My GA-VM900M Mother board gives a long beep after another when I switch it on. The monitor remains black and the power light stays on.
  • 3,606 Answers
Hello here is the homepage:
http://www.gigabyte.com/products/product-page.aspx?pid=2581#dl
Drivers or the manual can be selected in download type.
A long beeb is a fault in a RAM module.
Try to insert a ram module you know is working.
Your mainboard use DDR 2 ram, up to 4 GB.
Another fault could be the power supply.
Blow also any dust out with compressed air before working on the mainboard and take antistatic precautions
Here is a list of beeb codes:
http://www.computerhope.com/beep.htm
Good luck
Posted on Jan 04, 2013
  • 1 more comment
  • Lindani Mabuza Jan 04, 2013
    Can the RAM DDR2-666 be put in place of DDR2-667/533 ?
  • Hans Pedersen
    Hans Pedersen Jan 05, 2013
    Yes it can.
  • Lindani Mabuza Jan 10, 2013
    Bt its stil giving the beep.
5 Suggested Answers
SOURCE: intel 845 chipset mother board no reaction - expecting solution
respected sir..... i tried lot times...as per ur suggessions.. 1 beap sound .. it indicates mother board ram and parts ok... if i installed new ram ddr1 type... no reaction .... ... more over .. am also hardware engineer card level... i chatted with somboey... they told there may be clock problem.... what should i do... further... and suggest me how to do....
thanx
Posted on Feb 27, 2008
  • 192 Answers
SOURCE: Hi. got problems with my ga-vm900m audio drivers. cannot play or hear audio. please help with drivers. Hlonza
Hi there.
You can download the audio drivers from the Gigabyte website here:
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=2581
Just select your operating system, then select the driver you want to download.
Hope that helps.
Tim
Posted on Apr 19, 2009
fmuise
  • 83 Answers
SOURCE: audio input is not working for my pc mother board
Hey Jack Jackol,
This should do the trick, enjoy!
ftp://download.gigabyte.ru/driver/motherboard_driver_audio_via_hd_vista_beta.exe
Posted on Mar 18, 2010
ghost2233
  • 3606 Answers
SOURCE: mother board
Download here at gigabyte:
http://www.gigabyte.pt/products/page/mb/ga-8i915me-gl/download/
Posted on Nov 15, 2012
There is no power in mother board
check the power supply first or check if the power cored is connected to the motherboard
Aug 20, 2011 | Gigabyte GA-VM900M Motherboard
I have Gigabyte Mother board GA-VM900M mother borad I not able to install audio driver, and also let me know which audio driver is recomennded
on this page
http://www.gigabyte.com/products/product-page.aspx?pid=2581&dl=1#dl
select your operating system and go
Feb 23, 2011 | Gigabyte GA-VM900M Motherboard
I want mother board cd
check www.giga-byte.com and just downlaod the appropriate drivers that you need. hope this helps.
Aug 09, 2010 | Gigabyte GA-VM900M Motherboard
Monitor screen stays black even though it's on
Remove the memory from your unit - power it up it should beep if full communication is still happening across your m/board. No beeps you board has died. if it beeps and your using two diffent memory modules just fitt one leave the battery out and power it up = if no display pull power swap out the memory and try again. if display occurrs you have a defective memory module - throw that failed unit away
glenn
Mar 07, 2009 | Compaq Computers & Internet
Gigabyte ga-8ld533 mother board problem
i have a problem with my mother bord 8ld533.my head phone is not working properly also its working with a small sound,alredy a have installed my sound driver..can you help me please...
Oct 31, 2008 | Gigabyte GA-8LD533 Motherboard
Red light and monitor will not start up
you need to shut down the computer and pull the power cord off powersupply then remove the wire harness that goes on to the mother board then press the and hold the computer on button for 3 seconds then plug in the the harness back on the mother board and and plug in all power cords then try to turn on the computer it should give u a beep or the monitor should go from orange to green good luck e-mail me if u want tbirdfan1@yahoo.com
Aug 07, 2008 | Intel Motherboard
Monitor shut off, no BIOS post, no keyboard or mouse lights, will not boot
The best thing to do in this situation is to build your machine outside of the case, using the minimum amount of hardware,
Remove the motherboard and using only one stick of ram, the monitor, keyboard and mouse. short the power switch connector on the motherboard with a screw driver for a fraction of a second just to power it on.
If it starts up and gives you a "no boot disk" or "no Operating System found" at least you will know it's working and you can slowly connect everything else one by one to see whats preventing it from booting.
If it doesn't start like that, remove the power cord from the power supply and remove the mother board battery for at least 15 minutes, this will clear the BIOS and set it back to factory spec, now carryout the out of case procedure already stated.
Jul 22, 2008 | Intel Motherboard
Computers & Internet Logo
247 people viewed this question
David Payne
David Payne
