Question about Trek 3500
When I start to peddle the gear shifter moves as if im shifting gears and the chain comes off. Any suggestions?
The gear shifter moves up and the chain is loose not allowing me to peddle.
  • 21 Answers
I'm assuming you have levers on your shifter. If so, typically, the problem is the screw on the side has come loose allowing the lever to move. Tighten the screw a little see if it resolves your problem. If not snug it up some more. The tension of the screw creates the friction to keep the lever from moving.
Posted on Jan 06, 2013
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: for shifting gears up on
http://www.parktool.com/blog/repair-help/rear-derailler-adjustments-derailleur
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
and don't try to use large chainrings with large cogs or small with small (cross-chaining is unnecessary and potentially damaging).
Posted on May 22, 2011
How do I fix jumping gears on rear derailleur?
I also would check if the chain is not worn out. When the lenght increases the chain links, these also can make the chain jump. Put the bike up and rotate the peddles, while shifting gears and watch if the d?railleur moves fast enoug. Perhaps even the jumping is over, because the links are not pulled out.
for chain wear, check out this wiki. Bicycle chain Wikipedia the free encyclopedia
Mar 22, 2015 | Cycling
How do you use all the gears on a mgx dsr 21 speed mountain bike?
The way I start inexperienced rider out is by using only the left shifter first. Take a ride and only shift the left side up and down. Remember to pedal when shifting, Backpedaling or coasting may cause the chain to come off. Once you are familiar the left shifter, move to the right one. Up and down several times. Most experienced riders don't use all of the gears and only use the lower gears I steep hilly situatiuons
Oct 28, 2014 | Cycling
The bike slips when peddle.
If the bike has gearing I would get your shifters checked to make sure everything is lined up properly and the shift points are set properly. if they are not it can cause the chain to drop off a gear only to shift back up on next rotation of the pedals.
Sep 16, 2014 | Cycling
2000 ford mercury 3.0, shifter wont move. had a fender bender, put it into park and it wouldn't come back out.
For car not changing gears it can be shifter assembly issue, or it can also be transmission issue. Get the shifter assembly inspected with ignition OFF.
For more troubleshooting, I suggest you to get the Following help link checked, its complete step by step procedure to inspect gear shift issues: -----
GEAR SHIFT ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/gear-shift-issues.html
These will help.
Thanks.
Feb 15, 2013 | 2000 Mercury Sable
Turbo R-24 Model Empire 24 Inch Men&s Bike how many if any gears does it have shows to have ◦Shifters: Shimano tourney index but what does this mean. Sears can't answer
Count the number of sprockets you have up front, then count the number you have in the rear, Multiply, 3 x 6 = 18 speeds. 3 up front, 6 in the rear, or 2 up front, 5 in the rear, 10 speed. Etc, they go as high as 21. You might only have one in the front.
To shift, you have to be peddling, get the bike going, put the chain on the middle or the biggest sprocket in the front, move the left thumb shifter to do this, do not let the chain rattle, make it a clean shift and don't let it klik or rub. Then put the chain on the biggest one in the rear , without any rubbing, chattering, slipping, etc,with the right shifter, now you are ready to take off easily, when you get going and the pedals get too easy and go faster, shift the rear to the next sprocket down, then again, then when you are coming to a stop, down shift the rear sprocket back to the biggest gear and you will be ready to take off again easily. A few tries, you will shifting like mario andretti. Hope this helps.
Jun 16, 2010 | Empire Turbo TURBO BICYCLE R-24 MODEL...
How to use thumb shifters on a 21 speed Schwinn Highplains bike
OK, for a beginner in the world of 18 speed bikes, put the chain on the big sprocket up front, it should be about 46 teeth, make sure it is center and doesn't make noise, if it does, adjust it just a hair either way, now, the rear, put the chain on the big sprocket in the rear, make sure the front didn't start making noise, if it did, adjust it again. You are now ready to take off, in low gear, as you start out, it is easy to pedal, soon you will be peddling air, shift into second gear in the rear only, don't touch the front. Just a little push with the thumb will make it shift, now were going faster, easy peddling, shift into 3rd, then 4th, etc, coming to a stop, down shift the back sprocket back into low gear (big sprocket) and be ready to take off again. Soon you will be shifting that thing like a Ferrari! The front sprocket, will be used for moderate terrain, wheelies, and mountain climbing, that will come later, learn how to shift the rear first. As each gear climaxes, hit the shifter, it will get smoother as you go, and keep the chain quiet, no climbing on the next sprocket or falling out of gear. Hope this helps.
