Question about Hitachi NR90GC 3 1/2" Gas Powered Clipped Head Framing Nailer
I have just serviced my hitachi nr90gc2 as i do every 6 months, the gun will fire one nail then the firing pin stays out and the fan isnt kicking in like it normally does, do you have any suggestions?
Also what oil would you recommend is used for the o rings? cheers
  • 3 Answers
SOURCE: Hitachi Framing Gun Not Firing - Bad Battery?
Does the fan run and the light blink ont he nailer? I have one that I just bought. I put in the wrong type of nails and got one stuck. I had to take the front apart to clear it and now the damm thing wont fire. The green light blinks and the gas cartridge is basically full, even the fan does run after I release the push lever, but no fire???
I wonder if yours is the same as mine did fire for a couple nails first just fine then got jammed...
I will try to charge the battery more.... MAybe like yours it needs a strong charge for the spark...
Russ
Posted on Oct 05, 2008
  • 23 Answers
SOURCE: My nail gun hitachi nr83a2 only fires a nail half way
the blade assemblies for the A and A2 are the same.
the pison bumper should not be attached to the driver, if the bumper is moving around inside the gun i suggest checking to make sure it was properly seated when the gun was reassembled. if it was, i suggest ordering a new bumper.
a cracked bumper will usually cause a broken driver.
Posted on Nov 17, 2008
  • 1388 Answers
SOURCE: Hitachi NR83A air leak
Most all Hitachi nailers that use the plunger style of firing/safety mech will leak air past plunger (part #877-339) when firing, however should not leak when connected to air or resting. If air is leaking past plunger when connnected to air check following:
Remove head to reveal cylinder plate (part#877-318). Remove plate and check outer oring for nicks or broken. If nicked or broken, replace and problem solved. If in good condition, remove cylinder guide (part #877-310) and check two outer orings for nick /cut. Use caution when removing/installing cylinder guide. It is easy to pinch orings when installing causing air leak at plunger. If orings are in good shape then problem is warped body of gun not allowing outer orings to seal. To check for warped body, use the cylinder plate as a guage by lowering it into the area where the cylinder guide rests. Good Luck with your repair.
Posted on Mar 12, 2009
  • 1388 Answers
SOURCE: Hitachi NR 83A2S, Nail wont fire properly
The NR83a has an adjustment just below the triggering plunger. It is a 6mm hex head bolt with a locking nut. Loosen the nut and adjust screw out several turns and re-test. Make adjustment as necessary. I have seen many of these gun without the locking nut which allows the bolt the adjust itself all the way down. AS parts wear this screw needs to be adjusted. The pushing lever and the plunger are wearing smaller/shorter, that is unless the locking nut was missing. Remove gun from air supply for safety when making adjustments. Good Luck an email if you have other qustion about this gun.
Posted on Apr 27, 2009
  • 10 Answers
SOURCE: Can I use paslode roundrive nails in a Hitachi NR90GC Gas Nailer
Yes, BUT the paslode Round drive nails and known to cause driver jamms due to the excessive paper used in the spacing of the nails.
Posted on Oct 31, 2009
I pull the trigger and you get a air sound but no firing of nails . You get air release from top of gun
Could be just a lack of lubrication in the headvalve /orings or the safety foot is not pushing in the trigger pin all the way. Easy to check. Remove the head and pull out the head-valve. Apply plenty of white grease or silicone paste to the orings and the surface where the orings make contact. Install the head and test. If the gun fires then you are done. If the gun does not fire, make sure that the safety foot is depressing the trigger valve all the way in when attempting to nail. Simple test is to remove the trigger exposing the firing pin. With nails removed and air connected, with quick motion depress the firing pin all the way in. If the gun fires make adjustments to safety foot. If the gun still does not fire (with headvalve lubed) replace the firing valve core part # ca0108. Good luck
Mar 05, 2015 | Senco & Frame Pro 601 Framing Nailer
Hitachi nail gun
If gun firing but nails not being driven could be one of two basic problems:
