Question about Parmak Solar Fence Charger
Mark 7 work for awhile and stops
13 plus on meter then stops after 5 minutes
    Problem Solver:
  • 15 Answers
Sounds like the input circut board. they had an issue with a resetable fuse. it will damage the PCB, so it will need the entire board replaced.
Posted on Oct 28, 2013
Washer stops at 14 minute mark on cycle. any idea what could cause this?
Try unplugging the plug and leave it for awhile. Then plug it back in and try to do a reset of the washing machine. Open and close the machine's door about 5-6 times within 10-12 sec and this will cause the appliance to reset. It works with most electrical appliances.
Nov 30, 2014 | GE Profile WPRE6100G Top Load Washer
How do I find this missing number? 13 10 17 15 21 _ 25 25
I found the differences between successive numbers and looked for a pattern.
The pattern I saw was -3 +7 -2 + 6...
So the pattern is a negative and then a plus, with both the negative and positive numbers goes down by 1.
If we extend the sequence, we get -3 + 7 -2 +6 -1 +5 -0
I get the sequence 13 - 3=10 +7 =17 -2 =15 +6 = 21 -1 = 20 +5 = 25 - 0 = 25
Good luck.
Paul
Oct 03, 2014 | Office Equipment & Supplies
Scotsman ice maker cme 506 makes ice and turns off and blinks refrigeration
First check to make sure condenser fan is running during freeze cycle. Now check to make sure condenser coil is clean. Her is all the specks on the machine.
1. Ice production ( 500 at 70/50
2. BTUs per hour ( 7000)
3. Maximum times in Minutes. ( 50 freeze, 14 harvest.
4. Refrigerant charge ( R-404A ) ( A-D series: AC 32oz, WC 20 oz. E series AC 23 oz, WC 14 oz, F series AC 23 oz, WC 13 oz
5. Suction pressure ( PSIG ) 35-37 - end of freeze, 120-125-Peak in harvest.
6. Discharge pressure ( PSIG ) 240-260- 5 min in freeze.
165-175- minimum in harvest.
7. Metering device.( TXV plus distributor, E series and higher have two TXVs. superheat 3 to 15 deg F.
8. Average comp.amps. 10-11 during freeze, 11-12 during harvest.
9. Batch Weight. 6.5-7 lb
10. cycle time, 23 minutes @ 90/70. 19 minutes @ 70/50
Feb 24, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Looking for timing mark's for a 1997 camry with a 2.2 4cyl motor?
You find the timing marks on the picture below.
Removal
Remove auxiliary 1. drive belts.
2. Support engine.
Remove:
Engine mounting and bracket.
Timing belt upper cover [1].
3.
4. Turn crankshaft clockwise to TDC on No.1 cylinder. Ensure timing marks aligned [2] & [3].
Remove:
Crankshaft pulley bolt [4].
Crankshaft pulley [5]. Use tool No.09213-60017.
5.
6. Ensure timing marks aligned [2] & [3].
7. Slacken tensioner bolt [6]. Move tensioner away from belt and lightly tighten bolt.
Remove:
Timing belt lower cover [7].
Crankshaft sprocket guide washer [9].
Timing belt.
Tensioner pulley.
Installation
Installation
1. Check tensioner pulley for smooth operation.
2. Check free length of tensioner spring is 46,0 mm [8]. Replace spring if necessary.
3. Fit tensioner and spring. Ensure spring is connected correctly.
4. tighten bolt [6].
5. Ensure timing marks aligned [2] & [3].
6. Fit timing belt. Ensure belt is taut between sprockets.
Install:
7.
8. Slacken tensioner bolt 1/2 turn [6].
9. Turn crankshaft two turns clockwise to TDC on No.1 cylinder. Ensure timing marks aligned [2] & [3].
Turn crankshaft slowly 1 7/8 turns clockwise until crankshaft pulley timing mark [3] aligned with 45° BTDC mark [10] on
timing belt lower cover [7].
10.
11. Tighten tensioner bolt [6]. Tightening torque: 42 Nm.
12. Install components in reverse order of removal.
13. Tighten crankshaft pulley bolt [4]. Tightening torque: 108 Nm.
Manufacturer: Toyota
Jun 25, 2010 | 1997 Toyota Camry
How to reset the error codes (F21) on Bosch Maxx 7?
See this url
http://experts-univers.com/mon-lave-linge-bosch-maxx-7-ne-fonctionne-plus.html
Oct 10, 2009 | Bosch Washing Machines
A/C works in 5-7 minute intervals
compresser usually has low charge when this happens make sure its not leaking refrigerant get r134 with uv dye to locate leak
Jul 15, 2009 | 1999 Dodge Ram
Sony SLV-SE820 VHS VCR
Uh oh. If you have already unplugged this unit and allowed to reset after 5 minutes, it will be time for a service visit...accordianman
Feb 11, 2008 | Sony SLV-SE820 VHS VCR
Lost rice cooking instructions
From the users guide for the 550 FOR BROWN RICE RICE: 2 half cups WATER: To 2 mark, plus 3/4 cup TIME: 32 minutes MAKES: 2 cups RICE:4 cups WATER: To 4 mark, plus 3/4 cup TIME: 39 minutes MAKES: 8 cups Here are the rest: 6 cups To 6 mark, plus 3/4 cup 44 minutes 13-1/2 cups 8 cups To 8 mark, plus 3/4 cup 48 - 49 minutes 15 cups 10 cups To 10 mark, plus 3/4 cup 51 - 52 minutes 21 cups Here is a link to the user guide for all the instructions. http://www.blackanddeckerappliances.com/dyn/prod/user-guide/139/RC410%20RC550.pdf
Jun 22, 2007 | Black & Decker RC550 10-Cup Rice Cooker
Parmak Solar Fence Charger  Logo
142 people viewed this question
Top Parmak Electrical Supplies Experts
 Kenneth
Kenneth
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Parmak Electrical Supply Expert? Answer questions, earn points and help others
