Question about Kensington Ci65m Optical Mouse 72267
Kensington 72267 wireless mouse
The mouse simply stopped working. The red light underneath lights up, but not the green one on top. I've changed the batteries twice, but still no luck. Any ideas on why this is happening?
4 Suggested Answers
yooperbud
  • 8637 Answers
SOURCE: how to install batteries on kensington wireless mouse 72214
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this.
Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Posted on Jan 22, 2009
yboyandrei
  • 828 Answers
SOURCE: Kensington wireless mouse doesn't work on Mac laptop.
Kensington wireless mouse is compatible with this system:
PC-Windows® 98, Me, 2000, or XP with USB port
USB Macintosh® with OS 10.1.5 or later
USB Macintosh® with OS 8 and 9 device will only function as a 1-button mouse
If you buy this item you have a disk utility on it and provide the software to run on the system. If not you can download it at this site: http://us.kensington.com/html/4398.html
Posted on Jul 08, 2009
  • 310 Answers
SOURCE: I have a kensington wireless mouse. the wireless
Have you tried to resync the mouse with the receiver. Usually,you need to press the button on the reciever first, then quickly hit the button on bottom of the mouse.
Posted on Oct 05, 2009
Right side of mouse stopped working :(
broken mouse button. Use compressed air to remove the dust, or replace the mouse with a different one.
Oct 26, 2013 | Kensington Ci65m Optical Mouse 72267
The right side isn't working?
The right button? A right side button? What is not working?
Logitech M510 suddenly stopped working
What does the device manager say about the hardware?
It could be loss of the usb device controller. Windows XP is old and that is an indication that the hardware is old too.
Mar 25, 2017 | Logitech M510 Wireless Laser Mouse
Wireless mouse stopped working. green light works
This can happen when the battery's are starting to die. Replace the batteries and then test the device again.
Oct 09, 2009 | HP Wireless Optical Mouse
I have a kensington wireless mouse. the wireless keyboard works, but the mouse does not. The red laser light is on, but it won't move
Oct 05, 2009 | Kensington Computers & Internet
Jul 08, 2009 | Kensington PocketMouse 72214
Mouse stopped working
Check underneath for dirt or debris blocking the laser light lens, try on a different surface ie (mousepad). If that doesn't solve your problem, it's time for a new one.
Jun 19, 2009 | ACCO Brands Kensington o - Laser Si750m LE...
Flashing red light on the Kensington wireless mouse base
I still have the manual for my mouse.  Model number 64321.
When this mouse was manufactured it used NiCad batteries which developed a memory much more than the newer batteries.  The older NiCad batteries needed to be conditioned occasionally so Kensington provided a way to do that with the charging base.
The red light is for indicating discharge status of NiCad batteries.
The red light will flash quickly when you press the battery discharge button on the bottom of the base.  This indicates that you now have 5 seconds to place the mouse in the charging base for battery discharge.
The red light will flash flash more slowly when the battery is being discharged.
After the battery is fully discharged, the base will then charge the batteries.
It should be noted that very few manufacturers of products that utilized NiCad batteries provided a "battery conditioning" feature.  Kensington was unique in this regard.  Battery conditioning allowed NiCad batteries to have a longer useful life.
Now maybe you can help me....  I lost my power supply that plugs into the USB connector.  If you have yours, can you tell me what the output voltage is and what the polarity is of the inner pin.  This will be marked right on the power supply base.
I plan to just get a generic power supply from Radio Shack, but I need the voltage value and polarity.  Until then, I can still use the mouse, but it won't charge.  FOr now, I'm just using standard AAA batteries.
Thanks.
bartman9@earthlink.net
Mar 17, 2009 | Kensington StudioMouse Wireless
MS wireless notebook mouse 3000 not working?
A friend of mine brought me this problem with exactly the same problem. here is what I found. The small notch in usb device socket under the mouse was malfunctioning. If you press this notch you will find the mouse red light blink. If you further try pressing this notch at some point the mouse red light comes on constantly. Thats it, hold it there and try to connect first by pressing the usb device connect switch and then the mouse connect switch. The moment the connection is made the usb device stops blinking and the red light on the mouse starts blinking. Wow, it works now. Some one might just open the mouse and fix this microswtich for a permanent solution.
Jul 08, 2008 | Microsoft Wireless Notebook Optical Mouse...
Kensington Ci65m Optical Mouse 72267 Logo
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
Pierre Legault
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