May 03, 2010 | Cycling
I just bought my bike at wal-mart and I didnt get a manual. Iam having a hard time changing gears
I'm assuming you bought a mountain type thing with 12 -18 gears on it, It is easy enough to shift it, as long as it is it working right, They should have set the stops on both shifters front and rear for you. They might be a little off, but when in low gear rear, your chain should not go over the limit and fall into the spokes. Like wise in high gear, should not fall off the cluster in high. The front is the same, the chain should stop at the sprockets smoothly, and not crunch into gear. My bike shifts like a car, 1,2,3,etc. Your front sprockets, unless you are mountain climbing, leave it on the big sprocket, about 46 teeth, and get used to running that high gear up front, now the rear sprocket, you start off in low, biggest one, and move your shifter while you are peddling, 2nd, then 3rd, and when you come to a light or have to stop, downshift to low again in the rear and you'll be ready to take right off. There are a lot of people out there who don't know how to shift these things and they leave them in one gear and pedal air. Hope this helps.
Apr 20, 2010 | Cycling
Gear shift will not move -- button on gear shift will not depress to move gear shift out of park
ck brake switch,,shifter will not move,,if brake switch on brake peddle does not activate it ,
Feb 06, 2010 | 2008 Chevrolet Impala
Hard to shift into first gear
Tighten clutch cable until the car would start to move when the clutch peddle is 50% depressed, Before you do that, with the clutch fully depressed and in 2nd gear, start the car and slowly let off the clutch. You may find that the clutch has to be released virtually all the way before the car moves. It should be at about that 50% I spoke about
Dec 07, 2009 | 1999 Mercury Cougar
Problem with chain and gears
Wash, degrease and scrub the chain and derailleurs with a good degreaser (like Simple Green). Dry the chain and relubricate it with an appropriate bike chain lubricant (not oil or WD-40). Shift the derailleurs to the smallest chain ring and cog on the cassette (low front gear, high rear gear) and then loosen the cable at the derailleurs, pull the cables taut and reattach them. If the derailleurs still need adjustment, here is a procedure for it:
Flip the bike over (so you can pedal the bike manually while you shift) and shift the front to the middle chain ring. Shift the rear to the highest gear (small cog). Release the cable from the pinch bolt on the derailleur. Adjust the screw marked "H" on the derailleur until the jockey wheel on the derailleur is aligned perfectly over the small cassette cog. Set the cable adjuster on the derailleur to the middle of its range (find this by screwing it all the way in and then count how many revolutions it makes until it screws out completely. Screw it back in one half of the total revolutions). Reattach the cable and shift to the lowest gear (the biggest cog). Over-shift and hold on the shifter, then adjust the "L" screw on the derailleur until the jockey wheel sits just past the last cog. You have to hold the shifter to do this. Now shift into the middle gear (or one of the two middle gears if the bike has an even number of gears) and adjust the derailleur using the barrel adjuster you previously set to the middle of its range. Adjust it so that the derailleur is sitting perfectly over the appropriate gear. Shift up and down the cassette while pedaling and in every gear, reverse pedal (freewheel) to make sure the chain does not hop. Adjust as necessary until all gears are smooth.
Now the front:
Set the rear derailleur to the lowest gear (big cog) and the front to the lowest gear (small chain ring). Disconnect the derailleur cable. Screw in the adjuster for the cable tension all the way (this adjuster is on the shifter of a mountain bike or the down tube of a road bike). Pedal to make sure the chain is not rubbing on the derailleur cage. If it is, adjust the "L" setting on the derailleur until the chain moves by without touching the cage. Now pull taut and reattch the cable and shift the front to the big ring while pedaling. If it does not shift up well or completely, hold the shifter past its normal shift and adjust the "H" screw so that the derailleur allows the shift. Shift into the highest cassette gear and keep pedaling. The chain should not be touching the front derailleur's cage when you pedal. Adjust with the barrel adjuster until the chain moves freely without touching the derailleur cage.
That should be it, unless there is another mechanical problem causing the missed shifts, like a bent derailleur hanger or damaged teeth on the cassette cogs or a bad derailleur. If it is still problematic, come back for further information.
i hope this helps
-matthew
Oct 26, 2009 | Cycling
Trek 3500 Logo
71 people viewed this question
Top Trek Cycling Experts
Andrew Crawshaw
Level 1 Expert
dante
Are you a Trek Cycling Expert? Answer questions, earn points and help others
