Toshiba Satellite M305D-S4830 laptop won't boot up. It sounds like it starts to (can hear fan), but the screen never comes on.
Have had problems in the past where the monitor won't come on unless it is brought down to like a 45 degree angle, but now nothing happens. I have the recovery disks, but there are files I would like to recover. Any suggestions?
It sounds like either your display is turned off or the backlight went out. If you have a display selection button on your laptop(usually on one of the function keys), try that. If that doesn't work, try plugging it in to a monitor or other display and check if that works correctly. If it does, your screen either has a bad backlight or other physical problem.
Posted on Jan 04, 2013
  • 1 more comment
  • Steve W Jan 04, 2013
    I did connect it to my desktop monitor but still nothing. Any other suggestions?
  • William Waller Jan 04, 2013
    Does it beep when you turn it on? If so, how many times?
    no beeps, just sounds like it's gonna boot up but stays dark
Astinsan
  • 87 Answers
SOURCE: My Toshiba Satellite L305D-S5895 can't boot. I installed Fedora10
If you get a display or splash screen then you may just have a bad hard disk or memory dimm. If you get nothing then it is a hardware failure beyond a simple fix. Get on the phone with Toshiba and get it fixed before your warranty is up.
Posted on Jan 04, 2009
  • 8 Answers
SOURCE: I have a Toshiba Satellite M305D S4830 I
Someone posted this solution on the Toshiba forums:
http://laptopforums.toshiba.com/t5/Sound-Audio/M305D-S4830-Audio-Driver-for-Windows-XP/m-p/1623;jsessionid=AB9BD9281BB2E90E729E6B1EBDB58A24
Posted on May 17, 2009
Damilare
  • 358 Answers
SOURCE: i have problem with driver sound card in my
Follow this link and Download the drivers :
http://www.drivershq.com/Drivers/Toshiba/Satellite/M305D-S4830/4183/9941/38804/Drivers.aspx
You might need to install a small-sized software first called "Driver Detective"
Posted on Jul 09, 2009
giles102
  • 141 Answers
SOURCE: Hi! I have a Toshiba
You need to plug it into an external screen to see if windows is loading. That way you will know if it the laptop screen it self or t something to do with the computer hardware.
If the fans am starting then you are getting power to the laptop however it may be shorting out just before bios as time to load so you will not get any display.
The best bet is to try and isolate the problem. Try attaching another montior to it and see if you get a display, this test is not always reliable because some laptops requires external monitors to be enabled using windows, so if your getting no output on the laptop screen it cant be done.
If you can get output using an external monitor then the monitor of the laptop may be broke or as become discounted from the motherboard.
Posted on May 07, 2011
  • 11 Answers
SOURCE: I have a Toshiba Satellite M305D-S4830 laptop and
Go to Toshiba's web site and look in the support section for the proper driver(s) for the version of windows you are running on your model.
Posted on May 10, 2011
After changing the converter on satellite M305D-S4830 the backlight still very dim
i'm sure you ment inverter..if its working on external screen? it would seem. that you still need it replaced have u checked the ribbon cables?
Nov 23, 2013 | Toshiba Satellite M305D-S4830 Notebook
Toshiba Satellite M305D-S4830 can not get to BIOS setup.
Hi Guy,
Try those key during the first seconds of the start: ESC, DEL, F1, F2
Do some training before you start to get those keys hit alternatively during the first 3 seconds of start.
Let me know how it goes..
Cheers
Oct 16, 2013 | Toshiba Satellite M305D-S4829 Notebook
Toshiba laptop shuts down at boot up
reprogramming your laptop will definitely solve your problem
Jul 11, 2011 | Toshiba Satellite M305D-S4830 Notebook
I have a toshiba m305d-s4830 laptop. It won't turn
there must be a problem with your memory. if the lights are on and it not continuing booting then F2, it might help.
all the best!
May 15, 2011 | Toshiba Computers & Internet
Toshiba M305D S4830 laptop wont start
"I have M305D S4830 laptop. I put it to sleep in the night. In the morning when i tried to turn it on, it wouldnt start. The light on the switch turns on and it charges the battery fine, but no HDD activity(but it does spin up and stay), no screen, nothing. The fan turns on and then turns off in 1 sec and then just the power indicator lights stay on... i also checked cmos battery, removed it and put it back.its voltage is also fine..."
Hello PPL! Maybe this WILL HELP you! I HAD absolutely the same problem >> 3 months of god **** stress, didn't find any solution, till one day i found on my Recovery CDs one note!! >> It sounds like:
"BEFORE pressing power button, HOLD 'C' button and while Holding 'C' button push POWER Button ONCE!! to start Laptop, KEEP Holding 'C' button!!! untill appears TOSHIBA screen!" then release 'C'. After that, it will appear "Operating System not Found">>then just do a restart by pushing Power Button and Start again! For me, It Worked!! and i'm god **** happy now)...let me know if it Helped you, Good Luck!
Feb 04, 2010 | Toshiba Satellite Laptop with AMD Turion...
Computers & Internet Logo
David Payne
David Payne
