Question about Optics
Scope falls of tripod every time it is moved? Is this poor desin. Nothing seems to be broken
Frustrated my grandson because it would not work. Is this a design flaw.I do not want to run back and forth to stores if this is how you put this product out. How sad ?? Have you had other complaints on this?
  • 3 Answers
What type of telescope is it? Sadly there are a lot of poorly made "hobby killers" out there that suffer from poor optics and/or poor shaky mounts .
But knowing what type, model# & manufacturer would help narrow the problem down
You might also look to see if there is an Amateur Astronomy group in the area. They would likely be able to help.
Posted on Jan 07, 2013
I Need a replacement clamp/holder for one of the tripod legs for my Tasco telescope. The tripod legs are 5/8" dia & each leg fits into its own holder. one of the leg holders are broken and needs t
Looking at your other posts, you don't seem to have a lot of luck with technology - perhaps change the focus of your interests, hmm ? For your scope / tripod problem, take it to a service centre.
Nov 16, 2017 | Optics
Tip
You Just Bought an EQUATORIAL Telescope Mount!
Even though we warned you not to do this, you bought one anyway! Beginners should never buy an EQ telescope mount as their first telescope. It's too late now; so I guess we will need to teach you how to use it!
Equatorial mounts move in a way that seems not to very intuitive. Unlike the easy Alt AZ mount which moves up and down and left and right, the EQ mounted telescope seems to move in TWO dissimilar directions at the same time.
Additionally you must first polar align the mount on the North star Polaris before you can use it. SEE! we told you not to buy it!
Here are the steps to roughly polar align the telescope so you can use it. If it is motorized the single Right Ascension motor will keep the sky object inside the eyepiece for long periods of time. If you do not have a Right Ascension motor, the slow motion RA knob can be slowly turned to keep the sky object centered in the eyepiece.
Begin by leveling the mount and tripod. Move the entire mount and tripod so it is pointing roughly to North, as close as possible using the steps below or a compass. Don't forget to adjust for your magnetic deviation. My location's compass reading is about 5 degrees away from true North. This is called magnetic deviation. You can find your location's deviation on the internet. Then proceed with the steps below.
First, adjust the Declination to the latitude for your observing site. Declination is the angle that the scope is pointing UP, and it's the same as your latitude. For example Dallas, Texas is about 32 degrees North latitude, adjust the scope so the small indicator reads 32 degrees. By the way, the North star in Dallas, TX is about 32 degrees above the horizon. Your latitude matches the elevation of Polaris (the North star) above the horizon.
Second, either look through the polar alignment scope buried in the axis of the telescope mount, or look along side the axis, and get the star Polaris lined up in the cross-hair of the polar alignment scope, or as best you can by looking along the side of the mount axis, or lining it up using your compass.. This will put the scope to within about 3/4 of 1 degree of the TRUE North celestial sphere. This is good enough for VISUAL observation, but NOT good enough to do astro-photography..
Adjust the DECLINATION up or down, and move the entire mount left or right until you can see Polaris as indicated above, or it is lined up as close as possible.
Now you are roughly polar aligned. Now you can move the tube around by loosening the Right Ascension lock, and or the Declination lock until your sky object appears in the small finder scope mounted on top of the main telescope tube.(DO NOT MOVE THE MOUNT, and the counter weight should never be higher than the telescope tube) Lock down the scope in both axis and use the fine adjustment RA and DEC knobs to center the target. Again, DO NOT move the mount or tripod. The mount should still be pointing at Polaris.
This web site illustrates this procedure:
http://www.astronomy.net/articles/4/polaralign.html
also this web site
http://www.telescopes.com/telescopes/polaralignmentarticle.cfm
You should be able to keep an object within the field of view of the eyepiece by slowing turning the Right Ascension slow motion control knob-------- IF you are actually accurately polar aligned. Small adjustments may also be needed with the DEC slow motion knob since you are not exactly polar aligned using this rough alignment technique.
However it can be used successfully for visual observation. Your scope will now track the motion of the stars as they move across the sky.
Hope that helps you!
Clear Skies!
TelescopeMan
www.telescopeman.tumblr.com
on Dec 29, 2009 | Optics
Broken tripod for edu science telescope
You can buy a photo tripod and attach the tube to the tripod. You may need to visit a local hardware store to find the correct mounting bolts.
That scope is sold by Toys R Us -- as far as I know they DO NOT sell replacement parts.
Sorry
Sep 26, 2011 | Edu-Science (10166) Telescope
I need to purchase screw that attaches scope to window mount on a 78-4405
The mount has a 1/4-20 screw that fits most camera equipment. If you have the scope (spotting scope) it should have that hole in the bottom of the mounting ring. If the screw is missing from the window mount then most 1/4-20 tripod screws will work or you may substitute a cap screw and flat washer, to work with an Allen wrench for tightening.
Feb 07, 2011 | Bushnell 784405 Tripod
Could you tell me if a National PE2057 flash gun will work with a pentex sp500 camera
I do NOT recommend this telescope. The eyepieces are plastic, the scope is on a small shaky tripod.
Stop looking at $69 telescopes. Read my TIPS on my profile page.
You will be frustrated with this scope, and it will quickly wind up in a closet or for sale on craigslist.com.
Jul 19, 2010 | National Geographic 76AZ (525 x 76mm)...
Plastic part at end with "hook" on the leg of tripod is broken and despite trying at least three different types of super glues and epoxy I cannot repair it.
The tripod cannot be repaired unless you can find something at a hardware store. Toys R Us (they sell this scope) do not have any parts. A replacement tripod will cost more than the scope is worth. We receive more complaints about this telescope than just about any other brand.
Next time buy something like this:
http://www.telescope.com/control/product/~category_id=classicdobs/~pcategory=dobsonians/~product_id=09804
Jul 02, 2010 | Edu-Science (10166) Telescope
Radian pro Gt head broke that holds the scope.
You can still order the plate that attaches the camera/scope to the head from Eagle Optics directly at this link:
http://www.eagleoptics.com/tripod-accessories/vortex/radian-pro-gt-quick-release-plate
Feb 10, 2010 | Radians Radian Pro-GT Tripod
Giottos VT 806 tripod
The long pan handle tightens and loosens front to back moves. Are you using it? If you are in the USA and need help call us at 800 735-4373
Mar 21, 2008 | Giottos (VT806) Tripod
Cannot attach tripod plate to scope - stripped receptacle
Hardware stores should have thumb screws in different sizes and thread lengths ... box stores , local hardware ....
Jun 11, 2017 | Minox MD 62 ED W 62213
Optics Logo
32 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