1. Nail jammed in magazine not allowing nails to move up.
Empty magazine, does follower move to top of magazine. Push gun against work piece, does fan motor start? Yes - jam in magazine or lock out bar not operating. (this would allow nail un to fire when out of nails)
2. Piston/driver not returning fully after firing, hence driver blade on top of next nail instead of behind it. This could again be caused by a jammed nail or just a nail head. Another case of not returning is the combustion chamber not making a good seal, check O rings on framer (they are steel rings on bradders) it may just need a good clean it is surprising how dirty they can get and if not cleaned a build up of dirt could break a seal. If not been cleaned for a long time worth checking piston rings, worst case scenario dirt builds up around the rings and stick fully in requiring new piston if the rings will not come out.
Nail guns work on the principle that an explosion pushes the piston driver forcing a nail into the work piece, after the explosion a vacuum is created and it is this that 'sucks' the piston/driver back up the cylinder.
Mar 27, 2014 | Tools & Hardware - Others
My hitachi nail gun NV 50AA will fire, but won't advance the nails on a regular basis
NV50 nailer is very difficult to repair due to complicated feeder /feeder spring / feeder retainer pin design. You most likely need to replace the orings on the feeder piston. Problem is that you must remove the feed pin/ spring to get the piston out. If you are going to attempt to replace the orings, study how the pin is installed otherwise you will make it worse. Order new springs (2 different springs ) and install them when you are going back together. Good luck
Mar 03, 2013 | Tools & Hardware - Others
I have a Hitachi NR 83A2 nail gun, it still fires a nail, the firing pin retracts but then slowly comes out and stays out. Is there a seal kit available for this problem?
Sounds like you have worn valves or damaged o-rings. Unfortunately Hitachi does not make a rebuild kit for your nail gun. If you go to www.ereplacementparts.com you can find an excellent breakdown of your tool and either order the parts you need there or use the part numbers to search the web for prices and availability. Your tool is on the old side and some parts are no longer available.
Feb 26, 2013 | Tools & Hardware - Others
Why does my Hitachi nv45ab gun double fire nails?
This gun should be bump-fired only. Do not place the gun on the work and press trigger. Make sure that the safety spring is in place and has good tension. The spring helps to push the foot off the trigger so that it fires once. You could also adjust the screw that pushes on the firing valve. Turn in or out several turns till head of nail is correct when bump firing then lock the nut. The safety foot fits rather loose on the gun and should still work ok but can get so loose that it falls off the nose. Good luck
Jan 23, 2013 | Hitachi Air Tools & Compressors
Nv45ab won't advance nails
The allen screw/s that you mention are there to plug holes where automatic equipment would normally connect (such as automatic nailing machines) . This is only a plug and should not be driven in too far. I have also seen allen screws installed in the head to repair small crack/s.
Jan 22, 2013 | Hitachi Air Tools & Compressors
Hitachi NR83AA shoots two nails on one pull of the trigger?
Best practice is to bump fire the gun to prevent double fire. Do not place the gun on the work and pull the trigger. This takes practice while using at an angle. Works better if the nose piece has rather sharp points to help nose to stay in postion while you bump. With trigger depressed, practice without nails bumping/hitting wood at different angles untill you can bump hit at the spot that you need the fastener. If the gun double fires while bump-firing, most likely all the safety/trip parts are worn/loose. Not expensive to replace. Good luck.
Jul 05, 2012 | Air Tools & Compressors
Sparks when shooting a nail
It is common to see sparks. It is metal striking metal. Although, if it sparks alot. It could be a chipped driver blade and the nail would not drive all the way. Does your sink `em?
Aug 15, 2009 | Hitachi NT65MA2 1 1/4 To 2 1/2 Inch 15...
Russ
Sep 28, 2008 | Hitachi NR90GR Cordless Round Head Gas...
Hitachi NR90GC 3 1/2" Gas Powered Clipped Head Framing Nailer Logo
97 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
