Question about Gestetner DSm627sp All-In-One Laser Printer
How to change paper setting on tray 1 for a gestetner DSm627sp?
    Habit-Forming:
  • 103 Answers
Press the counter key.
tap the system settings on the screen
select tray settings and select the type of paper you prefer and tap on the ok .
After this open the tray and set the tray settings to the paper size.
All the best of luck .
Posted on May 25, 2014
2 Suggested Answers
  • 32 Answers
SOURCE: hi i have problems with my 7502 gestetner nrg photocopier
This sounds like a paper size issue. Check your papersize and oriontation in the tray(green selector font right or back left of tray) and check paper settings under the user tools menu for tray 1. let me know if that works, so we can trouble shoot.
Posted on May 08, 2010
Gestetner 5308L error says set drum completely
Please open the front door carefully and open the right door also and then remove the photoconductor unit unit and reset properly.
If the problems persist , call an expert to check the sensor for you.
Best of luck.
Apr 18, 2014 | Gestetner DSm627sp All-In-One Laser...
Copier Gestetner Dsc530 (or Ricoh Aficio mp c3000) has error SC501 - tried to reset, but need to replace thermistor. Can't find a diagram on where it's located on the fusing unit. Anyone?
Error code SC501 is not a fuser problem. It is the top paper feed tray. Take all of the paper out of tray 1 and turn the machine all the way off. Turn it back on. Code should be cleared. If it returns with no paper in it the paper feed station has a broken part and can only be repaired by replacing it.
Nov 04, 2013 | Gestetner Office Equipment & Supplies
NEED TO KNOW WHERE TO GET SOFTWARE FOR DSM627SP TO HOOK UP TO MY COMPUTER TO USE PRINTER
You can download DSm627 sp drivers and software from the link below:
http://www.nrgcss.com/drivers/Page2.Asp?Brand=gest&Vw=&Fltr=0&Ky=1124409&Usr=&Cat=3&Mdl=237&Pvw=1
Apr 07, 2010 | Gestetner DSm627sp All-In-One Laser...
My Gestetner DSm622sp says it has a hard drive problems, codes SC870, 872 what do I do
Most machines just use regular or notebook hard drives available anywhere.
Just replace & format it inside of the copier menus.
Jun 20, 2009 | Gestetner DSm627sp All-In-One Laser...
Copier Only prints half the page
Sounds to me that the paper tray is set incorrectly. There is a dial on the back of the machine that needs to be set correctly once the paper tray guides are adjusted accordingly -particularly when running 8 1/2 x 11" (letter) size paper. It can be set to run either lengthwise, or laterally (portrait) make sure the dial is set to the proper setting on ALL trays. If the tray is set for lateral, for example, and the paper is installed lengthwise, the scanner only utilizes 8 1/2" in length rather than the full 11". Frequent jamming is also a common problem when making multiple copies, because the paper is not where the machine "expects" it to be. Also check that the LCD display reads the proper size / orientation after adjustment.
Hope this helps. Please rate solution :)
May 21, 2009 | Gestetner Copier
Hi i have problems with my 7502 gestetner nrg photocopier
Feb 23, 2009 | Gestetner DSm618 All-In-One Printer
Gestetner DSM627
Have you tried the default UN and PW? UN: admin PW: password
Aug 27, 2008 | Gestetner DSm627sp All-In-One Laser...
Printing Problem - Help
n your computer, left click on START, left click on CONTROL PANEL, then left click on PRINTERS. On the PRINTERS SCREEN, RIGHT CLICK on GESTETNER icon. On the drop down menu, left click on PROPERTIES. Left click on ACCESSORIES tab. On the paper source setting, select TRAY 1 LETTER as the default paper source, left click on UPDATE, then APPLY, then OK.
May 08, 2008 | Gestetner Copier
Cannot print from Tray 1 in Gestetner 6002
First make sure that the machine is reading/ seeing the paper size of the paper that is in the tray ( select tray 1 from the touch screen and see what the paper size reads). If the machine sees a different size then that in the tray, use the 'user tools' and change the paper for that tray. Also, go into your printer settings on/in your computer and make sure that the proper paper size is selected ( the size that is in the tray you want to print from). If the orientation of the paper size is different from the tray -- will not print and give you the error.
May 06, 2008 | Gestetner - 6002 Digital Imaging System...
Gestetner DSm627sp All-In-One Laser Printer Logo
23 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
