Question about Comfort Zone CZ1500WC Infra-Red Utility/Portable Heater
Flashing AO5 it shut off and when i tried to turn on, flashes AO5 or AOS and click.
If the relays are clicking there are 2 1000uf capacitors on the main board that will be bad. If you know how to work on electronics you can unsolder and then replace them problem solved I just fixed my dads heater today cost about 2.00 bucks :). The capacitors have to be 1000uf 105c google them.
Posted on Jan 11, 2013
A05 on screen. Will not let me change temperature. Will not come on.
turn on heater ao5 comes on hit temp switch clicks but goes back and forth from ao5 to temp degree is it the printed circuit board please email at archieholdsworth@yahoo.com
Jan 08, 2016 | Comfort Zone CZ1500WC Infra-Red...
AO5 keeps flashing with a click sound
check room sensor and coil sensor
Nov 21, 2014 | Heating & Cooling
Flashing red flight
Its probably the cleaning light that comes on periodically to remind you to clean the unit. Shut off the unit AND when you do so hold down the power button for several seconds until the flashing red light shuts off. The cleaning light should stay off until the next cleaning is due.
Per the Air-O-Swiss FAQ:
Q: Cleaning light is flashing (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: Switch the unit OFF and unplug it. Empty the water in the base. Rinse the base with hot/clean water. Do not submerge the base! Visually inspect the base for dirt or mineral build up. If soft water is used decalcifying the unit every 4 weeks with EZ Cal is suggested. If hard water is used the unit should be decalcified every 2 weeks. Do not forget to reset the clean light after resetting the unit.
Q: Reset cleaning light (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: The cleaning light does not automatically reset. Hold down the power button (button A in instruction manual) until the light stops flashing. The light automatically comes on approximately 14 days after plugging in the unit.
Feb 15, 2014 | Air-O-Swiss U7142 Humidifier
Samsung ln46c530 lost picture, now won't turn on. Indicator light turns on solid red when on, flashes five times when shut off
The fault is with its main board itself. Troubleshooting to this board is not an easy work to a user can do. It will be best to contact any service technician. google.com/+GopakumarGopalan
Nov 24, 2013 | Samsung LN46C530 TV
Error code AOS
its show flashing AO5 code and than shut off
Nov 18, 2013 | Comfort Zone CZ1500WC Infra-Red...
I have the Comfortzone Infrared heater. The heating unit will not kick on. It tries to but then a code comes up that looks like AOS or AO5.
sounds like the outlet is not enough power for the heater. Remember with an electric heater youre dealing with watts and amps, It should be plugged into its own dedicated service for proper operating.
Mar 04, 2011 | Heating & Cooling
How to clean air-o-swiss humidifier?
Gererally according to the booklet in the box.
If you no longer have those instructions, simply clean out the
basin, make sure no mold, dust, hardwater or calcium is deposited.
Use a 10% bleach water solution to kill bacteria, and thats is basically it.
Just dont miss any spots, but humdifiers should be cleaned every few uses.
Feb 19, 2010 | Air-O-Swiss 7133 Humidifier
How do fix my Archos 605 after resettin using factory option
Well If a white screen shows up when you turn it on, select format. Wait for it to finish, then when it asks for a update file, plug it in to the computer and copy the .aos update file to the archos. Don't put it in a folder, just put it the root, (the folder that has the folders for music, video, flash, etc.) Unplug it and the archos should recognize it and proceed with the firmware update.
The Updates can be downloaded here:
for 20GB-160GB
http://update.archos.com/5/a605/a605_r2.1.04/firmware_a605.aos
or for the 4GB
http://update.archos.com/5/a605f/a605f_r2.1.04/firmware_a605f.aos
Aug 25, 2009 | Archos 605 WiFi Digital Media Player
Lg ru52sz51d will not turn on intermittantly
Check fan if bad set will not turn on ,it will try to come on.Bad Fan.
Nov 12, 2008 | LG RU-52SZ51D 52" Rear Projection...
Aos
hi chinadski...by aos files i pressume you mean Archos Operating System files i.e firmware ??..this you dont need a programme for all you do is click and drag the file into your root directory but be carefull i upgraded mine last night and the instructions stated it can cause all sorts of problems if not done correctly
Feb 29, 2008 | Archos 405 Digital Media Player
Comfort Zone CZ1500WC Infra-Red Utility/Portable Heater Logo
852 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
