: instructions manual for the handy stitch sewing machine
http://www.sewwhat.net/millie/Manuals/CEX300k.pdf
Posted on Feb 21, 2010
While sewing a straight stitch after about seeing 2 inches the machine stops 06 stitch lights up and beeps
Since you didn't provide the make & model of your machine, we are unable to help. However, you can check what the error code means by looking in the troubleshooting section of your owner's manual or search for:
Make Mode error code 06
Sep 23, 2017 | Sewing Machines
My stitch indicater only goes onto E8
You didn't provide the make & model of your machine, so we can't even begin to give you a best guess.
Search the internet for:
Make + Model + error code E8
and see if comes up with anything.
Oct 25, 2016 | Sewing Machines
When I give the presser foot power, it goes for about 5 seconds and abruptly stops with the "Lo" appearing on the electronic panel. How can I fix this?
Consult your owner's manual. The Troubleshooting section should explain the error code and suggestions for correcting it.
Oct 23, 2015 | Janome Magnolia 7330 Sewing Machine
Error code E3 45786 on Juki sewing machine motor
I could not find that error using the Manual that is on the Internet.
I suggest you call or email their Sales and Service in the U.K.
Their email is sew-europe@btconnect.com
JUKI DDL 5530 DDL 5550 Parts Needles Service
Feb 16, 2015 | Juki DDL-5550 Industrial Straight Stitch...
Error Code: Check and rethread the upper thread
Yes. It is a sensor on the take up spring. If you miss threading the take up spring you get this error. If take up spring is bent or broken you get this error or if sensor is damaged this error occurs.
May 16, 2014 | Brother LB6770 PRW Computerized Sewing...
Error Code E7 on Singer 6180
E7 means the machine has 'had enough' and that error flashes to let you know it needs a break. I found that out by trial and error and after phoning Singer as well.
Nov 04, 2012 | Singer 7258 Sewing Machine
Where can I get an instruction manual for Argos value range computerised sewing machine?
first contact the people you bought the machine from & ask them about a manual
then if they can't help you contact these sites, you'll probably have to email them about a manual
sewvacdoctor.com
a1sewingmachines.com
sewusa.com
May 10, 2012 | Sewing Machines
E6 error code on cs6000i
it's possible that it's a mechanical or electronic problem or something has worn or is loose, it needs to be serviced
Feb 06, 2012 | Brother CS6000i Computerized Sewing...
I have for gotten how to make the machine sew and im having trouble threading a bobbin for my moms machine elna 7000 i need a manual or a quick note to get started
YOu can down load a manual from here http://www.arizonaexpressionz.com/elna_instruction_manuals/Elna7000.pdf
Just remember to click the bobbin thread into the tension device correctly and hold the two threads behind the pressure foot when you start each seam - Elna top loading bobbins give great stitch quality but you just need to keep stray threads out or they'll jam up.
Also, you must use the Elna plastic bobbin that the manual specifies for this machine - the 5000, 7000 and 9000 were Elna Tavaro Switzerland's first foray into computerised machines and first released in 1986.
Also, please check the manual when you go to buy twin needles, there are two types now as computerised machines usually need the twin needles offset from the shaft position. They have red or black plastic block between the shaft and the twin needles - I think you need the red ones but just double check the manual to make sure. And you can't do all the wide stitches with a twin needle as it will strike the foot.
Hope this helps a little.
Jan 16, 2011 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
122 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
